JP 6.0/6.1 secureboot
We are using Jetson Orin Nano with Jetpack 6.0.
Right now, I am looking into secureboot and disk encryption procedures.
Per the documentation of r36.4 odmfuse.sh is deprecated and we should use FSKP instead.
I’d appreciate some clarifications regarding:
  1. Can I still use odmfuse at all?
  2. Per the documentation [here](https://docs.nvidia.com/jetson/archives/r36.4/DeveloperGuide/SD/Security/FSKP.html#sd-security-fskp)I need to send a certificate to NVIDIA and get a results.zip. Who do I send it to?
  3. Also, I can’t find where we can download the fusing tools (fskp_partner_t234_R3x.x.0_aarch64.tbz2)
hello shai.segev,
Factory Secure Key Provisioning (FSKP) is a technique to securely burn fuses on the factory floor.
you may still working with odmfuse.sh to burn fuse.
or, please see-also $OUT/Linux_for_Tegra/bootloader/README_Massfuse.txt for using nvmassfusegen.sh.
sorry, it’s not public available.
