Jp5 missing from https://pypi.jetson-ai-lab.io/
Based on this forum, it looks like https://pypi.jetson-ai-lab.io/ is finally supposed to be stable, but is jp5 going to be added to this? Based on this posts, it doesn’t seem like jp5 is EoL yet and I’m currently restricted from upgrading to jp6 or jp7.
Based on the provided context, I will attempt to provide a comprehensive answer to the question.
The question is asking about the stability of the Jetson Orin NX platform, specifically regarding the addition of JP5 (Jetpack 5.0) to the platform. The user is currently restricted from upgrading to JP6 or JP7 and is inquiring about the status of JP5.
From the provided context, we can gather the following information:
  • Jetson Orin NX is a platform for AI computing and is part of the NVIDIA Jetson series.
  • Jetpack is a software development kit for NVIDIA devices, including the Jetson Orin NX.
  • JP5, JP6, and JP7 refer to different versions of the Jetpack software.
  • The user is currently using JP5 and is restricted from upgrading to JP6 or JP7.
Regarding the stability of the Jetson Orin NX platform, the provided context does not explicitly state that JP5 is End-of-Life (EoL). However, it does mention that JP6 is available, and the user is restricted from upgrading to it.
Comparing the information provided, we can see that:
  • Jetson Orin NX is a platform that supports PCIe connections and has a hardware development kit available.
  • Jetpack is a software development kit that provides a comprehensive solution for building AI applications.
  • JP5, JP6, and JP7 are different versions of the Jetpack software, with JP6 being the latest available version.
Based on this information, it appears that JP5 is not EoL yet, but the user is restricted from upgrading to JP6 or JP7. The stability of the Jetson Orin NX platform with JP5 is not explicitly stated, but it is likely that NVIDIA will continue to support JP5 until it is officially declared EoL.
In conclusion, while the provided context does not explicitly state the stability of the Jetson Orin NX platform with JP5, it suggests that JP5 is not EoL yet, and the user should continue to use it until further notice from NVIDIA.
We will focus on JetPack 6 and JetPack 7 for the new server.
For the previous release, you should be able to build it from the source.
Or you can find some PyTorch packages below:
