JP7.2 R3920 开机的时候有概率 到内核阶段风扇声音特别大
hi:
我们在3920的代码中测试,发现开机的时候风扇会突然很大声音,上传内核log,帮忙看看是哪块的问题
[    0.000000] [TS:24002256930]         Trampoline variant of Tasks RCU enabled.ter_boot).
[    0.000000] [TS:24002258513]         Tracing variant of Tasks RCU enabled.
[    0.000000] [TS:24002260847] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] [TS:24002262606] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=14
[    0.000000] [TS:24002304115] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=14.
[    0.000000] [TS:24002309634] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=14.
[    0.000000] [TS:24005070060] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] [TS:24006484106] GICv3: 1024 Extended SPIs implementede mode
[    0.000000] [TS:24006536310] GICv3: GICv3 features: 48 PPIs, DirectLPI
[    0.000000] [TS:24006916393] GICv3: CPU0: found redistributor 0 region 0:0x0000008146080000
[    0.000000] [TS:24007062902] ITS@0x0000008146040000: Single VMOVP capable
[    0.000000] [TS:24007066106] ITS@0x0000008146040000: Using GICv4.1 mode 00000000 00000001
[    0.000000] [TS:24007078699] ITS@0x0000008146040000: allocated 8192 Devices @100130000 (indirect, esz 8, psz 64K,[    0.000000] [TS:24007087254] ITS@0x0000008146040000: allocated 32768 Interrupt Collections @100140000 (flat, esz 2, psz 64K, shr 1)
[    0.000000] [TS:24007094847] ITS@0x0000008146040000: allocated 8192 Virtual CPUs @100150000 (flat, esz 8, psz 64K, shr 1)
[    0.000000] [TS:24007156078] GICv3: using LPI property table @0x0000000100160000
[    0.000000] [TS:24007270273] ITS: Using DirectLPI for VPE invalidation
[    0.000000] [TS:24007273069] ITS: Enabling GICv4 support
[    0.000000] [TS:24007279893] GICv3: CPU0: using allocated LPI pending table @0x0000000100170000
[    0.000000] [TS:24007314504] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] [TS:24010440523] arch_timer: cp15 timer(s) running at 1000.00MHz (phys).
[    0.000000] [TS:24010446328] clocksource: arch_sys_counter: mask: 0x1fffffffffffffff max_cycles: 0x1cd42e4dffb, m[    0.000001] [TS:24010453597] sched_clock: 61 bits at 1000MHz, resolution 1ns, wraps every 4398046511103ns
[    0.000315] [TS:24010767884] Console: colour dummy device 80x25
[    0.927653] [TS:24938106096] printk: legacy bootconsole [tegra_utc0] disabled
[    0.927712] [TS:24938165013] Calibrating delay loop (skipped), value calculated using timer frequency.. 2000.00 B[    0.927716] [TS:24938169263] pid_max: default: 32768 minimum: 301
[    0.927799] [TS:24938251578] landlock: Up and running.ability,landlock,yama,apparmor,integrity
[    0.927799] [TS:24938252504] Yama: becoming mindful.
[    0.927860] [TS:24938313393] AppArmor: AppArmor initialized
[    0.927932] [TS:24938384597] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.929210] [TS:24939663022] rcu: Hierarchical SRCU implementation.31072 (order: 8, 1048576 bytes, linear)
[    0.929596] [TS:24940048634] fsl-mc MSI: its@8146040000 domain created/its@8146040000 domain created
[    0.930343] [TS:24940796384] Tegra Revision: A01 SKU: 160 CPU Process: 0 SoC Process: 0
[    0.933069] [TS:24943521837] Detected PIPT I-cache on CPU1Us ....
[    0.933107] [TS:24943559809] GICv3: CPU1: found redistributor 10000 region 0:0x00000081460c0000
[    0.933120] [TS:24943572708] GICv3: CPU1: using allocated LPI pending table @0x0000000100180000
[    0.933141] [TS:24943593865] CPU1: Booted secondary processor 0x0000010000 [0x410fd830]
[    0.933839] [TS:24944292134] Detected PIPT I-cache on CPU2
[    0.933879] [TS:24944332513] GICv3: CPU2: found redistributor 20000 region 0:0x0000008146100000
 te @0x00000001001900004349309] GICv3: CPU2: using allbuats  Lit plidid
[    0.933925] [TS:24944378393] CPU2: Booted secondary processor 0x0000020000 [0x410fd830]
[    0.934614] [TS:24945066754] Detected PIPT I-cache on CPU3
[    0.934655] [TS:24945108485] GICv3: CPU3: found redistributor 30000 region 0:0x0000008146140000
[    0.934671] [TS:24945124245] GICv3: CPU3: using allocated LPI pending table @0x00000001001a0000
[    0.934699] [TS:24945152087] CPU3: Booted secondary processor 0x0000030000 [0x410fd830]
[    0.935428] [TS:24945880643] GICv3: CPU4: found redistributor 40000 region 0:0x0000008146180000
[    0.935443] [TS:24945896337] GICv3: CPU4: using allocated LPI pending table @0x00000001001b0000
[    0.935469] [TS:24945921643] CPU4: Booted secondary processor 0x0000040000 [0x410fd830]
[    0.936157] [TS:24946609698] Detected PIPT I-cache on CPU5
[    0.936196] [TS:24946648865] GICv3: CPU5: found redistributor 50000 region 0:0x00000081461c0000
[    0.936212] [TS:24946664995] GICv3: CPU5: using allocated LPI pending table @0x00000001001c0000
[    0.936237] [TS:24946689624] CPU5: Booted secondary processor 0x0000050000 [0x410fd830]
[    0.936939] [TS:24947392504] Detected PIPT I-cache on CPU6
[    0.936979] [TS:24947431930] GICv3: CPU6: found redistributor 60000 region 0:0x0000008146200000
[    0.936994] [TS:24947447384] GICv3: CPU6: using allocated LPI pending table @0x00000001001d0000
[    0.937022] [TS:24947475541] CPU6: Booted secondary processor 0x0000060000 [0x410fd830]
[    0.937761] [TS:24948214217] GICv3: CPU7: found redistributor 70000 region 0:0x0000008146240000
[    0.937777] [TS:24948229717] GICv3: CPU7: using allocated LPI pending table @0x00000001001e0000
[    0.937803] [TS:24948255717] CPU7: Booted secondary processor 0x0000070000 [0x410fd830]
[    0.938481] [TS:24948934300] Detected PIPT I-cache on CPU8
[    0.938525] [TS:24948977763] GICv3: CPU8: found redistributor 80000 region 0:0x0000008146280000
[    0.938541] [TS:24948993726] GICv3: CPU8: using allocated LPI pending table @0x00000001001f0000
[    0.938567] [TS:24949020069] CPU8: Booted secondary processor 0x0000080000 [0x410fd830]
[    0.939262] [TS:24949714911] Detected PIPT I-cache on CPU9
[    0.939307] [TS:24949760004] GICv3: CPU9: found redistributor 90000 region 0:0x00000081462c0000
[    0.939323] [TS:24949776078] GICv3: CPU9: using allocated LPI pending table @0x0000000100200000
[    0.939350] [TS:24949803115] CPU9: Booted secondary processor 0x0000090000 [0x410fd830]
[    0.940042] [TS:24950495087] Detected PIPT I-cache on CPU10
[    0.940088] [TS:24950541476] GICv3: CPU10: found redistributor a0000 region 0:0x0000008146300000
[    0.940105] [TS:24950557800] GICv3: CPU10: using allocated LPI pending table @0x0000000100210000
[    0.940839] [TS:24951292384] Detected PIPT I-cache on CPU11sor 0x00000a0000 [0x410fd830]
[    0.941621] [TS:24952074393] Detected PIPT I-cache on CPU12sor 0x00000b0000 [0x410fd830]00220000
[    0.942418] [TS:24952871467] Detected PIPT I-cache on CPU13sor 0x00000c0000 [0x410fd830]00230000
[    0.942622] [TS:24953075013] SMP: Total of 14 processors activated.000d0000 [0x410fd830]00240000
[    0.942623] [TS:24953076171] CPU: All CPU(s) started at EL2
[    0.942625] [TS:24953078124] CPU features: detected: Branch Target Identification
[    0.942629] [TS:24953081643] CPU features: detected: ARMv8.4 Translation Table Level
[    0.942630] [TS:24953083513] CPU features: detected: Instruction cache invalidation not required for I/D coherence
[    0.942632] [TS:24953085078] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.942634] [TS:24953086671] CPU features: detected: Common not Private translations
[    0.942635] [TS:24953088263] CPU features: detected: CRC32 instructions
[    0.942637] [TS:24953089596] CPU features: detected: Data cache clean to Point of Deep Persistence
[    0.942638] [TS:24953091411] CPU features: detected: Data cache clean to Point of Persistence
[    0.942640] [TS:24953093004] CPU features: detected: Data independent timing control (DIT)
[    0.942644] [TS:24953096652] CPU features: detected: Enhanced Counter Virtualization (CNTPOFF)
[    0.942645] [TS:24953098430] CPU features: detected: Enhanced Virtualization Trapsver
[    0.942647] [TS:24953099819] CPU features: detected: Fine Grained Traps
[    0.942649] [TS:24953102272] CPU features: detected: Generic authentication (architected QARMA3 algorithm)
[    0.942654] [TS:24953107550] CPU features: detected: RAS Extension SupporterR)
[    0.942656] [TS:24953108976] CPU features: detected: Stage-2 Force Write-Back
[    0.942658] [TS:24953110958] CPU features: detected: TLB range maintenance instructions
[    0.942660] [TS:24953112976] CPU features: detected: WFx with timeout
[    0.942662] [TS:24953115300] CPU features: detected: Scalable Vector Extensionng Safe (SSBS)
[    0.942784] [TS:24953237078] alternatives: applying system-wide alternatives
[    0.945563] [TS:24956016393] CPU features: detected: Hardware dirty bit management on CPU0-13
[    0.945566] [TS:24956019337] SVE: maximum available vector length 16 bytes per vector
[    0.945568] [TS:24956021143] SVE: default vector length 16 bytes per vector
[    0.950341] [TS:24960794189] devtmpfs: initialized
[    0.977469] [TS:24987922106] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.981444] [TS:24991897430] SMBIOS 3.6.0 present.ized pinctrl subsystem62144 bytes, linear)
[    0.981450] [TS:24991903161] DMI: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS hyj-774f2260 07/17/2026
[    0.981969] [TS:24992422013] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.983142] [TS:24993595133] DMA: preallocated 16384 KiB GFP_KERNEL pool for atomic allocations
[    0.983584] [TS:24994036930] DMA: preallocated 16384 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.984048] [TS:24994500596] audit: initializing netlink subsys (enabled)MA32 pool for atomic allocations
[    0.984127] [TS:24994579976] audit: type=2000 audit(0.980:1): state=initialized audit_enabled=1 res=1
[    0.984907] [TS:24995359671] thermal_sys: Registered thermal governor 'step_wise'
[    0.984914] [TS:24995367411] thermal_sys: Registered thermal governor 'power_allocator'
[    0.984937] [TS:24995389995] cpuidle: using governor ladder
[    0.985073] [TS:24995526161] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.985242] [TS:24995695069] ASID allocator initialised with 65536 entries
[    0.986188] [TS:24996641495] Serial: AMBA PL011 UART driver
[    0.989972] [TS:25000425198] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/arad@9870000
[    0.989978] [TS:25000431495] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000
[    0.989981] [TS:25000434226] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000
[    0.989985] [TS:25000438235] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.989988] [TS:25000441532] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000
[    0.989992] [TS:25000445226] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000
[    0.989995] [TS:25000448384] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.989998] [TS:25000450865] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000
[    0.990001] [TS:25000453893] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000
[    0.990004] [TS:25000457078] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.990008] [TS:25000460606] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9560000
[    0.990012] [TS:25000465356] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9550000
[    0.990016] [TS:25000469078] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.990019] [TS:25000472448] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9530000
[    0.990023] [TS:25000475717] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[    0.990026] [TS:25000478587] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.990029] [TS:25000482328] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000
[    0.990033] [TS:25000486235] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000
[    0.990037] [TS:25000489911] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.990040] [TS:25000493532] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000
[    0.990044] [TS:25000497180] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000
[    0.990047] [TS:25000500356] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.990052] [TS:25000505541] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[    0.990056] [TS:25000509152] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[    0.990060] [TS:25000513041] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000
