JP7 r38.2 System crash
hi:
The system will automatically restart and a kernel error has been detected. Please help check the log and optimize it. Thank you
[   13.861343] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx4: initialized (streamid=4358)
[   13.875807] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx5: Adding to iommu group 38
[   13.877151] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx5: initialized (streamid=4359)
[   13.891660] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx6: Adding to iommu group 39
[   13.892715] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx6: initialized (streamid=4360)
[   13.911218] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx7: Adding to iommu group 40
[   13.912384] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx7: initialized (streamid=4361)
[   13.929567] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx8: Adding to iommu group 41
[   13.930794] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx8: initialized (streamid=4353)
[   13.947311] pva_kmd 818c000000.pva0: syncpt_unit_base 81c0000000 syncpt_unit_size 4000000 size 10000
[   13.947332] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx8: PVA syncpt (RO & RW) iova: 78000000, size: 4000000
[   13.947850] Allocated pva->fw_carveout
[   13.953801] nvpva_init completed: 0. GSC boot: 1
[   14.150027] tegra-dce 8808000000.dce: Adding to iommu group 42
[   14.150897] tegra-dce 8808000000.dce: Setting DCE HSP functions for tegra234-dce
[   14.152264] pstore: Using crash dump compression: deflate
[   14.152300] printk: legacy console [ramoops-1] enabled
[   14.152987] pstore: Registered ramoops as persistent store backend
[   14.152990] ramoops: using 0x200000@0x1fbf880000, ecc: 0
[   14.166716] dce: dce_ipc_channel_init_unlocked:248  Invalid Channel State [0x0] for ch_type [2]
[   14.168297] spi-tegra114 810c590000.spi: Adding to iommu group 43
[   14.171865] dce: dce_admin_send_cmd_ver:825  version : dcefw:[0x4] dcekmd:[0x4] err : [0x0]
[   14.172274] dce: dce_admin_setup_clients_ipc:1004 Channel Reset Complete for Type [1] ...
[   14.172282] dce: dce_admin_setup_clients_ipc:980  Get queue info failed for [2]
[   14.174578] dce: dce_admin_setup_clients_ipc:1004 Channel Reset Complete for Type [3] ...
[   14.175433] dce: dce_start_boot_flow:188  DCE_BOOT_DONE
[   14.202297] CAN device driver interface
[   14.232142] nvpps c230000.nvpps: nvpps_probe
[   14.232266] nvpps c230000.nvpps: primary-emac : ethernet@a808a10000
[   14.232309] nvpps c230000.nvpps: ts-capture-interval set to 1000ms
[   14.232331] nvpps c230000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[   14.232335] nvpps c230000.nvpps: Initial operating mode selected as TIMER
[   14.238428] Host1x-Fence: Default interface init done
[   14.239480] nvvrs_pseq 5-003c: NVVRS Vendor ID: 0x9
[   14.239793] nvvrs_pseq 5-003c: NVVRS Model Rev: 0x86
[   14.241212] nvpps c230000.nvpps: nvpps cdev(496:0)
[   14.241247] nvpps nvpps0: Using Lock threshold value(in ns) : 20000
[   14.241267] nvpps c230000.nvpps: tsc_res_ns(1)
[   14.244653] nvvrs_pseq 5-003c: NVVRS PSEQ probe successful
[   14.267112] tegra-hda 88090b0000.hda: Adding to iommu group 44
[   14.267803] irq: IRQ223: trimming hierarchy from :bus@0:pmc@c800000
[   14.267846] lm90 5-004c: supply vcc not found, using dummy regulator
[   14.281973] TT CAN feature is not supported
[   14.281989]   Message RAM Configuration
                | base addr   |0x81102f2000|
                | sidfc_flssa |0x00000000|
                | xidfc_flesa |0x00000040|
                | rxf0c_f0sa  |0x000000c0|
                | rxf1c_f1sa  |0x000009c0|
                | rxbc_rbsa   |0x000009c0|
                | txefc_efsa  |0x000009c0|
                | txbc_tbsa   |0x00000a40|
                | tmc_tmsa    |0x00000ec0|
                | mram size   |0x00001000|
[   14.285336] Release 3.2.3 from 09.06.2018
[   14.289538] hwmon hwmon4: temp1_input not attached to any thermal zone
[   14.289710] hwmon hwmon4: temp2_input not attached to any thermal zone
[   14.296763] at24 1-0050: supply vcc not found, using dummy regulator
[   14.297019] net can0: mttcan device registered (regs=0000000022a3b653, irq=225)
[   14.297229] TT CAN feature is not supported
[   14.297238]   Message RAM Configuration
                | base addr   |0x8110302000|
[   14.297273] at24 1-0050: 256 byte 24c02 EEPROM, read-only
[   14.300531] Release 3.2.3 from 09.06.2018
[   14.304455] imx390 9-0020: tegracam sensor driver:imx390_v2.0.6
[   14.304468] imx390 9-0020: imx390_power_on: power on
[   14.326480] net can1: mttcan device registered (regs=00000000758caa88, irq=226)
[   14.337256] obc_max96712 9-0069: max96712_probe: enter
[   14.337336] obc_max96712 9-0069: max96712_power_off
[   14.337344] imx185 9-0022: probing v4l2 sensor
[   14.337430] TT CAN feature is not supported
[   14.337447]   Message RAM Configuration
                | base addr   |0x8110332000|
[   14.337544] imx185 9-0022: tegracam sensor driver:imx185_v2.0.6
[   14.338262] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx185 9-0022 bound
[   14.339010] max96712 9-002a: max96712_probe: enter
[   14.339130] max96712 9-002a: max96712_power_on: pwdn_gpio = 675
[   14.339624] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c800000
[   14.340722] Release 3.2.3 from 09.06.2018
[   14.341141] net can2: mttcan device registered (regs=0000000096b73c59, irq=227)
[   14.346106] TT CAN feature is not supported
[   14.346121]   Message RAM Configuration
                | base addr   |0x8110342000|
[   14.349342] Release 3.2.3 from 09.06.2018
[   14.361790] net can3: mttcan device registered (regs=000000001dda83e8, irq=229)
[   14.374950] tegra-aocluster bus@0:aocluster@c000000: Tegra AOCLUSTER bus registered
[   14.377392] input: NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/88090b0000.hda/sound/card0/input1
[   14.377552] input: NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/88090b0000.hda/sound/card0/input2
[   14.377713] input: NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/88090b0000.hda/sound/card0/input3
[   14.381955] imx185 9-0022: Detected IMX185 sensor
[   14.381996] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0022
[   14.383482] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/arad@9870000
[   14.383502] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000
[   14.383512] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000
[   14.383521] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000
[   14.383531] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000
[   14.383539] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000
[   14.383548] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000
[   14.383556] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000
[   14.383566] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000
[   14.383575] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@9590000
[   14.383583] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9560000
[   14.383592] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9550000
[   14.383601] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9540000
[   14.383609] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9530000
[   14.383617] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[   14.383625] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9510000
[   14.383635] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000
[   14.383644] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000
[   14.383653] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000
[   14.383662] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000
[   14.383670] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000
[   14.383680] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000
[   14.383692] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[   14.383702] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[   14.383714] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000
[   14.396495] /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.396539] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[   14.410828] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.410856] input: NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/88090b0000.hda/sound/card0/input4
[   14.410900] /bus@0/aconnect@9000000/ahub@9630000/amx@9510000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.410925] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.410943] /bus@0/aconnect@9000000/ahub@9630000/amx@9530000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.410962] /bus@0/aconnect@9000000/ahub@9630000/amx@9540000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.410980] /bus@0/aconnect@9000000/ahub@9630000/amx@9550000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.410998] /bus@0/aconnect@9000000/ahub@9630000/amx@9560000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411018] /bus@0/aconnect@9000000/ahub@9630000/adx@9590000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411037] /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411056] /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411074] /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411091] /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411109] /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.411125] /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430699] /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430731] /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430753] /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430772] /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430792] /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430813] /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430831] /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430849] /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430873] /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.430903] /bus@0/aconnect@9000000/ahub@9630000/arad@9870000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   14.434326] nvethernet a808a10000.ethernet: Adding to iommu group 45
[   14.435973] nvethernet a808a10000.ethernet: Virtualization is not enabled
[   14.435988] nvethernet a808a10000.ethernet: failed to read skip mac reset flag, default 0
[   14.435994] nvethernet a808a10000.ethernet: failed to read MDIO address
[   14.436001] nvethernet a808a10000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[   14.436007] nvethernet a808a10000.ethernet: Failed to read nvida,disable-rx-checksum, so setting to default - rx checksum offload enabled
[   14.436013] nvethernet a808a10000.ethernet: setting to default DMA bit mask
[   14.436418] tegra23x-psc e860000.psc: Adding to iommu group 46
[   14.437241] tegra23x-psc e860000.psc: init done
[   14.439707] thermal-trip-event cpu-throttle-alert: cooling device registered.
