Jp 5.0.2 eqos compilation error on Jetson Orin
In the kernel configuration file tegra_defconfig, configure the macro CONFIG_EQOS = y and report an error
Some compiled logs are as follows:
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c:843:11: warning: ‘struct skb_frag_struct’ declared inside parameter list will not be visible outside of this definition or declaration
struct skb_frag_struct *frag,
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c: In function ‘eqos_map_page_buffs_64’:
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c:847:31: error: dereferencing pointer to incomplete type ‘struct skb_frag_struct’
unsigned int page_idx = (frag->page_offset + offset) >> PAGE_SHIFT;
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c: In function ‘tx_swcx_alloc’:
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c:984:34: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
struct skb_frag_struct *frag = &skb_shinfo(skb)->frags[i];
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c:986:13: error: dereferencing pointer to incomplete type ‘struct skb_frag_struct’
len = frag->size;
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c:997:12: error: passing argument 3 of ‘eqos_map_page_buffs_64’ from incompatible pointer type [-Werror=incompatible-pointer-types]
frag, offset, size);
/works/project/orin/kernel/nvidia/drivers/net/ethernet/nvidia/eqos/desc.c:841:12: note: expected ‘struct skb_frag_struct *’ but argument is of type ‘struct skb_frag_struct *’
static int eqos_map_page_buffs_64(struct eqos_prv_data *pdata,
cc1: some warnings being treated as errors
make[6]: *** [/works/project/orin/kernel/kernel-5.10/scripts/Makefile.build:281: drivers/net/ethernet/nvidia/eqos/desc.o] Error 1
make[5]: *** [/works/project/orin/kernel/kernel-5.10/scripts/Makefile.build:498: drivers/net/ethernet/nvidia/eqos] Error 2
make[4]: *** [/works/project/orin/kernel/kernel-5.10/scripts/Makefile.build:498: drivers/net/ethernet/nvidia] Error 2
make[3]: *** [/works/project/orin/kernel/kernel-5.10/scripts/Makefile.build:498: drivers/net/ethernet] Error 2
make[2]: *** [/works/project/orin/kernel/kernel-5.10/scripts/Makefile.build:498: drivers/net] Error 2
make[1]: *** [/works/project/orin/kernel/kernel-5.10/Makefile:1854: drivers] Error 2
make[1]: *** Waiting for unfinished jobs…
Thank you
What is the purpose to enable EQOS? This driver is no longer supported on jetpack5.0.2.
Gigabit Ethernet using rgmii interface
The driver is also changed… we no longer support this driver.
If you want to run RGMII, try to read document… there is no need to build EQOS driver…
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=rgmii#program-the-nvethernet-driver-dt-to-allow-it-to-work-with-the-third-party-phy-switch
My DT file contents are:
    /* EQOS */
    ethernet@2310000 {
            status = "okay";
            nvidia,mac-addr-idx = <0>;
            nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
            phy-mode = "rgmii-id";
            phy-handle = <&phy>;
// /delete-node/ fixed-link;
nvidia,max-platform-mtu = <16383>;
mdio {
compatible = “nvidia,eqos-mdio”;
#address-cells = <1>;
#size-cells = <0>;
                    phy: phy@0 {
                            reg = <0>;
                            compatible = "ethernet-phy-id001c.c916";
                            device_type = "ethernet-phy";
                            #if TEGRA_ETHERNETPHY_DT_VERSION >= DT_VERSION_2
                            /* use phy in poll mode */
                            #else
                            interrupt-parent = <&tegra_main_gpio>;
                            interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
                            #endif
// marvell,copper-mode;
/* Setup LED[2] as interrupt pin (active low) */