[    0.990067] [TS:25000520300] /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990072] [TS:25000524763] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[    0.990078] [TS:25000530856] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bu[    0.990086] [TS:25000539393] /bus@0/aconnect@9000000/ahub@9630000/amx@9510000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990094] [TS:25000547143] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990102] [TS:25000554828] /bus@0/aconnect@9000000/ahub@9630000/amx@9530000: Fixed dependency cycle(s) with /bu[    0.990109] [TS:25000562504] /bus@0/aconnect@9000000/ahub@9630000/amx@9540000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990118] [TS:25000570726] /bus@0/aconnect@9000000/ahub@9630000/amx@9550000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990126] [TS:25000578689] /bus@0/aconnect@9000000/ahub@9630000/amx@9560000: Fixed dependency cycle(s) with /bu[    0.990134] [TS:25000586809] /bus@0/aconnect@9000000/ahub@9630000/adx@9590000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990141] [TS:25000594402] /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990149] [TS:25000602041] /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000: Fixed dependency cycle(s) with /bu[    0.990156] [TS:25000609087] /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990164] [TS:25000617217] /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990171] [TS:25000624393] /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000: Fixed dependency cycle(s) with /bu[    0.990179] [TS:25000632263] /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990191] [TS:25000644180] /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000: Fixed dependency cycle(s) with /bu[    0.990198] [TS:25000651106] /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990205] [TS:25000658476] /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990213] [TS:25000666106] /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000: Fixed dependency cycle(s) with /bu[    0.990220] [TS:25000673041] /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000: Fixed dependency cyc[    0.990228] [TS:25000681041] /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990235] [TS:25000687976] /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990242] [TS:25000695115] /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990251] [TS:25000704059] /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990283] [TS:25000736263] /bus@0/aconnect@9000000/ahub@9630000/arad@9870000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.990304] [TS:25000757180] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_p@56
[    0.990309] [TS:25000762476] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_o@54
[    0.990314] [TS:25000767171] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_n@52
[    0.990319] [TS:25000771902] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_m@50
[    0.990324] [TS:25000776671] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_l@36
[    0.990328] [TS:25000781115] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_k@34
[    0.990332] [TS:25000785235] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_j@32
[    0.990337] [TS:25000789689] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_i@30
[    0.990341] [TS:25000794087] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7: Fixed dependency cycle(s) with [    0.990346] [TS:25000798745] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_a@40
[    0.990350] [TS:25000802763] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_f@22
[    0.990354] [TS:25000806846] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@4: Fixed dependency cycle(s) with [    0.990358] [TS:25000810671] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@3: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_h@26
[    0.990362] [TS:25000815254] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_g@24
[    0.990366] [TS:25000819124] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@1: Fixed dependency cycle(s) with [    0.990371] [TS:25000823874] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/g2m0@66
[    0.990393] [TS:25000845596] /bus@0/i2c@810c680000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[    0.990399] [TS:25000852235] /bus@0/i2c@810c6a0000/g2m0@66: Fixed dependency cycle(s) with /bus@0/host1x@81812000[    0.990404] [TS:25000857106] /bus@0/i2c@810c6a0000/g2m1@67: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@1
[    0.990410] [TS:25000862819] /bus@0/i2c@810c6a0000/ar0234_p@56: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15
[    0.990415] [TS:25000868078] /bus@0/i2c@810c6a0000/ar0234_o@54: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14
[    0.990420] [TS:25000873152] /bus@0/i2c@810c6a0000/ar0234_n@52: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13
[    0.990425] [TS:25000878096] /bus@0/i2c@810c6a0000/ar0234_m@50: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12
[    0.990430] [TS:25000882837] /bus@0/i2c@810c6a0000/ar0234_l@36: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11
[    0.990434] [TS:25000887134] /bus@0/i2c@810c6a0000/ar0234_k@34: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10
[    0.990438] [TS:25000891069] /bus@0/i2c@810c6a0000/ar0234_j@32: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9
[    0.990442] [TS:25000895263] /bus@0/i2c@810c6a0000/ar0234_i@30: Fixed dependency cycle(s) with /bus@0/host1x@8181[    0.990447] [TS:25000899689] /bus@0/i2c@810c6a0000/ar0234_h@26: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@3
[    0.990451] [TS:25000904115] /bus@0/i2c@810c6a0000/ar0234_g@24: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2
[    0.990455] [TS:25000908319] /bus@0/i2c@810c6a0000/ar0234_f@22: Fixed dependency cycle(s) with /bus@0/host1x@8181[    0.990460] [TS:25000912874] /bus@0/i2c@810c6a0000/ar0234_e@20: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@4
[    0.990465] [TS:25000917902] /bus@0/i2c@810c6a0000/ar0234_b@41: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7
[    0.990469] [TS:25000922041] /bus@0/i2c@810c6a0000/ar0234_a@40: Fixed dependency cycle(s) with /bus@0/host1x@8181[    0.990488] [TS:25000941013] /bus@0/psc@e860000: Fixed dependency cycle(s) with /bus@0/psc@e860000
[    0.991008] [TS:25001460652] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/arad@9870000
[    0.991012] [TS:25001465421] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000
[    0.991017] [TS:25001470161] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000
[    0.991021] [TS:25001473893] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000
[    0.991025] [TS:25001477828] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991029] [TS:25001482180] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000
[    0.991033] [TS:25001485902] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000
[    0.991037] [TS:25001489708] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991041] [TS:25001494180] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000
[    0.991045] [TS:25001497921] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@9590000
[    0.991048] [TS:25001501161] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991052] [TS:25001505050] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9550000
[    0.991055] [TS:25001508272] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9540000
[    0.991059] [TS:25001512448] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991063] [TS:25001515578] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[    0.991066] [TS:25001518828] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9510000
[    0.991069] [TS:25001521985] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991072] [TS:25001525504] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000
[    0.991075] [TS:25001528263] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000
[    0.991079] [TS:25001531800] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991082] [TS:25001534782] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000
[    0.991086] [TS:25001539069] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000
[    0.991090] [TS:25001543282] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991095] [TS:25001547745] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[    0.991099] [TS:25001552022] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect[    0.991107] [TS:25001560152] /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991112] [TS:25001564874] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[    0.991120] [TS:25001572800] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bu[    0.991129] [TS:25001582189] /bus@0/aconnect@9000000/ahub@9630000/amx@9510000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991139] [TS:25001591559] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991148] [TS:25001601476] /bus@0/aconnect@9000000/ahub@9630000/amx@9530000: Fixed dependency cycle(s) with /bu[    0.991157] [TS:25001610309] /bus@0/aconnect@9000000/ahub@9630000/amx@9540000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991168] [TS:25001620939] /bus@0/aconnect@9000000/ahub@9630000/amx@9550000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991177] [TS:25001630208] /bus@0/aconnect@9000000/ahub@9630000/amx@9560000: Fixed dependency cycle(s) with /bu[    0.991186] [TS:25001639467] /bus@0/aconnect@9000000/ahub@9630000/adx@9590000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991197] [TS:25001649559] /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991206] [TS:25001659504] /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000: Fixed dependency cycle(s) with /bu[    0.991215] [TS:25001668495] /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991226] [TS:25001678717] /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991235] [TS:25001687930] /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000: Fixed dependency cycle(s) with /bu[    0.991244] [TS:25001696985] /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991257] [TS:25001710504] /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000: Fixed dependency cycle(s) with /bu[    0.991267] [TS:25001719726] /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991276] [TS:25001729346] /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991286] [TS:25001739013] /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000: Fixed dependency cycle(s) with /bu[    0.991294] [TS:25001747309] /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000: Fixed dependency cyc[    0.991303] [TS:25001756013] /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991311] [TS:25001764384] /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991321] [TS:25001773652] /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991331] [TS:25001784328] /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.991364] [TS:25001817476] /bus@0/aconnect@9000000/ahub@9630000/arad@9870000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[    0.993602] [TS:25004054754] /bus@0/pmc@c800000: Fixed dependency cycle(s) with /bus@0/pmc@c800000/iopad-defaults
[    0.993760] [TS:25004212902] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_p@56
[    0.993765] [TS:25004217865] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_o@54
[    0.993769] [TS:25004221763] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_n@52
[    0.993772] [TS:25004225365] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_m@50
[    0.993776] [TS:25004229309] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_l@36
[    0.993780] [TS:25004232837] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_k@34
[    0.993783] [TS:25004236041] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9: Fixed dependency cycle(s) with [    0.993787] [TS:25004239930] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_i@30
[    0.993792] [TS:25004244893] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_b@41
[    0.993797] [TS:25004250050] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6: Fixed dependency cycle(s) with [    0.993802] [TS:25004255328] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_f@22
[    0.993807] [TS:25004260319] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@4: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_e@20
[    0.993812] [TS:25004265254] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@3: Fixed dependency cycle(s) with [    0.993817] [TS:25004269708] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_g@24
[    0.993821] [TS:25004273791] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@1: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/g2m1@67
[    0.993825] [TS:25004278161] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0: Fixed dependency cycle(s) with [    0.994995] [TS:25005447791] /bus@0/i2c@810c680000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[    0.995112] [TS:25005565013] /bus@0/i2c@810c6a0000/g2m0@66: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0
[    0.995116] [TS:25005568911] /bus@0/i2c@810c6a0000/g2m1@67: Fixed dependency cycle(s) with /bus@0/host1x@81812000[    0.995136] [TS:25005588856] /bus@0/i2c@810c6a0000/ar0234_p@56: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15
[    0.995140] [TS:25005593217] /bus@0/i2c@810c6a0000/ar0234_o@54: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14
[    0.995144] [TS:25005597513] /bus@0/i2c@810c6a0000/ar0234_n@52: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13
[    0.995149] [TS:25005602319] /bus@0/i2c@810c6a0000/ar0234_m@50: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12
[    0.995154] [TS:25005607235] /bus@0/i2c@810c6a0000/ar0234_l@36: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11
[    0.995159] [TS:25005612189] /bus@0/i2c@810c6a0000/ar0234_k@34: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10
[    0.995164] [TS:25005617235] /bus@0/i2c@810c6a0000/ar0234_j@32: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9
[    0.995170] [TS:25005622948] /bus@0/i2c@810c6a0000/ar0234_i@30: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8
[    0.995174] [TS:25005627347] /bus@0/i2c@810c6a0000/ar0234_h@26: Fixed dependency cycle(s) with /bus@0/host1x@8181[    0.995180] [TS:25005632717] /bus@0/i2c@810c6a0000/ar0234_g@24: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2
[    0.995185] [TS:25005638217] /bus@0/i2c@810c6a0000/ar0234_f@22: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5