[   14.442076] tegra-i2c 810c680000.i2c: I2C transfer timed out
[   14.442246] rt5640 7-001c: Device with ID register 0x0 is not rt5640/39
[   14.446084] max96712 9-002a: max96712_probe:  success
[   14.447454] nvethernet a808a10000.ethernet: failed to read or invalid MDC CR - default to 5
[   14.447578] nvethernet a808a10000.ethernet: failed to get phy reset gpio error: -2
[   14.455568] nvethernet a808a10000.ethernet: Ethernet MAC address: 3c:6d:66:e2:f3:37
[   14.458262] nvethernet a808a10000.ethernet: VM IRQ is handled by Camera CPU: 4
[   14.458387] max96712 9-0029: max96712_probe: enter
[   14.458557] max96712 9-0029: max96712_power_on: pwdn_gpio = 603
[   14.463712] gic 9961000.interrupt-controller: GIC IRQ controller registered
[   14.463763] thermal-trip-event gpu-throttle-alert: cooling device registered.
[   14.464800] thermal-trip-event soc012-throttle-alert: cooling device registered.
[   14.464951] tegra-aconnect bus@0:aconnect@9000000: Tegra ACONNECT bus registered
[   14.470772] thermal-trip-event soc345-throttle-alert: cooling device registered.
[   14.473301] arm_spe_pmu spe-pmu: probed SPEv1.2 for CPUs 0-13 [max_record_sz 64, align 64, features 0x57]
[   14.479795] -->macsec_probe()
[   14.479857] nvethernet a808a10000.ethernet: DT info about vlan in clear is missing setting default-disabled
[   14.479865] -->macsec_get_platform_res()
[   14.493437] <--macsec_get_platform_res()
[   14.493447] -->macsec_enable_car()
[   14.493675] <--macsec_enable_car()
[   14.493712] <--macsec_probe()
[   14.493717] nvethernet a808a10000.ethernet: Macsec: Reduced MTU: 1466 Max: 9000
[   14.496212] ivc-cdev: hypervisor not present
[   14.505076] nvethernet a808a10000.ethernet: mgbe0_0 (HW ver: 42) created with 4 DMA channels
[   14.509406] nvethernet a808b10000.ethernet: Adding to iommu group 47
[   14.509901] nvethernet a808b10000.ethernet: Virtualization is not enabled
[   14.509908] nvethernet a808b10000.ethernet: failed to read skip mac reset flag, default 0
[   14.509914] nvethernet a808b10000.ethernet: failed to read MDIO address
[   14.509921] nvethernet a808b10000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[   14.509926] nvethernet a808b10000.ethernet: Failed to read nvida,disable-rx-checksum, so setting to default - rx checksum offload enabled
[   14.509931] nvethernet a808b10000.ethernet: setting to default DMA bit mask
[   14.515686] nvsciipc nvsciipc: creating nvsciipc_uid sysfs group
[   14.515918] nvsciipc nvsciipc: nvsciipc_uid sysfs group: done
[   14.517513] nvsciipc: loaded module
[   14.517566] nvethernet a808b10000.ethernet: failed to read or invalid MDC CR - default to 5
[   14.517764] nvethernet a808b10000.ethernet: failed to get phy reset gpio error: -2
[   14.522467]  cs_system_cfg: CoreSight Configuration manager initialised
[   14.527235] nvethernet a808b10000.ethernet: Ethernet MAC address: 3c:6d:66:e2:f3:38
[   14.527484] nvethernet a808b10000.ethernet: VM IRQ is handled by Camera CPU: 4
[   14.532477] -->macsec_probe()
[   14.532538] nvethernet a808b10000.ethernet: DT info about vlan in clear is missing setting default-disabled
[   14.532546] -->macsec_get_platform_res()
[   14.534122] tegra-i2c c600000.i2c: I2C transfer timed out
[   14.534435] ina3221 2-0040: Unable to reset device
[   14.534553] ina3221: probe of 2-0040 failed with error -110
[   14.538343] <--macsec_get_platform_res()
[   14.538355] -->macsec_enable_car()
[   14.538571] <--macsec_enable_car()
[   14.538604] <--macsec_probe()
[   14.538609] nvethernet a808b10000.ethernet: Macsec: Reduced MTU: 1466 Max: 9000
[   14.551342] nvethernet a808b10000.ethernet: mgbe1_0 (HW ver: 42) created with 4 DMA channels
[   14.557195] nvethernet a808d10000.ethernet: Adding to iommu group 48
[   14.557983] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   14.558460] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000002008600000,914358272
[   14.558471] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   14.558498] nvmap_page_pool_init: Total RAM pages: 32195939
[   14.558502] nvmap_page_pool_init: nvmap page pool size: 4024492 pages (3432 MB)
[   14.558953] nvethernet a808d10000.ethernet: Virtualization is not enabled
[   14.558966] nvethernet a808d10000.ethernet: failed to read skip mac reset flag, default 0
[   14.558972] nvethernet a808d10000.ethernet: failed to read MDIO address
[   14.558995] nvethernet a808d10000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[   14.558999] nvethernet a808d10000.ethernet: Failed to read nvida,disable-rx-checksum, so setting to default - rx checksum offload enabled
[   14.559008] nvethernet a808d10000.ethernet: setting to default DMA bit mask
[   14.559985] nvmap_heap_create: created heap vpr base 0x0000002008600000 size (892928KiB)
[   14.560059] nvmap_heap_create: fsi :dma coherent mem declare 0x0000001fc4000000,16777216
[   14.560066] nvmap_heap_create: created heap fsi base 0x0000001fc4000000 size (16384KiB)
[   14.560320] nvmap_background_zero_thread: PP zeroing thread starting.
[   14.566078] max96712 9-0029: max96712_probe:  success
[   14.572453] nvethernet a808d10000.ethernet: failed to read or invalid MDC CR - default to 5
[   14.572643] nvethernet a808d10000.ethernet: failed to get phy reset gpio error: -2
[   14.584056] nvethernet a808d10000.ethernet: Ethernet MAC address: 3c:6d:66:e2:f3:39
[   14.584381] nvethernet a808d10000.ethernet: VM IRQ is handled by Camera CPU: 4
[   14.598653] ar0234 9-0036: probing v4l2 sensor.
[   14.598667] ar0234 9-0036: ar0234_probe: chan--nel 3
[   14.598672] ekeechg :d
[   14.598676] ar0234 9-0036: ar0234_probe: sync_sensor = OWL4
[   14.598895] ar0234 9-0036: failed to read pwr_gpio
[   14.599063] ar0234 9-0036: tegracam sensor driver:ar0234_v2.0.6
[   14.599069] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.599074] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.599077] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.599081] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.601101] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.601106] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.601110] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.601114] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.604702] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx390 9-0020 bound
[   14.619182] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0020
[   14.637463] -->macsec_probe()
[   14.637530] nvethernet a808d10000.ethernet: DT info about vlan in clear is missing setting default-disabled
[   14.637538] -->macsec_get_platform_res()
[   14.642129] tegra-i2c c600000.i2c: I2C transfer timed out
[   14.642458] ina238 2-0044: error configuring the device: -110
[   14.647797] <--macsec_get_platform_res()
[   14.647808] -->macsec_enable_car()
[   14.648032] <--macsec_enable_car()
[   14.648068] <--macsec_probe()
[   14.648073] nvethernet a808d10000.ethernet: Macsec: Reduced MTU: 1466 Max: 9000
[   14.664665] nvethernet a808d10000.ethernet: mgbe2_0 (HW ver: 42) created with 4 DMA channels
[   14.674073] nvethernet a808e10000.ethernet: Adding to iommu group 49
[   14.675822] nvethernet a808e10000.ethernet: Virtualization is not enabled
[   14.675835] nvethernet a808e10000.ethernet: failed to read skip mac reset flag, default 0
[   14.675841] nvethernet a808e10000.ethernet: failed to read MDIO address
[   14.675858] nvethernet a808e10000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
[   14.675865] nvethernet a808e10000.ethernet: Failed to read nvida,disable-rx-checksum, so setting to default - rx checksum offload enabled
[   14.675876] nvethernet a808e10000.ethernet: setting to default DMA bit mask
[   14.686780] nvethernet a808e10000.ethernet: failed to read or invalid MDC CR - default to 5
[   14.687055] nvethernet a808e10000.ethernet: failed to get phy reset gpio error: -2
[   14.702176] nvethernet a808e10000.ethernet: Ethernet MAC address: 3c:6d:66:e2:f3:3a
[   14.705616] nvethernet a808e10000.ethernet: VM IRQ is handled by Camera CPU: 4
[   14.706124] ar0234 9-0036: ar0234_write_table: channel 3,
[   14.775974] -->macsec_probe()
[   14.776042] nvethernet a808e10000.ethernet: DT info about vlan in clear is missing setting default-disabled
[   14.776053] -->macsec_get_platform_res()
[   14.783252] <--macsec_get_platform_res()
[   14.783260] -->macsec_enable_car()
[   14.784902] <--macsec_enable_car()
[   14.784947] <--macsec_probe()
[   14.784952] nvethernet a808e10000.ethernet: Macsec: Reduced MTU: 1466 Max: 9000
[   14.802611] nvethernet a808e10000.ethernet: mgbe3_0 (HW ver: 42) created with 4 DMA channels
[   14.818086] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818101] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818107] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818112] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818116] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818119] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818122] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818126] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818131] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818134] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818138] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818141] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.818146] owl_internal_fsync: not matching to any link type 0
[   14.818180] hawk_internal_fsync: not matching to any link type 0
[   14.818201] ar0234 9-0036: ar0234_write_table: channel 3,
[   14.818264] ar0234 9-0036: ar0234_write_table: channel 3,
[   14.818381] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0234 9-0036 bound
[   14.839396] camrtc-coe tegra-capture-coe0: netdev event 5 dev mgbe0_0
[   14.844265] ar0234 9-0036: Detected AR0234 sensor
[   14.844326] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0036
[   14.852609] camrtc-coe tegra-capture-coe0: Ch4->PDMA4
[   14.852701] camrtc-coe tegra-capture-coe0: Ch5->PDMA5
[   14.852774] camrtc-coe tegra-capture-coe0: Ch6->PDMA6
[   14.852840] camrtc-coe tegra-capture-coe0: Ch7->PDMA7
[   14.852979] camrtc-coe tegra-capture-coe0: Ch8->PDMA7
[   14.853182] camrtc-coe tegra-capture-coe0: Camera Over Eth controller a808a10000.ethernet num_chans=5 IRQ=4
[   14.854073] obc_max96712 9-0069: max96712_power_on
[   14.854658] camrtc-coe tegra-capture-coe1: netdev event 5 dev mgbe1_0
[   14.854938] camrtc-coe tegra-capture-coe1: Ch4->PDMA4
[   14.856040] camrtc-coe tegra-capture-coe1: Ch5->PDMA5
[   14.856654] ar0234 9-0034: probing v4l2 sensor.
[   14.856674] ar0234 9-0034: ar0234_probe: chan--nel 2
[   14.856678] ekeechg :c
[   14.856684] ar0234 9-0034: ar0234_probe: sync_sensor = OWL3
[   14.856849] ar0234 9-0034: failed to read pwr_gpio
[   14.857074] debugfs: Directory 'ar0234_e' with parent '/' already present!
