How to fix this error message??
tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
20220601_xavier_custom_kernel.log (68.0 KB)
tegra194-p2888-0001-p2822-0000.dts (460.3 KB)
What have been done on yout device?
How to repdocut this error?
Is this custom carrier board?
It is custom board … use jetson_agx_xavier
I don’t see this error in SDK4.6.1…
I don’t know why this message appears
Compare the kernel… is a new code in JP5.0!
If you want to use usb2-0 as host mode, then why do you keep it in xudc?
xudc is the device mode controller.
Thanks Reply
No error message after I removed usb2-0
fix
phy-names = “usb2-0\0usb3-2”;
to
phy-names = “usb3-2”;