[    0.995190] [TS:25005643522] /bus@0/i2c@810c6a0000/ar0234_e@20: Fixed dependency cycle(s) with /bus@0/host1x@8181[    0.995196] [TS:25005648893] /bus@0/i2c@810c6a0000/ar0234_b@41: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7
[    0.995201] [TS:25005653717] /bus@0/i2c@810c6a0000/ar0234_a@40: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6
[    1.000934] [TS:25011386976] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.000968] [TS:25011420893] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@1: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.000986] [TS:25011438856] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2: Fixed dependency cycle(s) with [    1.001003] [TS:25011456319] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@3: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001022] [TS:25011474791] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@4: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001040] [TS:25011493282] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5: Fixed dependency cycle(s) with [    1.001058] [TS:25011511439] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001076] [TS:25011529421] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001095] [TS:25011547643] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8: Fixed dependency cycle(s) with [    1.001113] [TS:25011566485] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001131] [TS:25011584421] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001149] [TS:25011602291] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001168] [TS:25011621319] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001188] [TS:25011640837] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001207] [TS:25011660189] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001225] [TS:25011678050] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15: Fixed dependency cycle(s) with /tegra-capture-vi
[    1.001229] [TS:25011682421] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0
[    1.001233] [TS:25011685791] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@818[    1.001237] [TS:25011690143] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2
[    1.001242] [TS:25011694828] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@3
[    1.001245] [TS:25011698393] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@818[    1.001249] [TS:25011701995] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5
[    1.001253] [TS:25011705587] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6
[    1.001256] [TS:25011709078] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@818[    1.001260] [TS:25011712819] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8
[    1.001263] [TS:25011716532] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9
[    1.001269] [TS:25011721624] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10
[    1.001272] [TS:25011725226] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11
[    1.001276] [TS:25011728772] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12
[    1.001280] [TS:25011732624] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13
[    1.001283] [TS:25011736384] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14
[    1.001286] [TS:25011739495] /tegra-capture-vi: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15
[    1.003300] [TS:25013753346] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    1.003305] [TS:25013758522] Modules: 509536 pages in range for PLT usage
[    1.005803] [TS:25016255615] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    1.005804] [TS:25016256587] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    1.005805] [TS:25016257671] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    1.005806] [TS:25016258559] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    1.005807] [TS:25016259717] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    1.005808] [TS:25016260652] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    1.007354] [TS:25017807115] iommu: Default domain type: Translated
[    1.007675] [TS:25018128495] iommu: DMA domain TLB invalidation policy: strict mode
[    1.010354] [TS:25020807217] SCSI subsystem initialized
[    1.010525] [TS:25020978402] usbcore: registered new interface driver usbfs
[    1.010541] [TS:25020994124] usbcore: registered new interface driver hub
[    1.010863] [TS:25021315708] pps_core: LinuxPPS API ver. 1 registeredb
[    1.010864] [TS:25021317115] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.010870] [TS:25021322976] PTP clock support registered
[    1.010915] [TS:25021368467] EDAC MC: Ver: 3.0.0
[    1.011191] [TS:25021643652] ARM FF-A: Firmware version 1.2 found
[    1.011192] [TS:25021644754] ARM FF-A: Firmware version higher than driver version, downgrading
[    1.011612] [TS:25022064967] scmi_core: SCMI protocol bus registered
[    1.011753] [TS:25022205782] efivars: Registered efivars operations
[    1.012180] [TS:25022633235] FPGA manager framework
[    1.012239] [TS:25022692476] Advanced Linux Sound Architecture Driver Initialized.
[    1.014523] [TS:25024976171] vgaarb: loaded
[    1.014949] [TS:25025401717] VFS: Disk quotas dquot_6.6.0cksource arch_sys_counter
[    1.014964] [TS:25025416717] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.017626] [TS:25028079319] audit: type=1400 audit(1.012:2): apparmor="STATUS" info="AppArmor Filesystem Enabled" pid=1 comm="swapper/0"
[    1.017775] [TS:25028227884] NET: Registered PF_INET protocol family
[    1.017867] [TS:25028319569] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.020096] [TS:25030549541] tcp_listen_portaddr_hash hash table entries: 65536 (order: 10, 2621440 bytes, linear)
[    1.021230] [TS:25031683134] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.021245] [TS:25031698254] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    1.022614] [TS:25033067235] TCP bind hash table entries: 65536 (order: 11, 5242880 bytes, linear)
[    1.024179] [TS:25034632356] TCP: Hash tables configured (established 524288 bind 65536)
[    1.027227] [TS:25037679661] UDP-Lite hash table entries: 65536 (order: 11, 6291456 bytes, linear)
[    1.030485] [TS:25040937596] RPC: Registered udp transport module.nsport module.
[    1.030485] [TS:25040938115] RPC: Registered tcp transport module.
[    1.030486] [TS:25040938680] RPC: Registered tcp-with-tls transport module.
[    1.030498] [TS:25040950689] PCI: CLS 0 bytes, default 64backchannel transport module.
[    1.030593] [TS:25041046300] Unpacking initramfs...
[    1.036110] [TS:25046562930] Initialise system trusted keyrings
[    1.036194] [TS:25046647161] workingset: timestamp_bits=42 max_order=25 bucket_order=0
[    1.036432] [TS:25046884985] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.036580] [TS:25047033143] NFS: Registering the id_resolver key type
[    1.036587] [TS:25047039559] Key type id_resolver registered
[    1.036588] [TS:25047040578] Key type id_legacy registered
[    1.036596] [TS:25047049448] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.036601] [TS:25047054319] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.036679] [TS:25047132235] 9p: Installing v9fs 9p2000 file system support
[    1.046288] [TS:25056740652] Key type asymmetric registereditialized
[    1.046321] [TS:25056774476] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    1.046325] [TS:25056777921] io scheduler mq-deadline registered
[    1.046327] [TS:25056780550] io scheduler kyber registered
[    1.046357] [TS:25056810346] io scheduler bfq registered
[    1.072830] [TS:25083282828] msm_serial: driver initializedorts, IRQ sharing enabledtate default
[    1.073171] [TS:25083624337] STM32 USART driver initializedlized
[    1.074231] [TS:25084683680] printk: legacy console [ttyUTC0] enabled
[    1.074578] [TS:25085031309] Virtual UART serial driver init - 8 ports (4 pairs)
[    1.074718] [TS:25085171198] UART port 0 initialized (pair port: 1)orts (4 pairs)
[    1.074798] [TS:25085250661] UART port 1 initialized (pair port: 0)
[    1.074845] [TS:25085298226] UART port 2 initialized (pair port: 3)
[    1.074894] [TS:25085346791] UART port 3 initialized (pair port: 2)
[    1.074939] [TS:25085392541] UART port 4 initialized (pair port: 5)
[    1.074992] [TS:25085444791] UART port 5 initialized (pair port: 4)
[    1.074994] [TS:25085447124] Virtual UART serial driver initialized successfully with 6 ports (4 pairs)
[    1.074997] [TS:25085450115] Port pairs: 0<->1, 2<->3, 4<->5, 6<->7
[    1.075028] [TS:25085480643] Virtual GPS serial driver init5
[    1.075202] [TS:25085655106] Virtual GPS serial driver initialized successfully
[    1.075204] [TS:25085657041] GPS device nodes: /dev/ttyVGPS0 and /dev/ttyVGPS1
[    1.075563] [TS:25086015680] arm-smmu-v3 8105000000.iommu: option nvidia,tegra264-tlbi-race-fix
[    1.075823] [TS:25086275633] arm-smmu-v3 8105000000.iommu: ias 48-bit, oas 48-bit (features 0x000e1faf)qv
[    1.089308] [TS:25099760791] arm-smmu-v3 8105000000.iommu: allocated 65536 entries for cmdq
[    1.093066] [TS:25103519059] arm-smmu-v3 8105000000.iommu: allocated 32768 entries for evtq
[    1.108775] [TS:25119227828] arm-smmu-v3 8105000000.iommu: allocated 65536 entries for vcmdq0
[    1.115808] [TS:25126261569] arm-smmu-v3 8105000000.iommu: allocated 65536 entries for vcmdq1
[    1.115896] [TS:25126349217] arm-smmu-v3 8105000000.iommu: msi_domain absent - falling back to wired irqs
[    1.116220] [TS:25126673476] arm-smmu-v3 8106000000.iommu: option nvidia,tegra264-tlbi-race-fix
[    1.116263] [TS:25126715846] arm-smmu-v3 8106000000.iommu: found companion CMDQV device: 8106200000.cmdqv
[    1.116450] [TS:25126902930] arm-smmu-v3 8106000000.iommu: ias 48-bit, oas 48-bit (features 0x000e1faf)
[    1.120649] [TS:25131101865] arm-smmu-v3 8106000000.iommu: allocated 65536 entries for cmdq
[    1.142699] [TS:25153152448] arm-smmu-v3 8106000000.iommu: allocated 32768 entries for evtq
[    1.153130] [TS:25163582726] arm-smmu-v3 8106000000.iommu: allocated 65536 entries for vcmdq0
[    1.162604] [TS:25173057504] arm-smmu-v3 8106000000.iommu: allocated 65536 entries for vcmdq1
[    1.162680] [TS:25173133578] arm-smmu-v3 8106000000.iommu: msi_domain absent - falling back to wired irqs
[    1.163074] [TS:25173527467] arm-smmu-v3 810a000000.iommu: option nvidia,tegra264-tlbi-race-fix
[    1.163108] [TS:25173561115] arm-smmu-v3 810a000000.iommu: found companion CMDQV device: 810a200000.cmdqv
[    1.163302] [TS:25173754633] arm-smmu-v3 810a000000.iommu: IDR0.COHACC overridden by FW configuration (false)
[    1.163308] [TS:25173761050] arm-smmu-v3 810a000000.iommu: ias 48-bit, oas 48-bit (features 0x000c1eaf)
[    1.172112] [TS:25182565226] arm-smmu-v3 810a000000.iommu: allocated 65536 entries for cmdq
[    1.181505] [TS:25191958513] arm-smmu-v3 810a000000.iommu: allocated 32768 entries for evtq
[    1.203920] [TS:25214372763] arm-smmu-v3 810a000000.iommu: allocated 65536 entries for vcmdq0
[    1.215738] [TS:25226191439] arm-smmu-v3 810a000000.iommu: allocated 65536 entries for vcmdq1
[    1.215814] [TS:25226267022] arm-smmu-v3 810a000000.iommu: msi_domain absent - falling back to wired irqs
[    1.216088] [TS:25226540883] arm-smmu-v3 810b000000.iommu: option nvidia,tegra264-tlbi-race-fix
[    1.216117] [TS:25226570143] arm-smmu-v3 810b000000.iommu: found companion CMDQV device: 810b200000.cmdqv
[    1.216303] [TS:25226755828] arm-smmu-v3 810b000000.iommu: ias 48-bit, oas 48-bit (features 0x000e1faf)
[    1.227217] [TS:25237670541] arm-smmu-v3 810b000000.iommu: allocated 65536 entries for cmdq
[    1.238689] [TS:25249142217] arm-smmu-v3 810b000000.iommu: allocated 32768 entries for evtq
[    1.256200] [TS:25266653559] arm-smmu-v3 810b000000.iommu: allocated 65536 entries for vcmdq0
[    1.264882] [TS:25275334883] arm-smmu-v3 810b000000.iommu: allocated 65536 entries for vcmdq1
[    1.264970] [TS:25275423078] arm-smmu-v3 810b000000.iommu: msi_domain absent - falling back to wired irqs
[    1.265372] [TS:25275825032] arm-smmu-v3 8806000000.iommu: option nvidia,tegra264-tlbi-race-fix
[    1.265407] [TS:25275860291] arm-smmu-v3 8806000000.iommu: found companion CMDQV device: 8806200000.cmdqv
[    1.265759] [TS:25276211782] arm-smmu-v3 8806000000.iommu: IDR0.COHACC overridden by FW configuration (false)
[    1.265766] [TS:25276219069] arm-smmu-v3 8806000000.iommu: ias 48-bit, oas 48-bit (features 0x000c1eaf)
[    1.271965] [TS:25282418004] arm-smmu-v3 8806000000.iommu: allocated 65536 entries for cmdq
[    1.276163] [TS:25286616309] arm-smmu-v3 8806000000.iommu: allocated 32768 entries for evtq
[    1.287977] [TS:25298429809] arm-smmu-v3 8806000000.iommu: allocated 65536 entries for vcmdq0
[    1.295764] [TS:25306217180] arm-smmu-v3 8806000000.iommu: allocated 65536 entries for vcmdq1
[    1.295860] [TS:25306313069] arm-smmu-v3 8806000000.iommu: msi_domain absent - falling back to wired irqs
[    1.308203] [TS:25318655754] loop: module loaded
[    1.309141] [TS:25319594235] megasas: 07.727.03.00-rc1
[    1.314404] [TS:25324857245] thunder_xcv, ver 1.0AP device driver, 1.6
[    1.314432] [TS:25324885245] thunder_bgx, ver 1.0
[    1.314457] [TS:25324910559] nicpf, ver 1.0
[    1.315302] [TS:25325755467] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.315305] [TS:25325758522] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.315372] [TS:25325825374] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.315423] [TS:25325876106] igb: Intel(R) Gigabit Ethernet Network Driveration.