[   14.857107] ar0234 9-0034: tegracam sensor driver:ar0234_v2.0.6
[   14.857111] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.857116] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.857120] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.857124] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.859139] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.859143] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.859147] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.859149] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   14.866080] camrtc-coe tegra-capture-coe1: Ch6->PDMA6
[   14.875557] camrtc-coe tegra-capture-coe1: Ch7->PDMA7
[   14.882779] camrtc-coe tegra-capture-coe1: Ch8->PDMA7
[   14.883032] camrtc-coe tegra-capture-coe1: Camera Over Eth controller a808b10000.ethernet num_chans=5 IRQ=4
[   14.885137] camrtc-coe tegra-capture-coe2: netdev event 5 dev mgbe2_0
[   14.891678] camrtc-coe tegra-capture-coe2: Ch4->PDMA4
[   14.901684] camrtc-coe tegra-capture-coe2: Ch5->PDMA5
[   14.915506] camrtc-coe tegra-capture-coe2: Ch6->PDMA6
[   14.925132] camrtc-coe tegra-capture-coe2: Ch7->PDMA7
[   14.933392] camrtc-coe tegra-capture-coe2: Ch8->PDMA7
[   14.933607] camrtc-coe tegra-capture-coe2: Camera Over Eth controller a808d10000.ethernet num_chans=5 IRQ=4
[   14.940057] camrtc-coe tegra-capture-coe3: netdev event 5 dev mgbe3_0
[   14.949060] camrtc-coe tegra-capture-coe3: Ch4->PDMA4
[   14.957485] camrtc-coe tegra-capture-coe3: Ch5->PDMA5
[   14.966077] ar0234 9-0034: ar0234_write_table: channel 2,
[   14.967413] camrtc-coe tegra-capture-coe3: Ch6->PDMA6
[   14.975485] camrtc-coe tegra-capture-coe3: Ch7->PDMA7
[   14.982428] camrtc-coe tegra-capture-coe3: Ch8->PDMA7
[   14.982662] camrtc-coe tegra-capture-coe3: Camera Over Eth controller a808e10000.ethernet num_chans=5 IRQ=4
[   15.064035] obc_max96712 9-0069: check link status: 0x00
[   15.064050] obc_max96712 9-0069: max96712_check_link_lock failed 0
[   15.065401] obc_max96712 9-0069: Serializer i2c address change failed, -1
[   15.079034] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079049] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079053] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079057] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079060] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079064] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079068] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079071] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079075] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079079] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079082] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079086] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.079090] owl_internal_fsync: not matching to any link type 0
[   15.079120] hawk_internal_fsync: not matching to any link type 0
[   15.084271] ar0234 9-0034: ar0234_write_table: channel 2,
[   15.084343] ar0234 9-0034: ar0234_write_table: channel 2,
[   15.084486] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0234 9-0034 bound
[   15.085832] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   15.085984] g300 9-0066: Probing new driver for orbbec camera
[   15.086035] g300 9-0066: supply vcc not found, using dummy regulator
[   15.086249] ar0234 9-0034: Detected AR0234 sensor
[   15.091481] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:00:40 UTC (40)
[   15.095486] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0034
[   15.098189] g300 9-0066: pps-gpios not found 0
[   15.105264] systemd-journald[281]: Time jumped backwards, rotating.
[   15.109763] g300 9-0066: g300 devicetree parse success
[   15.109770] g300 9-0066: camera num 0 no found serialer dev
[   15.111393] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0066
[   15.118832] nvadsp 9d60000.adsp: Adding to iommu group 50
[   15.126205] nvadsp 9d60000.adsp: in probe()...adsp
[   15.126292] g300 9-0067: Probing new driver for orbbec camera
[   15.126343] g300 9-0067: supply vcc not found, using dummy regulator
[   15.126756] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[   15.132760] ar0234 9-0032: probing v4l2 sensor.
[   15.132776] ar0234 9-0032: ar0234_probe: chan--nel 1
[   15.132780] ekeechg :b
[   15.132785] ar0234 9-0032: ar0234_probe: sync_sensor = OWL2
[   15.132912] ar0234 9-0032: failed to read pwr_gpio
[   15.133063] debugfs: Directory 'ar0234_e' with parent '/' already present!
[   15.138414] ar0234 9-0032: tegracam sensor driver:ar0234_v2.0.6
[   15.139535] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.139543] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.139548] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.139552] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.141572] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.141576] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.141580] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.141584] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.146316] /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.172364] g300 9-0067: pps-gpios not found 0
[   15.172398] g300 9-0067: g300 devicetree parse success
[   15.172405] g300 9-0067: camera num 0 no found serialer dev
[   15.183273] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0067
[   15.191409] g300 9-0068: Probing new driver for orbbec camera
[   15.191442] g300 9-0068: supply vcc not found, using dummy regulator
[   15.192560] g300 9-0068: pps-gpios not found 0
[   15.192577] /bus@0/i2c@810c680000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[   15.196668] g300 9-0068: g300 devicetree parse success
[   15.196675] g300 9-0068: camera num 0 no found serialer dev
[   15.199235] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[   15.209911] nvadsp 9d60000.adsp: nvadsp_app_module_probe
[   15.211894] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[   15.226959] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.244552] audit: type=1400 audit(40.648:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=596 comm="apparmor_parser"
[   15.244676] audit: type=1400 audit(40.648:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=600 comm="apparmor_parser"
[   15.246088] ar0234 9-0032: ar0234_write_table: channel 1,
[   15.260425] audit: type=1400 audit(40.648:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=598 comm="apparmor_parser"
[   15.274393] audit: type=1400 audit(40.648:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=603 comm="apparmor_parser"
[   15.274398] audit: type=1400 audit(40.652:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=605 comm="apparmor_parser"
[   15.289499] audit: type=1400 audit(40.684:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=608 comm="apparmor_parser"
[   15.314834] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0068
[   15.327474] audit: type=1400 audit(40.684:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=609 comm="apparmor_parser"
[   15.327482] audit: type=1400 audit(40.684:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=610 comm="apparmor_parser"
[   15.327490] audit: type=1400 audit(40.684:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=612 comm="apparmor_parser"
[   15.327496] audit: type=1400 audit(40.688:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=613 comm="apparmor_parser"
[   15.370061] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383334] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383338] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383344] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383348] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383352] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383356] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383360] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383364] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383368] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383372] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383376] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.383380] owl_internal_fsync: not matching to any link type 0
[   15.389364] hawk_internal_fsync: not matching to any link type 0
[   15.395196] ar0234 9-0032: ar0234_write_table: channel 1,
[   15.395274] ar0234 9-0032: ar0234_write_table: channel 1,
[   15.396065] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0234 9-0032 bound
[   15.398064] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9510000
[   15.409881] /bus@0/aconnect@9000000/ahub@9630000/amx@9510000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.422395] g300 9-0065: Probing new driver for orbbec camera
[   15.422436] g300 9-0065: supply vcc not found, using dummy regulator
[   15.428650] g300 9-0065: pps-gpios not found 0
[   15.428683] g300 9-0065: g300 devicetree parse success
[   15.428691] g300 9-0065: camera num 0 no found serialer dev
[   15.428735] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0065
[   15.430178] ar0234 9-0032: Detected AR0234 sensor
[   15.435006] nvadsp c040000.aon: Adding to iommu group 51
[   15.440533] nvadsp c040000.aon: in probe()...aon
[   15.445582] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0032
[   15.447693] nvadsp c040000.aon: nvadsp_app_module_probe
[   15.449190] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[   15.449354] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.449689] ar0234 9-0030: probing v4l2 sensor.
[   15.449708] ar0234 9-0030: ar0234_probe: chan--nel 0
[   15.449713] ekeechg :a
[   15.449719] ar0234 9-0030: ar0234_probe: sync_sensor = OWL1
[   15.449905] ar0234 9-0030: failed to read pwr_gpio
[   15.450162] debugfs: Directory 'ar0234_e' with parent '/' already present!
[   15.456004] ar0234 9-0030: tegracam sensor driver:ar0234_v2.0.6
[   15.456638] nvadsp 9d60000.adsp1: Adding to iommu group 52
[   15.457799] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9530000
[   15.458223] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.458240] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.458246] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.458250] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.458962] nvadsp 9d60000.adsp1: in probe()...adsp1
[   15.460277] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.460286] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.460290] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.460294] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.460661] /bus@0/aconnect@9000000/ahub@9630000/amx@9530000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.469567] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9540000
[   15.470472] nvadsp 9d60000.adsp1: nvadsp_app_module_probe
[   15.484593] /bus@0/aconnect@9000000/ahub@9630000/amx@9540000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.515721] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9550000
[   15.526932] /bus@0/aconnect@9000000/ahub@9630000/amx@9550000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.547161] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9560000
[   15.550011] /bus@0/aconnect@9000000/ahub@9630000/amx@9560000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.554735] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@9590000
[   15.554832] /bus@0/aconnect@9000000/ahub@9630000/adx@9590000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.557296] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000
[   15.557391] /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.560196] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000
[   15.560537] /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.562912] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000
[   15.563096] /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.564974] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000
[   15.564998] tegra-adma 9440000.dma-controller: Tegra210 ADMA driver registered 64 channels
[   15.565039] /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.566051] ar0234 9-0030: ar0234_write_table: channel 0,
[   15.567167] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000
[   15.567294] /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.570168] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000
[   15.570281] /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.575775] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000
[   15.575865] /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.577350] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000
[   15.577429] /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.579867] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000
[   15.579939] /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.582885] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000
[   15.583290] /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.585244] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000
[   15.585537] /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.587453] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000
[   15.587507] /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.588289] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000
[   15.588481] /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.590633] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000
[   15.590743] /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.592822] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000
[   15.592906] /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.594780] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/arad@9870000
[   15.594849] /bus@0/aconnect@9000000/ahub@9630000/arad@9870000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.674081] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674100] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674105] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674110] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674114] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674119] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674124] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674128] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674133] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674137] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674141] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674145] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.674151] owl_internal_fsync: not matching to any link type 0
[   15.674182] hawk_internal_fsync: not matching to any link type 0
[   15.674205] ar0234 9-0030: ar0234_write_table: channel 0,
[   15.674371] ar0234 9-0030: ar0234_write_table: channel 0,
[   15.679590] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0234 9-0030 bound
[   15.703113] ar0234 9-0030: Detected AR0234 sensor
[   15.707946] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0030
[   15.711732] ar0234 9-0041: probing v4l2 sensor.
[   15.711750] ar0234 9-0041: ar0234_probe: chan--nel 5
[   15.711757] ekeechg :f
[   15.711762] ar0234 9-0041: ar0234_probe: sync_sensor = HAWK1
[   15.711921] ar0234 9-0041: failed to read pwr_gpio
[   15.712156] ar0234 9-0041: tegracam sensor driver:ar0234_v2.0.6
[   15.712168] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.712174] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.712178] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.712182] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.714053] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.714061] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.714065] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.714069] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.747028] tegra210-admaif 9610000.admaif: Adding to iommu group 53
[   15.822054] ar0234 9-0041: ar0234_write_table: channel 5,
[   15.934060] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934076] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934081] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934086] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934090] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934094] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934097] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934101] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934106] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934110] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934114] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934118] ar0234_hawk_link_check: linA=12, linB=0, linC=0, linD=0
[   15.934122] owl_internal_fsync: not matching to any link type 0
[   15.934150] hawk_internal_fsync: not matching to any link type 0
[   15.938766] ar0234 9-0041: ar0234_write_table: channel 5,
[   15.938847] ar0234 9-0041: ar0234_write_table: channel 5,
[   15.938968] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0234 9-0041 bound
[   15.940135] ar0234 9-0041: Detected AR0234 sensor
[   15.943331] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0041
[   15.953404] ar0234 9-0040: probing v4l2 sensor.
[   15.953413] ar0234 9-0040: ar0234_probe: chan--nel 4
[   15.953417] ekeechg :e
[   15.953421] ar0234 9-0040: ar0234_probe: sync_sensor = HAWK1
[   15.953576] ar0234 9-0040: failed to read pwr_gpio
[   15.953706] debugfs: Directory 'ar0234_a' with parent '/' already present!
[   15.960065] ar0234 9-0040: tegracam sensor driver:ar0234_v2.0.6
[   15.960070] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.960075] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.960078] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.960081] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.962045] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.962049] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.962052] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   15.962055] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.070339] ar0234 9-0040: ar0234_write_table: channel 4,
[   16.178346] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178361] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178365] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178369] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178372] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178376] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178379] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178383] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178388] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178391] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178395] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178398] ar0234_hawk_link_check: linA=0, linB=0, linC=0, linD=0
[   16.178403] owl_internal_fsync: not matching to any link type 0
[   16.178437] hawk_internal_fsync: not matching to any link type 0
[   16.178461] ar0234 9-0040: ar0234_write_table: channel 4,
[   16.178550] ar0234 9-0040: ar0234_write_table: channel 4,
[   16.178663] tegra-camrtc-capture-vi tegra-capture-vi: subdev ar0234 9-0040 bound
[   16.179470] ar0234 9-0040: Detected AR0234 sensor
[   16.180990] tegra-nvcsi 8181200000.host1x:nvcsi@8188000000: Failed to create device link (0x180) with 9-0040
[   16.197155] cdi_tsc c230000.tsc_sig_gen: CDI TSC probing...
[   16.197263] ar0234 9-0041: ar0234_open:
[   16.197355] ar0234 9-0030: ar0234_open:
[   16.197432] cdi_tsc c230000.tsc_sig_gen: cdi_tsc_probe: Initializing the driver
[   16.197727] ar0234 9-0032: ar0234_open:
[   16.197893] ar0234 9-0036: ar0234_open:
[   16.198583] ar0234 9-0034: ar0234_open:
[   16.199116] ar0234 9-0040: ar0234_open:
[   16.202436] cdi_tsc c230000.tsc_sig_gen: cdi_tsc_probe: Successfully initialized the tsc char driver
[   16.607738] 8021q: 802.1Q VLAN Support v1.8
[   16.609096] camrtc-coe tegra-capture-coe1: netdev event 27 dev mgbe1_0
[   16.609159] camrtc-coe tegra-capture-coe1: netdev event 22 dev mgbe1_0
[   16.623601] camrtc-coe tegra-capture-coe1: netdev event 27 dev mgbe1_0
[   16.623651] camrtc-coe tegra-capture-coe1: netdev event 22 dev mgbe1_0
[   16.639385] camrtc-coe tegra-capture-coe1: netdev event 27 dev mgbe1_0
[   16.639436] camrtc-coe tegra-capture-coe1: netdev event 22 dev mgbe1_0
[   16.732149] nv_nvsciipc_init.sh[905]: found /dev/nvsciipc
[   16.744011] nvsciipc: nvsciipc_uid is set as 2000
[   16.744069] nv_nvsciipc_init.sh[905]: set 2000 to /sys/devices/platform/nvsciipc/nvsciipc_uid
[   16.746487] loop0: detected capacity change from 0 to 32768
[   16.947427] Mass Storage Function, version: 2009/09/11
[   16.947436] LUN: removable file: (no medium)
[   16.948458] nvidia-nvlink: Nvlink Core is being initialized, major device number 488
[   16.953537] cpufreq: cpu0,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   16.962360] nvidia 0000:01:00.0: Adding to iommu group 54
[   16.964503] nvidia 0000:01:00.0: enabling device (0000 -> 0002)
[   17.008118] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   17.013517] configfs-gadget.l4t gadget.0: HOST MAC 6e:3b:8d:8b:36:ec
[   17.013531] configfs-gadget.l4t gadget.0: MAC 6e:3b:8d:8b:36:ed
[   17.013995] configfs-gadget.l4t gadget.0: HOST MAC 6e:3b:8d:8b:36:ee
[   17.014001] configfs-gadget.l4t gadget.0: MAC 6e:3b:8d:8b:36:ef
[   17.014025] tegra-xudc a808670000.usb: EP 0 (type: ctrl, dir: out) enabled
[   17.019521] l4tbr0: port 1(usb0) entered blocking state
[   17.019537] l4tbr0: port 1(usb0) entered disabled state
[   17.019564] configfs-gadget.l4t gadget.0 usb0: entered allmulticast mode
[   17.019668] configfs-gadget.l4t gadget.0 usb0: entered promiscuous mode
[   17.031435] l4tbr0: port 2(usb1) entered blocking state
[   17.031450] l4tbr0: port 2(usb1) entered disabled state
[   17.031475] configfs-gadget.l4t gadget.0 usb1: entered allmulticast mode
[   17.031655] configfs-gadget.l4t gadget.0 usb1: entered promiscuous mode
[   17.041407] loop0: detected capacity change from 0 to 32768
[   17.336944] loop1: detected capacity change from 0 to 8
[   17.526956] Consider using thermal netlink events interface
[   17.576143] nvsciipc: set_db start
[   17.576177] nvsciipc: set_db done
[   18.547661] nv_platform 8808c00000.display: Adding to iommu group 55
[   18.562059] platform 8808c00000.display:nvdisplay-niso: Adding to iommu group 56
[   18.571952] NVRM: devm_reset_control_get failed, err: -2
[   18.571961] NVRM: devm_reset_control_get failed, err: -2
[   18.571966] NVRM: mipi_cal devm_reset_control_get failed, err: -2
[   18.571988] ------------[ cut here ]------------
[   18.571991] WARNING: CPU: 9 PID: 891 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x194
[   18.572008] Modules linked in: cfg80211(E+) rfkill(E) bridge(E) usb_f_ncm(E) usb_f_mass_storage(E) nvidia(OE+) usb_f_acm(E) u_serial(E) usb_f_rndis(E) u_ether(E) governor_pod_scaling(OE) libcomposite(E) 8021q(E) garp(E) mrp(E) stp(E) llc(E) cam_cdi_tsc(OE) snd_soc_tegra210_mixer(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_arad(OE) snd_soc_tegra_pcm(E) snd_soc_tegra186_asrc(E) snd_soc_tegra210_sfc(E) snd_soc_tegra210_mvc(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_amx(E) snd_soc_tegra210_i2s(E) snd_soc_tegra210_ahub(E) g300(OE) spidev(E) nvadsp(OE) nvvrs_pseq_rtc(OE) tegra210_adma(E) tegra_capture_coe(OE) nv_hawk_owl(OE) nvmap(OE) crct10dif_ce(E) coresight_trbe(E) sm3_ce(E) sm3(E) sha3_ce(E) sha512_ce(E) sha512_arm64(E) nvsciipc(OE) coresight(E) ivc_cdev(OE) snd_soc_tegra_audio_graph_card(E) snd_soc_audio_graph_card(E) arm_spe_pmu(E) snd_soc_simple_card_utils(E) nvpmodel_clk_cap(OE) ina238(E) ina3221(E) tegra234_oc_event(OE) tegra23x_psc(OE) tegra_cactmon_mc_all(OE) thermal_trip_event(OE)
[   18.572087]  nvethernet(OE) tegra_aocluster(OE) snd_soc_rt5640(E) max96712(OE) obc_max9296(OE) nv_imx185(OE) tegra_aconnect(E) snd_hda_codec_hdmi(E) snd_soc_rl6231(E) obc_max96712(OE) nv_imx390(OE) at24(E) mttcan(OE) lm90(E) snd_hda_tegra(E) nvidia_vrs_pseq(OE) snd_hda_codec(E) host1x_fence(OE) nvpps(OE) can_dev(E) snd_hda_core(E) nvidia_cspmu(E) pwm_tegra_tachometer(OE) spi_tegra114(E) tegra264_mc_hwpm(OE) ramoops(E) mc_t26x(OE) tegra_dce(OE) arm_cspmu_module(E) reed_solomon(E) tegra_se(OE) nvhost_nvcsi(OE) nvhost_pva(OE) tegra_se_kds(OE) nvhost_capture(OE) nvhost_vi5(OE) crypto_engine(E) tpm_ftpm_tee(E) camera_diagnostics(OE) nvhost_isp5(OE) tegra_capture_isp(OE) tegra_camera(OE) v4l2_dv_timings(E) host1x_nvhost(OE) tegra_drm(OE) tegra_wmark(OE) nvhwpm(OE) drm_display_helper(E) drm_dp_aux_bus(E) cec(E) drm_kms_helper(E) host1x(OE) tegra_camera_platform(OE) mc_utils(OE) capture_ivc(OE) v4l2_fwnode(E) v4l2_async(E) videobuf2_dma_contig(E) videobuf2_memops(E) videobuf2_v4l2(E) videodev(E) videobuf2_common(E) mc(E)
[   18.572166]  camchar(OE) rtcpu_debug(OE) tegra_camera_rtcpu(OE) ivc_bus(OE) hsp_mailbox_client(OE) nvme_fabrics(E) drm(E) fuse(E) nfsd(E) nfnetlink(E) ip_tables(E) x_tables(E) ipv6(E) pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) uas(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E) phy_tegra194_p2u(E) pcie_tegra194(E) ufs_tegra(OE) pcie_tegra264(OE)
[   18.572202] CPU: 9 PID: 891 Comm: modprobe Tainted: G           OE      6.8.12-rt-tegra #16
