请问我想将vi相关的所有补丁创建一个文件夹收集在一起防止我们做的产品后续遇到问题了再去浪费时间寻找补丁,请问你们能够提供一下有关5.1.4相关的所有vi的补丁吗?
The provided context does not contain any information about the “Jetson Orin NX vi514vi”. The context appears to be related to the NVIDIA Jetson Linux Developer Guide, specifically the Jetson Orin NX Series and Jetson Orin Nano Series modules.
However, based on the context, here is a comprehensive overview of the Jetson Orin NX Series and Jetson Orin Nano Series modules:
The Jetson Orin NX Series and Jetson Orin Nano Series modules are part of the NVIDIA Jetson family of embedded systems. These modules are designed for edge AI applications and provide a range of features and capabilities.
The modules connect to the carrier board using a 260-pin SODIMM connector, which is a DDR4 SODIMM, 260-pin, right-angle, standard key type. The full height of the connector is 9.2 mm, and other heights are available.
In terms of design, the modules require a specific mounting hardware configuration, which includes metal standoffs and screws (or equivalent) to provide mechanical integrity and to ensure proper installation.
The context also mentions a tuning and compliance guide for the Jetson Orin NX Series and Jetson Orin Nano Series modules, which covers topics such as USB tuning and compliance testing, PCIe compliance testing, HDMI tuning, VESA DisplayPort and embedded DisplayPort tuning, and Ethernet compliance testing.
Unfortunately, without more information about the “Jetson Orin NX vi514vi”, it is not possible to provide a more specific answer. If you could provide more context or clarify what you are looking for, I would be happy to try and assist you further.
我想要获得有关jp5.1.4的vi相关的所有补丁代码
hello Edsonsl111,
JetPack 5.1.4/L4T 35.6.0 should be more stable then previous JP-5 release versions.
may I know what’s the failure use-case? or, what changes you’re looking for?
anyways, you may see-also Topic 305007, here’s a bug fix of error recovery has failed, which cause a kernel panic.
你好,目前还没有在使用中遇到的问题,不过确实遇到过这个内核恐慌,我希望是能够提前将补丁打入防止后续产品会出现其他问题再去搜索补丁而造成麻烦
all right, please apply the bug fixes from Topic 305007.