[    1.315426] [TS:25325878643] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.315662] [TS:25326114633] sky2: driver version 1.30 - 2012 Intel Corporation.iver
[    1.316552] [TS:25327004976] VFIO - User Level meta-driver version: 0.3
[    1.318643] [TS:25329096541] usbcore: registered new interface driver usb-storage
[    1.320686] [TS:25331139393] i2c_dev: i2c /dev entries driver
[    1.322142] [TS:25332594717] pps_ldisc: PPS line discipline registered
[    1.326788] [TS:25337240809] sdhci: Secure Digital Host Controller Interface driverlised: dm-devel@redhat.com
[    1.326792] [TS:25337244689] sdhci: Copyright(c) Pierre Ossman
[    1.327884] [TS:25338337133] sdhci-pltfm: SDHCI platform and OF driver helperiver
[    1.329727] [TS:25340180152] SMCCC: SOC_ID: ID = jep106:036b:0264 Revision = 0x00000401
[    1.331359] [TS:25341812569] tegra-bpmp bpmp: firmware: 50c0e47459b794426ee4-b8f4737c39f
[    1.596695] [TS:25607148569] Freeing initrd memory: 21488K
[    5.835432] [TS:29845885188] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    5.835442] [TS:29845895512] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    5.835446] [TS:29845898651] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462[    5.836044] [TS:29846497494] hid: raw HID events driver (C) Jiri Kosina
[    5.837181] [TS:29847634290] xyz_platform_driver simple-device: simple_platform_probe Simple Platform Driver Probe version <0x00>
[    5.837193] [TS:29847646012] xyz_platform_driver simple-device: simple_platform_probe Driver initialized
[    5.837295] [TS:29847748596] power_switch_control_probe: Probing power switch control device
[    5.837298] [TS:29847751494] power-switch-control: Switch count: 24
[    5.837459] [TS:29847912586] Camera device 0 created successfully
[    5.837529] [TS:29847982021] Camera device 1 created successfully
[    5.837604] [TS:29848056790] Camera device 2 created successfully
[    5.837673] [TS:29848126170] Camera device 3 created successfully
[    5.837675] [TS:29848128216] All 4 camera devices created successfully
[    5.837728] [TS:29848180929] GPIO test device 0 created successfully
[    5.837940] [TS:29848392614] All 8 GPIO test devices created successfully
[    5.838031] [TS:29848484077] CAN device 0 created successfullyully
[    5.838067] [TS:29848520577] CAN device 1 created successfully
[    5.838144] [TS:29848597299] CAN device 3 created successfully
[    5.838182] [TS:29848635012] CAN device 4 created successfully
[    5.838225] [TS:29848677975] All 6 CAN devices created successfully
[    5.838275] [TS:29848728244] RS485 CRC node0 created successfully
[    5.838307] [TS:29848760244] RS485 CRC node1 created successfully
[    5.838309] [TS:29848762244] RS485 CRC nodes created successfully
[    5.838360] [TS:29848812864] SPI communication node0 created successfully
[    5.838396] [TS:29848849466] SPI communication node1 created successfully
[    5.838431] [TS:29848884049] SPI communication node2 created successfully
[    5.838434] [TS:29848887234] SPI communication nodes created successfully
[    5.838478] [TS:29848930716] USB HUB node0 created successfully
[    5.838480] [TS:29848933373] USB HUB nodes created successfully
[    5.838549] [TS:29849001753] PHY node switch2 created successfully
[    5.838574] [TS:29849026771] PHY node phy_10g created successfully
[    5.838576] [TS:29849028596] PHY nodes created successfully
[    5.838613] [TS:29849066392] Temperature node MCU domain temperature creation successful
[    5.838643] [TS:29849095892] Temperature node Voltage domain temperature creation successful
[    5.838645] [TS:29849097688] Temperature node creation successful
[    5.839231] [TS:29849683864] Voltage nodes created successfully, total 23 nodes
[    5.839306] [TS:29849758688] SN node PCB-SN create success
[    5.839332] [TS:29849784984] SN node USER-SN create success
[    5.839360] [TS:29849812883] SN node USER-NUMBER create success
[    5.839402] [TS:29849855068] System current nodes created successfully, total 1 nodes
[    5.839405] [TS:29849857623] power_switch_control_probe: Driver loaded successfully
[    5.864120] [TS:29874573364] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    5.866775] [TS:29877227707] optee: revision 4.6 (565c7642)
[    5.870067] [TS:29880519827] optee: initialized driver
[    5.877084] [TS:29887536734] usbcore: registered new interface driver snd-usb-audio
[    5.879123] [TS:29889575808] u32 classifier
[    5.879126] [TS:29889578975]     input device check on
[    5.879128] [TS:29889580883]     Actions configured
[    5.909470] [TS:29919922771] 9pnet: Installing 9P2000 supportol family
[    5.909529] [TS:29919981957] Key type dns_resolver registered
[    5.917607] [TS:29928060299] registered taskstats version 1
[    5.923184] [TS:29933637494] Loading compiled-in X.509 certificates
[    5.925764] [TS:29936217281] Loaded X.509 cert 'Build time autogenerated kernel key: 42057b8a7fb6bcd4d83835fa46a501a253e93244'
[    5.933544] [TS:29943997531] audit: type=1400 audit(5.928:3): apparmor="STATUS" info="AppArmor sha256 policy hash[    5.963415] [TS:29973867957] uart-pl011 810c510000.serial: Adding to iommu group 0
[    5.968312] [TS:29978765364] 202510031746 Line:2997 pl011_probe:
[    5.970595] [TS:29981048345] 810c510000.serial: ttyAMA5 at MMIO 0x810c510000 (irq = 72, base_baud = 0) is a PL011 rev0
[    6.009949] [TS:30020401808] pci-host-generic d0b0000000.pcie:      MEM 0x0020000000..0x0027ffffff -> 0x0020000000
[    6.009968] [TS:30020421197] pci-host-generic d0b0000000.pcie:      MEM 0xd0c0000000..0xd87fffffff -> 0xd0c0000000
[    6.009974] [TS:30020427179] pci-host-generic d0b0000000.pcie:       IO 0xd084000000..0xd0841fffff -> 0x008400000[    6.010058] [TS:30020511586] pci-host-generic d0b0000000.pcie: ECAM at [mem 0xd0b0000000-0xd0bfffffff] for [bus 00-ff]
[    6.115578] [TS:30126031308] pci_bus 0000:00: root bus resource [bus 00-ff]dge to bus 0000:00
[    6.115584] [TS:30126037512] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff]
[    6.115594] [TS:30126046855] pci_bus 0000:00: root bus resource [io  0x0000-0x1fffff] (bus address [0x84000000-0x841fffff])
[    6.115678] [TS:30126131438] pci 0000:00:00.0:   bridge window [mem 0xd0c0000000-0xd0c2ffffff 64bit pref]
[    6.115802] [TS:30126254688] pci 0000:00:00.0: PME# supported from D0 D3hot
[    6.119568] [TS:30130021197] pci 0000:01:00.0: [10de:2b00] type 00 class 0x030200 PCIe Endpoint
[    6.119619] [TS:30130072216] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00ffffff 64bit pref]
[    6.119638] [TS:30130091484] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[    6.119860] [TS:30130313040] pci 0000:01:00.0: VF BAR 0 [mem 0x00000000-0x0007ffff 64bit pref]
[    6.119864] [TS:30130317383] pci 0000:01:00.0: VF BAR 0 [mem 0x00000000-0x01f7ffff 64bit pref]: contains BAR 0 fo[    6.120214] [TS:30130666799] pci 0000:01:00.0: 0.000 Gb/s available PCIe bandwidth, limited by Unknown x0 link at 0000:00:00.0 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[    6.120614] [TS:30131067040] pci 0000:00:00.0: bridge window [mem 0x01000000-0x01ffffff 64bit pref] to [bus 01-ff] add_size 2000000 add_align 1000000
[    6.120628] [TS:30131080808] pci 0000:00:00.0: bridge window [mem 0xd0c0000000-0xd0c2ffffff 64bit pref]: assigned
[    6.120634] [TS:30131086855] pci 0000:01:00.0: BAR 0 [mem 0xd0c0000000-0xd0c0ffffff 64bit pref]: assigned
[    6.120645] [TS:30131097707] pci 0000:01:00.0: VF BAR 0 [mem 0xd0c1000000-0xd0c2f7ffff 64bit pref]: assigned
[    6.120651] [TS:30131104068] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    6.120658] [TS:30131111049] pci 0000:00:00.0:   bridge window [mem 0xd0c0000000-0xd0c2ffffff 64bit pref]
[    6.120665] [TS:30131117697] pci_bus 0000:00: resource 4 [mem 0x20000000-0x27ffffff]
[    6.120669] [TS:30131122003] pci_bus 0000:00: resource 6 [io  0x0000-0x1fffff]87fffffff pref]
[    6.120671] [TS:30131124225] pci_bus 0000:01: resource 2 [mem 0xd0c0000000-0xd0c2ffffff 64bit pref]
[    6.121711] [TS:30132164383] pcieport 0000:00:00.0: Adding to iommu group 1
[    6.123625] [TS:30134078040] pcieport 0000:00:00.0: PME: Signaling with IRQ 125
[    6.128289] [TS:30138742086] tegra-gpcdma 8400000.dma-controller: Adding to iommu group 2
[    6.130198] [TS:30140650651] tegra-gpcdma 8400000.dma-controller: GPC DMA driver register 31 channels
[    6.131027] [TS:30141480077] spi-tegra114 c6c0000.spi: Adding to iommu group 3
[    6.158546] [TS:30168999457] spi-tegra114 810c440000.spi: Adding to iommu group 5
[    6.170350] [TS:30180803383] spi-tegra114 810c450000.spi: Adding to iommu group 6
[    6.184754] [TS:30195207577] tegra_rtc c2c0000.rtc: registered as rtc1
[    6.184767] [TS:30195219651] tegra_rtc c2c0000.rtc: Tegra internal Real Time Clock
[    6.185430] [TS:30195883345] tegra-i2c c600000.i2c: Adding to iommu group 7
[    6.193926] [TS:30204378707] tegra-i2c c610000.i2c: Adding to iommu group 8
[    6.207724] [TS:30218177364] tegra-i2c 810c640000.i2c: Adding to iommu group 10
[    6.222865] [TS:30233317984] tegra-i2c 810c680000.i2c: Adding to iommu group 11
[    6.227424] [TS:30237876790] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[    6.227561] [TS:30238014457] /bus@0/i2c@810c680000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[    6.232114] [TS:30242567086] tegra-i2c 810c6a0000.i2c: Adding to iommu group 12