marvell,reg-init = <0x03 0x12 0x7fff 0x880>;
the pinmux changes:
pinmux@2430000 {
pinctrl-names = “default”, “drive”, “unused”;
pinctrl-0 = <&pinmux_default>;
pinctrl-1 = <&drive_default>;
pinctrl-2 = <&pinmux_unused_lowpower>;
pinmux_default: common {
eqos_txc_pe0 {
nvidia,pins = “eqos_txc_pe0”;
nvidia,function = “eqos”;
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
                    eqos_td0_pe1 {
                            nvidia,pins = "eqos_td0_pe1";
                            nvidia,function = "eqos";
                    eqos_td1_pe2 {
                            nvidia,pins = "eqos_td1_pe2";
                    eqos_td2_pe3 {
                            nvidia,pins = "eqos_td2_pe3";
                    eqos_td3_pe4 {
                            nvidia,pins = "eqos_td3_pe4";
                   eqos_tx_ctl_pe5 {
                            nvidia,pins = "eqos_tx_ctl_pe5";
                    eqos_rd0_pe6 {
                            nvidia,pins = "eqos_rd0_pe6";
                            nvidia,tristate = <TEGRA_PIN_ENABLE>;
                            nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                    eqos_rd1_pe7 {
                            nvidia,pins = "eqos_rd1_pe7";
                    eqos_rd2_pf0 {
                            nvidia,pins = "eqos_rd2_pf0";
                    eqos_rd3_pf1 {
                            nvidia,pins = "eqos_rd3_pf1";
                    eqos_rx_ctl_pf2 {
                            nvidia,pins = "eqos_rx_ctl_pf2";
                    eqos_rxc_pf3 {
                            nvidia,pins = "eqos_rxc_pf3";
                    eqos_sma_mdio_pf4 {
                            nvidia,pins = "eqos_sma_mdio_pf4";
                    eqos_sma_mdc_pf5 {
                            nvidia,pins = "eqos_sma_mdc_pf5";
                    soc_gpio17_pg4 {
                            nvidia,pins = "soc_gpio17_pg4";
                            nvidia,function = "rsvd0";
                            nvidia,pull = <TEGRA_PIN_PULL_UP>;
                            nvidia,lpdr = <TEGRA_PIN_DISABLE>;
                   soc_gpio18_pg5 {
                            nvidia,pins = "soc_gpio18_pg5";
            pinmux_unused_lowpower: unused_lowpower {
            drive_default: drive {
The current situation is that the RGMII_TXC pin has a 125MHz clock. When other pins Ping other hosts, there is no signal
boot log
luk-adu510_2022-09-05_18_16_15.log (329.7 KB)
Please check adaptation guide first. This PHY and RGMII has been validated by many other users/customers already.
Make sure you do full flash instead of partial update in each time you change things. Device trees, or dtsi file.
And make sure the dtsi got flashed is indeed the file you modified…
ADU506-RTL8211.pdf (141.7 KB)
rgmii 相关的原理图
The rgmii SCH is demaged.
Is there a problem with this sch? Excuse me, what’s the problem?
retransmission
RGMII_TXC has 125MHz output, right?
“other pins other hosts, there’s no signal”, this is not clear, can you please list the pin names?
‘other host’ do you mean — RTL8211?
yes,RGMII_TXC has 125MHz output .
rgmii rt8211DHCP cannot get IP,Manually set an orin rt8211 IP s,Ping other hosts;
The pins without signal are:
RGMII_TX_CTL
RGMII_TD0
RGMII_TD1
RGMII_TD2
RGMII_TD3
how about MDIO, does Orin get right info from MDIO?
The correct ID number is obtained at startup: 0x001cc916 (rtl8211f); After that, it can correctly identify the inserted and unplugged network cables
My DTS file’s
tegra234-p3711-ethernet.dtsi (1.5 KB)
tegra234-p3737-eqos-pinmux.dtsi (3.8 KB)
tegra234-soc-eqos.dtsi (7.5 KB)
麻煩你就把dtb用dtc 轉成dts然後貼那個dts就好了 不需要把每個dtsi都貼出來.
please just convert your final dtb back to dts by using dtc tool and just post that dtc tool. No need to paste every dtsi file here.
