用JP 7.1(38.4.0),bootloader用的uefi_t26x_minimal.bin(主要是做启动时间优化),系统不能正常启动
log如下
英伟达thor用了uefi_t26x_minimal.bin后系统起不来。▒▒[ 0.541392] Camera-FW on t264-rce-safe started
TCU early console enabled.
CoE: setup IRQ=0 MGBE=0 local_irq=150
CoE: setup IRQ=1 MGBE=0 local_irq=151
CoE: setup IRQ=2 MGBE=0 local_irq=152
CoE: setup IRQ=3 MGBE=0 local_irq=153
CoE: setup IRQ=4 MGBE=0 local_irq=154
CoE: setup IRQ=0 MGBE=1 local_irq=155
CoE: setup IRQ=1 MGBE=1 local_irq=156
CoE: setup IRQ=2 MGBE=1 local_irq=157
CoE: setup IRQ=3 MGBE=1 local_irq=158
CoE: setup IRQ=4 MGBE=1 local_irq=159
CoE: setup IRQ=0 MGBE=2 local_irq=160
CoE: setup IRQ=1 MGBE=2 local_irq=161
CoE: setup IRQ=2 MGBE=2 local_irq=162
CoE: setup IRQ=3 MGBE=2 local_irq=163
CoE: setup IRQ=4 MGBE=2 local_irq=164
CoE: setup IRQ=0 MGBE=3 local_irq=165
CoE: setup IRQ=1 MGBE=3 local_irq=166
CoE: setup IRQ=2 MGBE=3 local_irq=167
CoE: setup IRQ=3 MGBE=3 local_irq=168
CoE: setup IRQ=4 MGBE=3 local_irq=169
[ 1.047708] Camera-FW on t264-rce-safe ready SHA1=dd50722c (crt 2502.995 ms, total boot 637.305 ms)
▒▒S Memory ranges:
[80000000 - 80000100 (1 pages)]
NS Memory ranges:
VM 8001: I/TC:
VM 8001: I/TC: No non-secure external DT
VM 8001: I/TC: manifest DT found
VM 8001: I/TC: Switching console to device: /ffa-console
VM 8001: I/TC: OP-TEE version: 4.4 (gcc version 13.2.0 (crosstool-NG 1.26.0)) #2 Tue Dec 30 23:37:02 UTC 2025 aarch64
VM 8001: I/TC: WARNING: This OP-TEE configuration might be insecure!
VM 8001: I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
VM 8001: I/TC: Primary CPU initializing
VM 8001: I/TC: Test TZ root key is being used. This is insecure for shipping products!
VM 8001: I/TC: fTPM ID is not enabled.
VM 8001: I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
VM 8001: I/TC: Primary CPU switching to normal world boot
VM 8002: (version 38.4.0-gcid-43443517 2025-12-30T23:33:22+00:00)
VM 8001: I/TC: WARNING: Test UEFI variable auth key is being used !
VM 8001: I/TC: WARNING: UEFI variable protection is not fully enabled !
VM 8002: Boot Complete
▒▒t26x_minimal UEFI firmware (version 38.4.0-gcid-43443517 built on 2025-12-30T23:33:08+00:00)
▒▒L4TLauncher: Attempting Direct Bo▒▒L4TL▒▒ot
▒▒ fin▒▒Find▒▒her:▒▒Part▒▒ Att▒▒itio▒▒empt▒▒nInf▒▒ing ▒▒o: F▒▒Dire▒▒aile▒▒ct B▒▒d to▒▒oot
Fin▒▒d pa▒▒dPar▒▒rent▒▒titi▒▒s - ▒▒onIn▒▒Not ▒▒fo: ▒▒Foun▒▒Fail▒▒d
P▒▒ed t▒▒roce▒▒o fi▒▒ssEx▒▒nd p▒▒tLin▒▒aren▒▒uxCo▒▒ts -▒▒nfig▒▒ Not▒▒: Un▒▒ Fou▒▒able▒▒nd
▒▒g: U▒▒Proc▒▒find▒▒essE▒▒ par▒▒xtLi▒▒titi▒▒nuxC▒▒on i▒▒onfi▒▒nfo
L4T▒▒nabl▒▒Laun▒▒e to▒▒cher▒▒ fin▒▒: Un▒▒d pa▒▒able▒▒rtit▒▒ to ▒▒ion ▒▒proc▒▒info▒▒ess ▒▒
L4▒▒extl▒▒TLau▒▒inux▒▒nche▒▒ con▒▒r: U▒▒fig:▒▒nabl▒▒ Not▒▒e to▒▒ Fou▒▒ pro▒▒nd
▒▒el B▒▒L4TL▒▒ ext▒▒aunc▒▒linu▒▒her:▒▒x co▒▒ Att▒▒nfig▒▒empt▒▒: No▒▒ing ▒▒t Fo▒▒Kern▒▒und
▒▒Laun▒▒L4T▒▒oot
Fin▒▒cher▒▒dPar▒▒: At▒▒titi▒▒temp▒▒onIn▒▒ting▒▒fo: ▒▒ Ker▒▒Fail▒▒nel ▒▒ed t▒▒Boot▒▒o fi▒▒
Fi▒▒nd p▒▒ndPa▒▒aren▒▒rtit▒▒ts -▒▒ionI▒▒ Not▒▒nfo:▒▒ Fou▒▒ Fai▒▒nd
▒▒ion:▒▒Read▒▒to f▒▒Andr▒▒ind ▒▒oidS▒▒pare▒▒tyle▒▒nts ▒▒Kern▒▒- No▒▒elPa▒▒t Fo▒▒rtit▒▒und
Rea▒▒ Una▒▒dAnd▒▒ble ▒▒roid▒▒to l▒▒Styl▒▒ocat▒▒eKer▒▒ed p▒▒nelP▒▒arti▒▒arti▒▒tio▒▒▒▒▒▒▒
▒▒[ 0.540775] Camera-FW on t264-rce-safe started
[ 1.047919] Camera-FW on t264-rce-safe ready SHA1=dd50722c (crt 2503.240 ms, total boot 637.729 ms)
▒▒S Memory ranges:
NS Memory ranges:
VM 8001: I/TC:
