用JP 7.2 (39.2.0),thor开机串口打印错误log
用JP 7.2 (39.2.0),thor开机串口打印错误log,是什么问题?这个错误log有什么影响么?
Hi mingkuo2010,
Are you using the devkit or custom board for Thor?
This is usually a known, harmless display/DCE log message.
It commonly appears when a DP AUX/DPCD access fails, and by itself it does not indicate a fatal issue unless it is accompanied by real symptoms such as black screen, display hotplug failure, or resume/display malfunction.