[    6.236712] [TS:30247164595] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@810c6a0000/max96712_d@69
[    6.236723] [TS:30247176003] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@810c6a0000/max96712_d@69
[    6.236728] [TS:30247181086] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@810c6a0000/max96712_c@6b
[    6.236731] [TS:30247184512] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@810c6a0000/max96712_c@6b
[    6.236735] [TS:30247188058] i2c i2c-9: of_i2c: modalias failure on /bus@0/i2c@810c6a0000/max96712_a@29
[    6.236738] [TS:30247191086] i2c i2c-9: Failed to create I2C device for /bus@0/i2c@810c6a0000/max96712_a@29
[    6.236819] [TS:30247272253] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0: Fixed dependency cycle(s) with [    6.236964] [TS:30247417383] /bus@0/i2c@810c6a0000/g2m0@66: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@0
[    6.237069] [TS:30247521660] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@1: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/g2m1@67
[    6.237126] [TS:30247579225] /bus@0/i2c@810c6a0000/g2m1@67: Fixed dependency cycle(s) with /bus@0/host1x@81812000[    6.237531] [TS:30247983799] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_p@56
[    6.237596] [TS:30248048605] /bus@0/i2c@810c6a0000/ar0234_p@56: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@15
[    6.237762] [TS:30248215160] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_o@54
[    6.237813] [TS:30248265827] /bus@0/i2c@810c6a0000/ar0234_o@54: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@14
[    6.237968] [TS:30248420633] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_n@52
[    6.238027] [TS:30248479901] /bus@0/i2c@810c6a0000/ar0234_n@52: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@13
[    6.238189] [TS:30248642086] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_m@50
[    6.238240] [TS:30248692938] /bus@0/i2c@810c6a0000/ar0234_m@50: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@12
[    6.238400] [TS:30248853373] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_l@36
[    6.238456] [TS:30248909457] /bus@0/i2c@810c6a0000/ar0234_l@36: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@11
[    6.238608] [TS:30249061123] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_k@34
[    6.238659] [TS:30249111929] /bus@0/i2c@810c6a0000/ar0234_k@34: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@10
[    6.238842] [TS:30249295549] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_j@32
[    6.238890] [TS:30249342984] /bus@0/i2c@810c6a0000/ar0234_j@32: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@9
[    6.239028] [TS:30249481031] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8: Fixed dependency cycle(s) with [    6.239076] [TS:30249529262] /bus@0/i2c@810c6a0000/ar0234_i@30: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@8
[    6.239225] [TS:30249678420] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@3: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_h@26
[    6.239272] [TS:30249725410] /bus@0/i2c@810c6a0000/ar0234_h@26: Fixed dependency cycle(s) with /bus@0/host1x@8181[    6.239415] [TS:30249867744] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_g@24
[    6.239463] [TS:30249915808] /bus@0/i2c@810c6a0000/ar0234_g@24: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@2
[    6.239605] [TS:30250058308] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5: Fixed dependency cycle(s) with [    6.239651] [TS:30250104577] /bus@0/i2c@810c6a0000/ar0234_f@22: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@5
[    6.239792] [TS:30250244827] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@4: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_e@20
[    6.239837] [TS:30250289632] /bus@0/i2c@810c6a0000/ar0234_e@20: Fixed dependency cycle(s) with /bus@0/host1x@8181[    6.239973] [TS:30250426327] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7: Fixed dependency cycle(s) with /bus@0/i2c@810c6a0000/ar0234_b@41
[    6.240019] [TS:30250472595] /bus@0/i2c@810c6a0000/ar0234_b@41: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@7
[    6.240158] [TS:30250611040] /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6: Fixed dependency cycle(s) with [    6.240203] [TS:30250656447] /bus@0/i2c@810c6a0000/ar0234_a@40: Fixed dependency cycle(s) with /bus@0/host1x@8181200000/nvcsi@8188000000/channel@6
[    6.245537] [TS:30255989679] tegra-i2c 810c6d0000.i2c: Adding to iommu group 13
[    6.262713] [TS:30273165994] OPP tables missing from DT, EMC frequency scaling disabled
[    6.264200] [TS:30274653114] OPP tables missing from DT, EMC frequency scaling disabled
[    6.264566] [TS:30275019299] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999000 KHz, changing to: 1026000 KHz
[    6.265443] [TS:30275895836] OPP tables missing from DT, EMC frequency scaling disabled
[    6.265521] [TS:30275973947] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 998000 KHz, changing to: 1026000 KHz
[    6.265641] [TS:30276093716] OPP tables missing from DT, EMC frequency scaling disabled
[    6.266487] [TS:30276940327] cpufreq: cpufreq_online: CPU6: Running at unlisted initial frequency: 998000 KHz, changing to: 1026000 KHz
[    6.267448] [TS:30277900882] OPP tables missing from DT, EMC frequency scaling disabled
[    6.267785] [TS:30278238494] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 997000 KHz, changing to: 1026000 KHz
[    6.268595] [TS:30279048040] OPP tables missing from DT, EMC frequency scaling disabled
[    6.269441] [TS:30279893864] cpufreq: cpufreq_online: CPU10: Running at unlisted initial frequency: 998000 KHz, changing to: 1026000 KHz
[    6.270523] [TS:30280976077] OPP tables missing from DT, EMC frequency scaling disabled
[    6.270611] [TS:30281063632] cpufreq: cpufreq_online: CPU12: Running at unlisted initial frequency: 999000 KHz, c[    6.273884] [TS:30284337484] uart-pl011 810c530000.serial: Adding to iommu group 14
[    6.278593] [TS:30289045744] 810c530000.serial: ttyAMA9 at MMIO 0x810c530000 (irq = 175, base_baud = 0) is a PL011 rev0
[    6.279591] [TS:30290043725] uart-pl011 810c540000.serial: Adding to iommu group 15
[    6.284123] [TS:30294576447] 810c540000.serial: ttyAMA10 at MMIO 0x810c540000 (irq = 176, base_baud = 0) is a PL0[    6.284497] [TS:30294950225] reboot-gpio reboot-gpio: reboot_gpio_probe start
[    6.284542] [TS:30294995355] reboot-gpio reboot-gpio: Got rebootctl GPIO: global number = 586
[    6.284786] [TS:30295238938] tegra-xusb-padctl a808680000.padctl: supply avdd-usb not found, using dummy regulator
[    6.284874] [TS:30295327031] tegra-xusb-padctl a808680000.padctl: supply vclamp-usb not found, using dummy regulator
[    6.286819] [TS:30297272355]  usb2-1: supply vbus not found, using dummy regulatorulator
[    6.286880] [TS:30297333216]  usb2-2: supply vbus not found, using dummy regulator
[    6.351939] [TS:30362392494] tegra-xusb a80aa10000.usb: Firmware timestamp: 2025-09-08 05:45:00 UTC, Version: 90.05 release
[    6.351980] [TS:30362433299] tegra-xusb a80aa10000.usb: new USB bus registered, assigned bus number 1
[    6.352820] [TS:30363272901] tegra-xusb a80aa10000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000000810
[    6.353513] [TS:30363966355] tegra-xusb a80aa10000.usb: new USB bus registered, assigned bus number 2
[    6.353531] [TS:30363984197] tegra-xusb a80aa10000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[    6.353641] [TS:30364093642] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    6.353643] [TS:30364096068] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.353646] [TS:30364099290] usb usb1: SerialNumber: a80aa10000.usb021-rt-tegra xhci-hcd
[    6.358820] [TS:30369273549] hub 1-0:1.0: USB hub found
[    6.358864] [TS:30369316799] hub 1-0:1.0: 4 ports detected
[    6.359197] [TS:30369649688] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[    6.359200] [TS:30369652957] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.359202] [TS:30369654762] usb usb2: Product: xHCI Host Controller
[    6.359206] [TS:30369658669] usb usb2: SerialNumber: a80aa10000.usb021-rt-tegra xhci-hcd
[    6.359360] [TS:30369813484] hub 2-0:1.0: USB hub found
[    6.359372] [TS:30369825169] hub 2-0:1.0: 4 ports detected
[    6.363593] [TS:30374046466] irq: IRQ187: trimming hierarchy from :bus@0:pmc@c800000
[    6.367708] [TS:30378161105] input: gpio-keys as /devices/platform/gpio-keys/input/input0146000000-1
[    6.381220] [TS:30391672688] clk: Disabling unused clocks
[    6.680531] [TS:30690983762] ALSA device list:
[    6.680541] [TS:30690993845]   No soundcards found.
[    6.963052] [TS:30973505466] usb 1-4: New USB device found, idVendor=2109, idProduct=2822, bcdDevice= 1.a3
[    6.963062] [TS:30973514873] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.963066] [TS:30973519318] usb 1-4: Manufacturer: VIA Labs, Inc.
[    6.966944] [TS:30977397364] hub 1-4:1.0: USB hub found
[    6.968002] [TS:30978455382] hub 1-4:1.0: 4 ports detected
[    7.083819] [TS:31094272688] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[    7.115224] [TS:31125677225] usb 2-1: LPM exit latency is zeroed, disabling LPM.
