JP6: Out of tree modules & upstream kernels
I have a question regarding the OOT modules & newer kernels (say 6.6) - looking at Bring Your Own Kernel — NVIDIA Jetson Linux Developer Guide 1 documentation it would seem that for instance sound drivers were upstreamed in 5.16 and so I’d imagine once when using a newer kernel and building the OOT modules I should disable those in OOT and stick to the upstream modules?
Are there any other “dualities” between upstream / OOT modules that should be watched out for?
if the "sound drivers were upstreamed in 5.16 " , the driver will be removed from nvidia-oot repository.
So, yes, your understanding is correct, the driver from one place only needed to be enabled/used
