JP7 R38.2.0 how to enable the spi@810c590000 master device
hi:
JP7 R38.2.0 how to enable the spi@810c590000 master device, i want use spi@810c590000 such as master device,in the kernel Which .c file should be used,and How to configure the device tree
1、config the spi@810c590000 node compatible = “nvidia,tegra210-spi”;
use this file kernel/kernel-noble/drivers/spi/spi-tegra114.c
2、pinmux config
                    spi1_sck_pj7 {
                            nvidia,pins = "spi1_sck_pj7";
                            nvidia,function = "spi1_sck";
                            nvidia,pull = <TEGRA_PIN_PULL_UP>;
                            nvidia,tristate = <TEGRA_PIN_DISABLE>;
                            nvidia,enable-input = <TEGRA_PIN_DISABLE>;
                            nvidia,drv-type = <TEGRA_PIN_1X_DRIVER>;
                            nvidia,e-io-od = <TEGRA_PIN_DISABLE>;
                            nvidia,e-lpbk = <TEGRA_PIN_DISABLE>;
                    spi1_miso_pk0 {
                                nvidia,pins = "spi1_miso_pk0";
                                nvidia,function = "spi1_din";
                                nvidia,tristate = <TEGRA_PIN_ENABLE>;
                                nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                        spi1_mosi_pk1 {
                                nvidia,pins = "spi1_mosi_pk1";
                                nvidia,function = "spi1_dout";
                        spi1_cs0_pk2 {
                                nvidia,pins = "spi1_cs0_pk2";
                                nvidia,function = "spi1_cs0";
Please check if this pinmux configuration is correct. Thank you
hi:
I’d like to ask how to adjust the delay between cs and clk
For enabling SPI interface, please check the examples in
Making sure you're not a bot!
To configure delay, you may try to set the properties:
                                nvidia,rx-clk-tap-delay = <0x10>;
                                nvidia,tx-clk-tap-delay = <0x0>;
hi:
The verification has no effect
hi:
Now the test has found that there is a state where the cs signal is pulled up. Please help analyze it. Thank you
As my understanding, the SPI interface has been configured as Master by default.
You can refer to https://elinux.org/Jetson/L4T/peripheral/#Mapping for the mapping of SPI interface on AGX Thor.
It seems you’ve enabled SPI and gotten the signal there.
SPI-CS will de-assert betweeen the transfers.
hi:
It has been solved.