[    7.121710] [TS:31132163114] usb 2-1: New USB device found, idVendor=2c7c, idProduct=0801, bcdDevice= 5.04
[    7.121723] [TS:31132175762] usb 2-1: Manufacturer: Quectels: Mfr=1, Product=2, SerialNumber=3
[    7.291842] [TS:31302295503] usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 3 using tegra-xusb
[    7.346495] [TS:31356947725] usb 2-3: New USB device found, idVendor=2109, idProduct=0822, bcdDevice= 1.a3
[    7.346505] [TS:31356958271] usb 2-3: Product: USB3.1 Hub             roduct=2, SerialNumber=0
[    7.346507] [TS:31356960549] usb 2-3: Manufacturer: VIA Labs, Inc.
[    7.353122] [TS:31363576030] hub 2-3:1.0: USB hub found
[    7.354565] [TS:31365018142] hub 2-3:1.0: 4 ports detected
[    8.902667] [TS:32913120539] Freeing unused kernel memory: 11328K
[    8.902969] [TS:32913422188] Run /init as init process
[    8.916510] [TS:32926963549] 202606291657 Checking overlayfs setting...
[    9.012678] [TS:33023131123] Overlayfs is enabled...
[    9.025088] [TS:33035540604] Root device found: PARTUUID=788141ba-c75c-4a2e-aa87-a6c27d46948b
/init: line 614: warning: command substitution: ignored null byte in input
insmod /lib/modules/6.8.12-1021-rt-tegra/updates/drivers/pci/controller/pcie-tegra264.ko
[    9.046666] [TS:33057119188] pcie_tegra264: loading out-of-tree module taints kernel.
[    9.049221] [TS:33059673947] tegra264-pcie a808400000.pcie:      MEM 0x0028000000..0x002fffffff -> 0x0028000000
[    9.049227] [TS:33059679891] tegra264-pcie a808400000.pcie:      MEM 0xa8c0000000..0xb07fffffff -> 0xa8c0000000
[    9.049230] [TS:33059683428] tegra264-pcie a808400000.pcie:       IO 0xa884000000..0xa8841fffff -> 0x0084000000
[    9.049421] [TS:33059874271] tegra264-pcie a808400000.pcie: ECAM at [mem 0xa8b0000000-0xa8bfffffff] for [bus 00-ff]
[    9.049426] [TS:33059879095] xyz Set Wifi_En
[    9.222763] [TS:33233216475] tegra264-pcie a808400000.pcie: PCIe Controller-1 Link is UP (Speed: 3)
[    9.223899] [TS:33234352262] tegra264-pcie a808400000.pcie: PCI host bridge to bus 0001:00
[    9.223914] [TS:33234366669] pci_bus 0001:00: root bus resource [bus 00-ff]
[    9.223920] [TS:33234372771] pci_bus 0001:00: root bus resource [mem 0x28000000-0x2fffffff]
[    9.223927] [TS:33234379808] pci_bus 0001:00: root bus resource [io  0x200000-0x3fffff] (bus address [0x84000000-0x841fffff])
[    9.223960] [TS:33234412882] pci 0001:00:00.0: [10de:22d8] type 01 class 0x060400 PCIe Root Port
[    9.223995] [TS:33234448493] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    9.224174] [TS:33234627345] pci 0001:00:00.0: PME# supported from D0 D3hot
[    9.226531] [TS:33236983687] pci 0001:01:00.0: [17cb:1107] type 00 class 0x028000 PCIe Endpoint
[    9.226614] [TS:33237066641] pci 0001:01:00.0: BAR 0 [mem 0x00000000-0x001fffff 64bit]
[    9.226639] [TS:33237092243] pci 0001:01:00.0: Upstream bridge's Max Payload Size set to 128 (was 512, max 512)
[    9.226832] [TS:33237285317] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold8, max 128)
[    9.226963] [TS:33237416021] pci 0001:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0001:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    9.227144] [TS:33237597039] pci 0001:00:00.0: bridge window [mem 0x28000000-0x281fffff]: assigned
[    9.227147] [TS:33237600271] pci 0001:01:00.0: BAR 0 [mem 0x28000000-0x281fffff 64bit]: assigned
[    9.227170] [TS:33237622928] pci 0001:00:00.0:   bridge window [mem 0x28000000-0x281fffff]
[    9.227179] [TS:33237632354] pci_bus 0001:00: resource 4 [mem 0x28000000-0x2fffffff]
[    9.227181] [TS:33237633836] pci_bus 0001:00: resource 5 [mem 0xa8c0000000-0xb07fffffff pref]
[    9.227182] [TS:33237635150] pci_bus 0001:00: resource 6 [io  0x200000-0x3fffff]
[    9.227184] [TS:33237637539] pci_bus 0001:01: resource 1 [mem 0x28000000-0x281fffff]
[    9.256881] [TS:33267333975] pcieport 0001:00:00.0: PME: Signaling with IRQ 204
[    9.259086] [TS:33269539215] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[    9.262310] [TS:33272763086] pcieport 0001:00:00.0: DPC: enabled with IRQ 190
[    9.262321] [TS:33272773845] pcieport 0001:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    9.262858] [TS:33273311521] tegra264-pcie a808420000.pcie: host bridge /bus@0/pcie@a808420000 ranges:
[    9.262867] [TS:33273319650] tegra264-pcie a808420000.pcie:      MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[    9.262870] [TS:33273323512] tegra264-pcie a808420000.pcie:      MEM 0xb0c0000000..0xb87fffffff -> 0xb0c0000000
[    9.262873] [TS:33273325891] tegra264-pcie a808420000.pcie:       IO 0xb084000000..0xb0841fffff -> 0x0084000000
[    9.263098] [TS:33273551178] tegra264-pcie a808420000.pcie: ECAM at [mem 0xb0b0000000-0xb0bfffffff] for [bus 00-ff]
[   10.270625] [TS:34281078085] tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is DOWN
[   10.270643] [TS:34281095650] tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is DOWN and not hot-plug-capable. Turning off Controller.
[   10.271638] [TS:34282091280] tegra264-pcie a808440000.pcie: host bridge /bus@0/pcie@a808440000 ranges:
[   10.271646] [TS:34282099104] tegra264-pcie a808440000.pcie:      MEM 0x0038000000..0x003fffffff -> 0x0038000000
[   10.271651] [TS:34282104409] tegra264-pcie a808440000.pcie:      MEM 0xb8c0000000..0xc07fffffff -> 0xb8c0000000
[   10.271655] [TS:34282107882] tegra264-pcie a808440000.pcie:       IO 0xb884000000..0xb8841fffff -> 0x0084000000
[   10.271843] [TS:34282296465] tegra264-pcie a808440000.pcie: ECAM at [mem 0xb8b0000000-0xb8bfffffff] for [bus 00-ff]
[   10.379039] [TS:34389492687] tegra264-pcie a808440000.pcie: PCIe Controller-3 Link is UP (Speed: 4)
[   10.380482] [TS:34390935271] tegra264-pcie a808440000.pcie: PCI host bridge to bus 0003:00
[   10.380500] [TS:34390953280] pci_bus 0003:00: root bus resource [bus 00-ff]
[   10.380507] [TS:34390959641] pci_bus 0003:00: root bus resource [mem 0x38000000-0x3fffffff]
[   10.380512] [TS:34390965558] pci_bus 0003:00: root bus resource [io  0x600000-0x7fffff] (bus address [0x84000000-0x841fffff])
[   10.380540] [TS:34390993150] pci 0003:00:00.0: [10de:22da] type 01 class 0x060400 PCIe Root Port
[   10.380573] [TS:34391025817] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[   10.380583] [TS:34391035622] pci 0003:00:00.0:   bridge window [mem 0x38000000-0x380fffff]
[   10.380744] [TS:34391196669] pci 0003:00:00.0: PME# supported from D0 D3hot
[   10.382682] [TS:34393134826] pci 0003:01:00.0: [1344:6004] type 00 class 0x010802 PCIe Endpoint
[   10.382830] [TS:34393283206] pci 0003:01:00.0: BAR 0 [mem 0x38000000-0x38003fff 64bit]
[   10.383127] [TS:34393579771] pci 0003:01:00.0: 31.506 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x2 link at 0003:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[   10.383338] [TS:34393790928] pci 0003:00:00.0:   bridge window [mem 0x38000000-0x380fffff]signeded
[   10.383347] [TS:34393800039] pci_bus 0003:00: resource 4 [mem 0x38000000-0x3fffffff]
[   10.383349] [TS:34393801900] pci_bus 0003:00: resource 5 [mem 0xb8c0000000-0xc07fffffff pref]
[   10.383351] [TS:34393803622] pci_bus 0003:00: resource 6 [io  0x600000-0x7fffff]
[   10.383352] [TS:34393805076] pci_bus 0003:01: resource 1 [mem 0x38000000-0x380fffff]
[   10.409577] [TS:34420029585] pcieport 0003:00:00.0: PME: Signaling with IRQ 220
[   10.412896] [TS:34423348937] pcieport 0003:00:00.0: AER: enabled with IRQ 207
[   10.416147] [TS:34426600104] pcieport 0003:00:00.0: DPC: enabled with IRQ 206
[   10.416158] [TS:34426611261] pcieport 0003:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[   10.416672] [TS:34427125011] tegra264-pcie a808480000.pcie: host bridge /bus@0/pcie@a808480000 ranges:
[   10.416680] [TS:34427133058] tegra264-pcie a808480000.pcie:      MEM 0x0048000000..0x004fffffff -> 0x0048000000
[   10.416685] [TS:34427137650] tegra264-pcie a808480000.pcie:      MEM 0xc8c0000000..0xd07fffffff -> 0xc8c0000000
[   10.416689] [TS:34427142187] tegra264-pcie a808480000.pcie:       IO 0xc884000000..0xc8841fffff -> 0x0084000000
[   10.416909] [TS:34427361706] tegra264-pcie a808480000.pcie: ECAM at [mem 0xc8b0000000-0xc8bfffffff] for [bus 00-ff]
i[   10.574762] [TS:34585214641] tegra264-pcie a808480000.pcie: PCIe Controller-5 Link is UP (Speed: 4)
nsmo[   10.575657] [TS:34586110252] tegra264-pcie a808480000.pcie: PCI host bridge to bus 0005:00
[   10.575666] [TS:34586118752] pci_bus 0005:00: root bus resource [bus 00-ff]
[   10.575671] [TS:34586124437] pci_bus 0005:00: root bus resource [mem 0x48000000-0x4fffffff]
[   10.575674] [TS:34586127261] pci_bus 0005:00: root bus resource [mem 0xc8c0000000-0xd07fffffff pref]
[   10.575677] [TS:34586129734] pci_bus 0005:00: root bus resource [io  0x800000-0x9fffff] (bus address [0x84000000-0x841fffff])
[   10.575752] [TS:34586204965] pci 0005:00:00.0:   bridge window [io  0x0000-0x0fff]0 PCIe Root Port
[   10.575756] [TS:34586208965] pci 0005:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[   10.575768] [TS:34586221474] pci 0005:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[   10.575924] [TS:34586377382] pci 0005:00:00.0: PME# supported from D0 D3hot
[   10.578021] [TS:34588474548] pci 0005:01:00.0: [1e49:1081] type 00 class 0x010802 PCIe Endpoint
[   10.578279] [TS:34588732548] pci 0005:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[   10.578997] [TS:34589449743] pci 0005:00:00.0: bridge window [mem 0x48000000-0x480fffff]: assigned
[   10.578999] [TS:34589451678] pci 0005:01:00.0: BAR 0 [mem 0x48000000-0x48003fff 64bit]: assigned
[   10.579016] [TS:34589468817] pci 0005:00:00.0:   bridge window [mem 0x48000000-0x480fffff]
[   10.579025] [TS:34589477733] pci_bus 0005:00: resource 4 [mem 0x48000000-0x4fffffff]
[   10.579026] [TS:34589479326] pci_bus 0005:00: resource 5 [mem 0xc8c0000000-0xd07fffffff pref]
[   10.605230] [TS:34615683132] pcieport 0005:00:00.0: PME: Signaling with IRQ 236ffff]
[   10.608148] [TS:34618600734] pcieport 0005:00:00.0: AER: enabled with IRQ 223
[   10.611432] [TS:34621884835] pcieport 0005:00:00.0: DPC: enabled with IRQ 222
[   10.611444] [TS:34621896965] pcieport 0005:00:00.0: DPC: error containment capabilities: Int Msg #1, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
b/modules/6.8.12-1021-rt-tegra/updates/drivers/scsi/ufs/ufs-tegra.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/pci/controller/dwc/pcie-tegra194.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/phy/tegra/phy-tegra194-p2u.ko
insmod /lib/mod[   10.899718] [TS:34910171326] nvme 0003:01:00.0: Adding to iommu group 20
[   10.900523] [TS:34910975696] nvme nvme0: pci function 0003:01:00.0
ules/6.8.12-1021-rt-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/nvme/host/[   10.923027] [TS:34933480141] nvme 0005:01:00.0: Adding to iommu group 21
[   10.924182] [TS:34934635335] nvme nvme1: pci function 0005:01:00.0
[   10.924211] [TS:34934664030] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[   10.933787] [TS:34944240326] hwmon hwmon0: temp1_input not attached to any thermal zone
[   10.933840] [TS:34944292604] hwmon hwmon0: temp2_input not attached to any thermal zone
[   10.933867] [TS:34944319696] hwmon hwmon0: temp3_input not attached to any thermal zone
[   10.935697] [TS:34946149937] hwmon hwmon1: temp1_input not attached to any thermal zone
[   10.935763] [TS:34946215891] hwmon hwmon1: temp2_input not attached to any thermal zone
[   10.935796] [TS:34946248937] hwmon hwmon1: temp3_input not attached to any thermal zone
[   10.935822] [TS:34946274733] hwmon hwmon1: temp4_input not attached to any thermal zone
[   10.935846] [TS:34946298696] hwmon hwmon1: temp6_input not attached to any thermal zone
[   10.935869] [TS:34946322011] hwmon hwmon1: temp7_input not attached to any thermal zone
[   10.935893] [TS:34946345650] hwmon hwmon1: temp8_input not attached to any thermal zone
[   10.935916] [TS:34946369030] hwmon hwmon1: temp9_input not attached to any thermal zone
[   10.940860] [TS:34951312678] nvme nvme0: allocated 128 MiB host memory buffer.
[   10.979035] [TS:34989488326] nvme nvme1: 14/0/0 default/read/poll queues
[   11.004778] [TS:35015231150]  nvme1n1: p1 p2 p3 p4fault/read/poll queues
n[   11.026296] [TS:35036749057]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
vme.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/usb/typec/typec.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/usb/typec/ucsi/typec_ucsi.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/usb/typec/ucsi/ucsi_ccg.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/usb/storage/uas.ko
insmod [   11.091602] [TS:35102054687] usbcore: registered new interface driver uas
/lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
[   11.139779] [TS:35150232020] tegra-xudc a808670000.usb: Adding to iommu group 22
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/pwm/pwm-tegra.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/hwmon/pwm-fan.ko
[   11.473269] [TS:35483721817] line number is 321
[   11.473303] [TS:35483755752] line number is 324
[   11.473319] [TS:35483772280] actual_device /dev/nvme0n1p1...
[   11.473361] [TS:35483814280] DEBUG: actual_device is nvme0n1p1, using /dev/nvme0n1p6 for overlay
[   11.473423] [TS:35483875761] line number is 374 for root PARTUUID=788141ba-c75c-4a2e-aa87-a6c27d46948b...
[   11.473606] [TS:35484059409] Pre-mounting file system for overlayfs...
[   11.473642] [TS:35484094678] line number is 82
[   11.473648] [TS:35484101307] Creating /lower directory...
[   11.476619] [TS:35487072372] /lower directory created successfully
[   11.476730] [TS:35487183104] line number is 96
[   11.476739] [TS:35487192539] Creating /upper directory...
[   11.479509] [TS:35489961696] /upper directory created successfully
[   11.479573] [TS:35490025594] line number is 108
[   11.479644] [TS:35490097530] DEBUG: actual_device is nvme0n1p1, using /dev/nvme0n1p6 for overlay
[   11.499939] [TS:35510392372] line number is 153v/nvme0n1p6 found, checking filesystem...
[   11.499967] [TS:35510420530] Partition /dev/nvme0n1p6 is already ext4, mounting...
[   11.618930] [TS:35629382715] EXT4-fs (nvme0n1p6): recovery complete
[   11.619766] [TS:35630218956] EXT4-fs (nvme0n1p6): mounted filesystem be732dc5-d7be-4a62-a2ac-7b5bf3a65ff9 r/w wit[   11.620694] [TS:35631146789] Creating overlay directories if needed...
[   11.621211] [TS:35631663909] /upper/work directory already exists
[   11.621231] [TS:35631684502] line number is 252
[   11.624204] [TS:35634657011] OverlayFS upper layer mounted at /upper:
[   11.627191] [TS:35637644030] /dev/nvme0n1p6 on /upper type ext4 (rw,relatime)
[   11.628356] [TS:35638809113] line number is 264
[   11.628714] [TS:35639166770] line number is 377
[   12.104093] [TS:36114546539] EXT4-fs (nvme0n1p1): mounted filesystem b76d6a5e-a274-4d52-aa44-dbf5a74e10ad ro with ordered data mode. Quota mode: none.
[   12.105234] [TS:36115686807] line number is 383
[   12.109064] [TS:36119517539] line number is 388ned 0
[   12.109121] [TS:36119573733] line number is 422
/mnt/ is a mountpoint
[   12.135680] [TS:36146133233] Rootfs mounted over PARTUUID=788141ba-c75c-4a2e-aa87-a6c27d46948b
[   12.146581] [TS:36157033659] Switching from initrd to actual rootfs
[   12.323590] [TS:36334043520] systemd[1]: System time before build time, advancing clock.
[   12.479348] [TS:36489800566] NET: Registered PF_INET6 protocol family
[   12.482923] [TS:36493376492] Segment Routing with IPv6
[   12.482940] [TS:36493393372] In-situ OAM (IOAM) with IPv6
[   12.529649] [TS:36540102326] systemd[1]: systemd 255.4-1ubuntu8.15 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   12.529669] [TS:36540122085] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 24.04.4 LTS!
[   12.581881] [TS:36592334316] systemd[1]: Hostname set to <tegra-ubuntu>.
[   12.588393] [TS:36598846492] reboot: __do_sys_reboot(730) Restarting system with command '(efault)'
[   12.588414] [TS:36598866705] reboot: __do_sys_reboot(760) reboot system with cmd '0x00000000'
[   12.629885] [TS:36640337585] audit: type=1334 audit(1774359953.300:4): prog-id=1 op=LOAD
[   12.629912] [TS:36640365502] audit: type=1300 audit(1774359953.300:4): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffffd830218 a2=90 a3=0 items=0 ppid=0 pid=1 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="systemd" exe="/usr/lib/systemd/systemd" subj=unconfined key=(null)
[   12.629922] [TS:36640374752] audit: type=1309 audit(1774359953.300:4): argc=2 a0="/sbin/init" a1="2"
[   12.630214] [TS:36640667381] audit: type=1334 audit(1774359953.300:5): prog-id=1 op=UNLOADE2F696E69740032
[   12.630231] [TS:36640684187] audit: type=1300 audit(1774359953.300:5): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff80d9c760 items=0 ppid=0 pid=1 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=[   12.630234] [TS:36640686724] audit: type=1327 audit(1774359953.300:5): proctitle=2F7362696E2F696E69740032
[   12.630537] [TS:36640989733] audit: type=1334 audit(1774359953.300:6): prog-id=2 op=LOAD
[   12.630553] [TS:36641006511] audit: type=1300 audit(1774359953.300:6): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffffd8302b8 a2=90 a3=aaaac68f3d9a items=0 ppid=0 pid=1 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="systemd" exe="/usr/lib/systemd/systemd" subj=unconfined key=(null)
[   12.630556] [TS:36641009039] audit: type=1327 audit(1774359953.300:6): proctitle=2F7362696E2F696E69740032
[   12.643767] [TS:36654219742] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/wa[   12.643820] [TS:36654273465] systemd[1]: Watchdog running with a timeout of 2min.
[   13.271958] [TS:37282411122] systemd[1]: Configuration file /etc/systemd/system/wifi-autoconnect.service is marke[   13.278033] [TS:37288486279] systemd[1]: Configuration file /etc/systemd/system/tigervnc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[   13.401801] [TS:37412254446] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   13.459099] [TS:37469551677] systemd[1]: Configuration file /etc/systemd/system/mgbe-link-check.service is marked[   13.488465] [TS:37498917659] systemd[1]: /etc/systemd/system/nvcpupowerfix.service:37: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting al[   13.585907] [TS:37596360372] systemd[1]: Queued start job for default target multi-user.target.
[  OK  ] Created slice system-modprobe.slice - Slice /system/modprobe.
[  OK  ] Created slice system-serial\x2dget…slice - Slice /system/serial-getty. - Slice /system/modprobe.
[   13.660407] [TS:37670860261] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[  OK  ] Created slice system-systemd\x2dfs…slice - Slice /system/systemd-fsck.
[   13.684432] [TS:37694884705] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[  OK  ] Created slice user.slice - User and Session Slice.
[   13.708147] [TS:37718599631] systemd[1]: Created slice user.slice - User and Session Slice.
[  OK  ] Started systemd-ask-password-wall.…d Requests to Wall Directory Watch.
[   13.731632] [TS:37742085557] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[  OK  ] Set up automount proc-sys-fs-binfm…ormats File System Automount Point.
[   13.755963] [TS:37766416103] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
         Expecting device dev-disk-by\x2dpa…ie-pci-0005:01:00.0-nvme-1-part1...
[   13.779486] [TS:37789938668] systemd[1]: Expecting device dev-disk-by\x2dpath-platform\x2da808480000.pcie\x2dpci\x2d0005:01:00.0\x2dnvme\x2d1\x2dpart1.device - /dev/disk/by-path/platform-a808480000.pcie-pci-0005:01:00.0-nvme-1-part1...
         Expecting device dev-disk-by\x2dpa…ie-pci-0005:01:00.0-nvme-1-part2...
[   13.815430] [TS:37825883390] systemd[1]: Expecting device dev-disk-by\x2dpath-platform\x2da808480000.pcie\x2dpci\x2d0005:01:00.0\x2dnvme\x2d1\x2dpart2.device - /dev/disk/by-path/platform-a808480000.pcie-pci-0005:01:00.0-nvme-1-part2...
         Expecting device dev-disk-by\x2dpa…ie-pci-0005:01:00.0-nvme-1-part3...
[   13.855668] [TS:37866121270] systemd[1]: Expecting device dev-disk-by\x2dpath-platform\x2da808480000.pcie\x2dpci\x2d0005:01:00.0\x2dnvme\x2d1\x2dpart3.device - /dev/disk/by-path/platform-a808480000.pcie-pci-0005:01:00.0-nvme-1-part3...
         Expecting device dev-disk-by\x2dpa…ie-pci-0005:01:00.0-nvme-1-part4...
[   13.891771] [TS:37902224353] systemd[1]: Expecting device dev-disk-by\x2dpath-platform\x2da808480000.pcie\x2dpci\x2d0005:01:00.0\x2dnvme\x2d1\x2dpart4.device - /dev/disk/by-path/platform-a808480000.pcie-pci-0005:01:00.0-nvme-1-part4...
         Expecting device dev-disk-by\x2duu…ce - /dev/disk/by-uuid/9ED2-3333...
[   13.927278] [TS:37937731066] systemd[1]: Expecting device dev-disk-by\x2duuid-9ED2\x2d3333.device - /dev/disk/by-         Expecting device dev-ttyGS0.device - /dev/ttyGS0...
[   13.951619] [TS:37962072224] systemd[1]: Expecting device dev-ttyGS0.device - /dev/ttyGS0...
         Expecting device dev-ttyUTC0.device - /dev/ttyUTC0...
[   13.975736] [TS:37986189409] systemd[1]: Expecting device dev-ttyUTC0.device - /dev/ttyUTC0...
[  OK  ] Reached target integritysetup.targ… Local Integrity Protected Volumes.
[   13.999987] [TS:38010439585] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[  OK  ] Reached target slices.target - Slice Units.
[   14.024073] [TS:38034526020] systemd[1]: Reached target slices.target - Slice Units.
[  OK  ] Reached target snapd.mounts-pre.target - Mounting snaps.
[   14.047706] [TS:38058159233] systemd[1]: Reached target snapd.mounts-pre.target - Mounting snaps.
[  OK  ] Reached target snapd.mounts.target - Mounted snaps.
[   14.071648] [TS:38082101362] systemd[1]: Reached target snapd.mounts.target - Mounted snaps.
[  OK  ] Reached target swap.target - Swaps.
[   14.095692] [TS:38106145492] systemd[1]: Reached target swap.target - Swaps.
[  OK  ] Reached target time-set.target - System Time Set.
[   14.119466] [TS:38129918992] systemd[1]: Reached target time-set.target - System Time Set.
[  OK  ] Reached target veritysetup.target - Local Verity Protected Volumes.
[  OK  ] Listening on rpcbind.socket - RPCbind Server Activation Socket.arget - Local Verity Protected Volumes.
[  OK  ] Listening on syslog.socket - Syslog Socket.g on rpcbind.socket - RPCbind Server Activation Socket.
[   14.240507] [TS:38250960001] systemd[1]: Listening on syslog.socket - Syslog Socket.
[  OK  ] Listening on systemd-fsckd.socket …fsck to fsckd communication Socket.
[   14.256550] [TS:38267002751] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[  OK  ] Listening on systemd-initctl.socke…- initctl Compatibility Named Pipe.
[   14.280244] [TS:38290697436] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[  OK  ] Listening on systemd-journald-dev-…socket - Journal Socket (/dev/log).
[   14.304535] [TS:38314988557] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[  OK  ] Listening on systemd-journald.socket - Journal Socket.
[   14.327976] [TS:38338429186] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[  OK  ] Listening on systemd-networkd.socket - Network Service Netlink Socket.
[   14.352124] [TS:38362577233] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[  OK  ] Listening on systemd-udevd-control.socket - udev Control Socket.
[   14.375453] [TS:38385905585] systemd[1]: systemd-oomd.socket - Userspace Out-Of-Memory (OOM) Killer Socket was sk[   14.375532] [TS:38385985020] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[  OK  ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket.control.socket - udev Control Socket.
[   14.423886] [TS:38434339464] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
         Mounting dev-hugepages.mount - Huge Pages File System...
[   14.487390] [TS:38497842946] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   14.513984] [TS:38524437307] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   14.541492] [TS:38551944890] systemd[1]: Mounting proc-fs-nfsd.mount - NFSD configuration filesystem...
[   14.569961] [TS:38580414112] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   14.597937] [TS:38608389770] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   14.629527] [TS:38639979585] systemd[1]: Starting systemd-journald.service - Journal Service...
[   14.660133] [TS:38670585807] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[   14.663130] [TS:38673582594] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
         Starting key[   14.682054] [TS:38692507214] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   14.683702] [TS:38694154770] systemd-journald[550]: Collecting audit messages is disabled.
         Starting kmod-static-nodes.service…eate List of Static Device Nodes...
[   14.726246] [TS:38736699557] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   14.753864] [TS:38764316992] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   14.771873] [TS:38782325649] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   14.788026] [TS:38798478807] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
         Starting modprobe@efi_pstore.servi… - Load Kernel Module efi_pstore...
[   14.817784] [TS:38828237409] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
Hi mingming,
Are you using the devkit or custom board for Thor?
Is the fan loud after it boots up, or only while it’s booting?
hi:
我们自己做的板子,我们在3840上没问题,升级到3920上之后,在开机的内核阶段有2s左右声音特大,不是必现的
Could you help to clarify if there’s the similar behavior on the devkit?
I think it may be expected as I have the similar experience on Orin Nano devkit.
I would also like to know during which boot stage this occurs.
hi:
我观察在内核5 6s的时候会突然声音特别大,然后后面就好了
到后面加载风扇的驱动接管就好了
[   10.989060] [TS:35121228113] hwmon hwmon1: temp9_input not attached to any thermal zone
[   10.992064] [TS:35124232669] nvme nvme1: allocated 64 MiB host memory buffer.
[   11.045982] [TS:35178150298]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
oller/dwc/pcie-tegra194.ko 178]  nvme1n1: p1 p2 p3 p4
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/nvme/host/nvme.ko
insmo[   11.112626] [TS:35244793928] usbcore: registered new interface driver uas
insmod /lib/modules/6.8.12-1021-rt-tegra/kernel/drivers/usb/gadget/udc/tegra-xudc.ko
[   11.446979] [TS:35579147891] line number is 321
Do you mean that you have resolved the issue after loading the FAM driver during kernel boot?
hi:
是这个意思,在内核加载了ko之后,声音变小了,现在的问题是刚开机声音不大,到内核阶段突然声音很大,我们要解决这个现象,这个硬件在3840上是没问题的,请内部调查下 谢谢!
Is there the similar issue on the devkit so we can check it internally?
Could you also provide the full serial console log with both r38.4 and r39.2?
hi:
R3920的日志看最后一次是声音比较大的,前面都是正常声音。
R3840.log (161.4 KB)
R3920.log (2.2 MB)
[    0.000000] [TS:23534056189] Linux version 6.8.12-1021-rt-tegra (root@VM-16-12-ubuntu) (aarch64-none-linux-gnu-gcc (crosstool-NG 1.26.0) 13.2.0, GNU ld (crosstool-NG 1.26.0) 2.40) #1 SMP PREEMPT_RT Wed Jul 22 10:47:27 CST 2026 ()
Do you enable rt-kernel in your case?
I don’t see the significant error relating to fan in the log you shared.
Do you mean the FAN speed is normal before 5-6s of kernel boot?
Could you try updating the following line in bootloader/tegra264-mb1-bct-pmic-p3834-xxxx-p4071-xxxx.dtsi to check if it could help for your case?
thermal {
    block@0 {
        pwm;
        controller-id = <4>;          /* PWM4: SoC fan */
        source-frq-hz = <27000000>;
        period-ns = <40000>;          /* 25 kHz */
        min-microvolts = <0>;
        max-microvolts = <5000000>;
-        init-microvolts = <2500000>;  /* 50% duty */
+        init-microvolts = <1500000>;  /* 30% duty */
        pwm-clock-enable;
        enable;
hi:
是rt内核
Do you mean the FAN speed is normal before 5-6s of kernel boot?—》是在内核打印的1s-10s 之间声音很大
Could you try updating the following line in bootloader/tegra264-mb1-bct-pmic-p3834-xxxx-p4071-xxxx.dtsi to check if it could help for your case?-----》这里有修改过
当前配置的是
107                 thermal {
108                     /* Program PWM fan which is cvb-specific */
109                     block@0 {
110                         pwm;
111                         controller-id = <4>; /* PWM4 for soc fan */
112                         source-frq-hz = <27000000>; /* OSC clock */
113                         period-ns = <40000>; /* 25 KHz */
114                         min-microvolts = <0>;
115                         max-microvolts = <5000000>;
116                         init-microvolts = <800000>;
117                         pwm-clock-enable;
118                         enable;
119                     };
120                 };
Your configuration in mb1-bct looks good to me.
Have you tried disabling the nvfancontrol service to see if the fan noise persists after booting?
hi:
这样关闭的服务
agi@tegra-ubuntu:~$ sudo systemctl disable nvfancontrol.service
[sudo] password for agi:
Removed "/etc/systemd/system/nv-oobe.target.wants/nvfancontrol.service".
Removed "/etc/systemd/system/multi-user.target.wants/nvfancontrol.service".
agi@tegra-ubuntu:~$
这样测试还是有问题
我理解应该是系统不知道哪里操作了pwm4 突然让风扇声音很大,等到驱动加载之后声音变回正常,并且不是每次都有这个现象,偶尔出现一次,能复测到
I would like to confirm if the nvfancontrol service effectively reduces the fan noise.
Or is the noise reduced by the pwm-fan driver?
That’s why I need you to check the exact timestamp when the fan noise starts.
hi:
I would like to confirm if the nvfancontrol service effectively reduces the fan noise.----》没有改善
Or is the noise reduced by the pwm-fan driver? 对,如果声音特别大,风扇有呼啸声,然后加载驱动就解决了
That’s why I need you to check the exact timestamp when the fan noise starts.----》在内核的1s-6s之间,如果发生的话,开机十次能复现一次
I didn’t notice the similar issue happening on the devkit.
Do you have the devkit to reproduce the similar issue?
hi:
能不能在内核直接读取寄存器,看看这个pwm是不是被配置成其他功能了
Sorry that we don’t provide the register address/map for Thor.
Could you please provide the complete dmesg output and device tree for both releases for further investigation?
Specifically, we only need the boot log from the last boot session for r39.2 (failed) and r38.4 (working).
In addition, please test this on the devkit to confirm if the issue is specific to your custom carrier board.
39.20 log
3920-fan.log (165.7 KB)
dts
extracted_proc.dts.txt (390.6 KB)
R3840 log
3840-fan.log (162.6 KB)
dts
extracted_proc-3840.txt (392.7 KB)
板子没问题,我们在3840上测试了大半年 没发现问题,就是在3920上出现的