[   18.572208] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS r38.2-899cdbc9-dirty 09/28/2025
[   18.572211] pstate: 23400009 (nzCv daif +PAN -UAO +TCO +DIT -SSBS BTYPE=--)
[   18.572217] pc : __reset_control_get_internal+0x68/0x194
[   18.572222] lr : __of_reset_control_get+0x188/0x1c0
[   18.572227] sp : ffff80008c38b5c0
[   18.572229] x29: ffff80008c38b5c0 x28: 0000000000000004 x27: ffff000099a68110
[   18.572235] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000001
[   18.572240] x23: 0000000000000000 x22: ffff000087c4a350 x21: 000000000000001f
[   18.572245] x20: ffff000087c4a370 x19: ffff0000816dd340 x18: 00000000fffffffe
[   18.572250] x17: ffff482f4eb1b000 x16: ffffb7f007ac51c4 x15: ffff80008c38b310
[   18.572255] x14: ffffffffffffffff x13: 0000000000000018 x12: 0101010101010101
[   18.572260] x11: 7f7f7f7f7f7f7f7f x10: ffffbbf00b10ab41 x9 : 0000000000000018
[   18.572265] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 00000080a3f0ef77
[   18.572270] x5 : ffff80008c38b618 x4 : fffffbfffde2d8f4 x3 : 0000000000000001
[   18.572275] x2 : 000000000000001f x1 : 000000000000001f x0 : 0000000000000000
[   18.572280] Call trace:
[   18.572282]  __reset_control_get_internal+0x68/0x194
[   18.572287]  __of_reset_control_get+0x188/0x1c0
[   18.572291]  __reset_control_get+0x48/0x1f4
[   18.572295]  __devm_reset_control_get+0x78/0xe8
[   18.572300]  nv_platform_device_probe+0xaf8/0xd60 [nvidia]
[   18.573281]  platform_probe+0x68/0xc8
[   18.573291]  really_probe+0x148/0x2b0
[   18.573302]  __driver_probe_device+0x78/0x12c
[   18.573312]  driver_probe_device+0x3c/0x15c
[   18.573321]  __driver_attach+0x90/0x19c
[   18.573330]  bus_for_each_dev+0x7c/0xe0
[   18.573339]  driver_attach+0x24/0x30
[   18.573347]  bus_add_driver+0xe4/0x208
[   18.573356]  driver_register+0x5c/0x124
[   18.573359]  __platform_driver_register+0x28/0x34
[   18.573365]  nv_platform_register_driver+0x34/0x40 [nvidia]
[   18.574272]  nvidia_init_module+0x174/0x5a0 [nvidia]
[   18.575135]  do_one_initcall+0x58/0x278
[   18.575144]  do_init_module+0x58/0x1e4
[   18.575153]  load_module+0x1efc/0x1fa8
[   18.575160]  init_module_from_file+0x88/0xcc
[   18.575167]  __arm64_sys_finit_module+0x200/0x3f0
[   18.575174]  invoke_syscall+0x48/0x114
[   18.575184]  el0_svc_common.constprop.0+0x40/0xe0
[   18.575192]  do_el0_svc+0x1c/0x28
[   18.575200]  el0_svc+0x30/0xa8
[   18.575211]  el0t_64_sync_handler+0x120/0x12c
[   18.575215]  el0t_64_sync+0x194/0x198
[   18.575219] ---[ end trace 0000000000000000 ]---
[   18.576050] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64  TempVersion  Release Build  (bugfix_main)  (root@xyz-eai-ThinkStation-K)  2025年 10月 03日 星期五 22:14:18 CST
[   18.587210] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   18.588390] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   18.588790] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   18.778368] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  TempVersion  Release Build  (bugfix_main)  (root@xyz-eai-ThinkStation-K)  2025年 10月 03日 星期五 22:13:49 CST
[   18.843343] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[   18.983311] NET: Registered PF_QIPCRTR protocol family
[   19.971608] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[   19.971633] nvidia 0000:01:00.0: [drm] No compatible format found
[   19.971640] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
[   19.971695] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[   20.237153] nvidia-modeset: WARNING: HW supports 8 heads. Limiting to 4 heads
[   20.237620] nvidia-modeset: WARNING: GPU:0: The head configuration (0xff) is inconsistent with the number of heads (4)
[   21.760493] camrtc-coe tegra-capture-coe0: netdev event 14 dev mgbe0_0
[   21.781037] camrtc-coe tegra-capture-coe0: netdev event 1 dev mgbe0_0
[   21.781119] camrtc-coe tegra-capture-coe0: netdev event 4 dev mgbe0_0
[   21.789140] camrtc-coe tegra-capture-coe1: netdev event 14 dev mgbe1_0
[   21.808873] camrtc-coe tegra-capture-coe1: netdev event 1 dev mgbe1_0
[   21.808888] nvethernet a808b10000.ethernet mgbe1_0: entered promiscuous mode
[   21.809287] camrtc-coe tegra-capture-coe1: netdev event 4 dev mgbe1_0
[   21.818167] camrtc-coe tegra-capture-coe2: netdev event 14 dev mgbe2_0
[   21.838198] camrtc-coe tegra-capture-coe2: netdev event 1 dev mgbe2_0
[   21.844116] camrtc-coe tegra-capture-coe2: netdev event 4 dev mgbe2_0
[   21.844192] camrtc-coe tegra-capture-coe2: netdev event 4 dev mgbe2_0
[   21.852338] camrtc-coe tegra-capture-coe3: netdev event 14 dev mgbe3_0
[   21.866672] nvethernet a808a10000.ethernet mgbe0_0: Link is Up - 10Gbps/Full - flow control off
[   21.872365] camrtc-coe tegra-capture-coe3: netdev event 1 dev mgbe3_0
[   21.872452] camrtc-coe tegra-capture-coe3: netdev event 4 dev mgbe3_0
[   21.918452] nvethernet a808d10000.ethernet mgbe2_0: Link is Up - 10Gbps/Full - flow control off
[   22.006428] nvethernet a808b10000.ethernet mgbe1_0: Link is Up - 10Gbps/Full - flow control off
[   22.017688] camrtc-coe tegra-capture-coe0: netdev event 4 dev mgbe0_0
[   22.020494] camrtc-coe tegra-capture-coe2: netdev event 4 dev mgbe2_0
[   22.021868] camrtc-coe tegra-capture-coe3: netdev event 4 dev mgbe3_0
[   22.084503] [drm] Initialized nvidia-drm 0.0.0 20160202 for 8808c00000.display on minor 2
[   22.084513] [drm] [nvidia-drm] [GPU ID 0x00020000] Invalid framebuffer console info
[   22.151697] vcan: Virtual CAN interface driver
[   22.728357] Console: switching to colour frame buffer device 240x67
[   22.736789] nv_platform 8808c00000.display: [drm] fb0: nvidia-drmdrmfb frame buffer device
[   28.241434] ar0234 9-0030: ar0234_open:
[   28.241468] ar0234 9-0032: ar0234_open:
[   28.241493] ar0234 9-0034: ar0234_open:
[   28.241516] ar0234 9-0036: ar0234_open:
[   28.241539] ar0234 9-0040: ar0234_open:
[   28.241560] ar0234 9-0041: ar0234_open:
[   28.317197] rfkill: input handler disabled
[   28.753091] platform sound: deferred probe pending: tegra-audio-graph-card: parse error
[   31.529792] pwm-tegra-tachometer 810c5c0000.tachometer: Tachometer Overflow is detected
[   68.027199] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[   82.366690] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[   82.658062] tegra-i2c 810c630000.i2c: I2C transfer timed out
[   84.606261] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[   84.811239] cpufreq: cpu0,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.811981] cpufreq: cpu0,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.812652] cpufreq: cpu2,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   84.813298] cpufreq: cpu2,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   84.813949] cpufreq: cpu4,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   84.814604] cpufreq: cpu4,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   84.815281] cpufreq: cpu6,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.815906] cpufreq: cpu6,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.816574] cpufreq: cpu8,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.817204] cpufreq: cpu8,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.817846] cpufreq: cpu10,cur:649000,set:2601000,delta:1952000,set ndiv:289
[   84.818483] cpufreq: cpu10,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   84.819120] cpufreq: cpu12,cur:647000,set:2601000,delta:1954000,set ndiv:289
[   84.819739] cpufreq: cpu12,cur:650000,set:2601000,delta:1951000,set ndiv:289
[   99.173009] tegra-xusb a80aa10000.usb: Firmware timestamp: 2025-03-13 04:47:28 UTC, Version: 90.04 release
[   99.426054] usb 1-4: new high-speed USB device number 2 using tegra-xusb
[   99.580588] hub 1-4:1.0: USB hub found
[   99.581107] hub 1-4:1.0: 5 ports detected
[   99.704762] usb 2-3: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[   99.734221] hub 2-3:1.0: USB hub found
[   99.734849] hub 2-3:1.0: 4 ports detected
[  100.254040] usb 1-4.5: new high-speed USB device number 3 using tegra-xusb
[  115.562688] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  127.906050] nvethernet a808b10000.ethernet: [get_tx_ts][1904][type:0x2][loga-0x15e] Removing stale TS from queue pkt_id
[  144.070498] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[  147.898591] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  147.931566] nvethernet a808b10000.ethernet: [get_tx_ts][1904][type:0x2][loga-0x16e] Removing stale TS from queue pkt_id
[  164.014320] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[  190.906957] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  205.564266] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  248.251190] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  276.518326] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  309.691641] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  329.209961] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  358.346030] rcu: INFO: rcu_sched self-detected stall on CPU
[  358.346037] rcu:     0-....: (5250 ticks this GP) idle=95c4/1/0x4000000000000000 softirq=8747/8747 fqs=2609
[  358.346048] rcu:     (t=5251 jiffies g=15989 q=11727 ncpus=14)
[  358.346054] CPU: 0 PID: 2200 Comm: Xorg Tainted: G        W  OE      6.8.12-rt-tegra #16
[  358.346059] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS r38.2-899cdbc9-dirty 09/28/2025
[  358.346061] pstate: 83400009 (Nzcv daif +PAN -UAO +TCO +DIT -SSBS BTYPE=--)
[  358.346067] pc : __memcpy+0x0/0x250
[  358.346082] lr : vsnprintf+0x2d0/0x6e0
[  358.346091] sp : ffff80008f2fb160
[  358.346093] x29: ffff80008f2fb170 x28: ffffb7efeb741640 x27: 00000000ffffffe8
[  358.346100] x26: ffff80008f2fb2d0 x25: 0000000000000064 x24: ffff80008f2fb214
[  358.346105] x23: ffff80008f2fb2d0 x22: ffff80008f2fb278 x21: 0000000000000008
[  358.346110] x20: ffff80008f2fb214 x19: ffffb7efeb741638 x18: ffffffffffffffff
[  358.346114] x17: 0000000000000000 x16: ffffb7f008416170 x15: ffff80008f2fb0e0
[  358.346119] x14: ffff80008f2fb278 x13: 2e676e6979727465 x12: 72203a6465747075
[  358.346123] x11: 0000000000000000 x10: 0000000000000000 x9 : 0000000000000000
[  358.346128] x8 : ffff80008f2fb278 x7 : 0000000000000000 x6 : 692074696177205d
[  358.346133] x5 : 00000000ffffffe8 x4 : ffffb7efeb741640 x3 : ffffb7efeb741640
[  358.346138] x2 : 0000000000000008 x1 : ffffb7efeb741638 x0 : ffff80008f2fb214
[  358.346142] Call trace:
[  358.346145]  __memcpy+0x0/0x250
[  358.346151]  dce_os_log_msg+0x8c/0x124 [tegra_dce]
[  358.346177]  dce_client_ipc_wait+0xc0/0x188 [tegra_dce]
[  358.346192]  dce_ipc_send_message_sync+0x90/0x288 [tegra_dce]
[  358.346206]  tegra_dce_client_ipc_send_recv+0x94/0x1d0 [tegra_dce]
[  358.346219]  nv_tegra_dce_client_ipc_send_recv+0x38/0x64 [nvidia]
[  358.347075]  dceclientSendRpc_IMPL+0x64/0xe0 [nvidia]
[  358.347899]  _dceRpcIssueAndWait.isra.0+0x80/0x100 [nvidia]
[  358.348660]  rpcRmApiControl_dce+0xc8/0x1b0 [nvidia]
[  358.349399]  rmresControl_Prologue_IMPL+0xb4/0x1c0 [nvidia]
[  358.350178]  resControl_IMPL+0xec/0x1d0 [nvidia]
[  358.350938]  serverControl+0x3b8/0x4a0 [nvidia]
[  358.351681]  _rmapiRmControl+0x474/0x6a0 [nvidia]
[  358.352407]  rmapiControlWithSecInfo+0xa8/0x150 [nvidia]
[  358.353128]  rmapiControlWithSecInfoTls+0x74/0xe0 [nvidia]
[  358.353845]  _nv04ControlWithSecInfo.constprop.0+0x80/0xa0 [nvidia]
[  358.354561]  Nv04ControlKernel+0x50/0x60 [nvidia]
[  358.355276]  nvkms_call_rm+0x58/0x94 [nvidia_modeset]
[  358.355421]  nvRmApiControl+0x50/0x70 [nvidia_modeset]
[  358.355562]  __arm64_sys_ioctl+0xac/0xf0
[  358.355574]  invoke_syscall+0x48/0x114
[  358.355585]  el0_svc_common.constprop.0+0x40/0xe0
[  358.355594]  do_el0_svc+0x1c/0x28
[  358.355602]  el0_svc+0x30/0xa8
[  358.355613]  el0t_64_sync_handler+0x120/0x12c
[  358.355616]  el0t_64_sync+0x194/0x198
[  421.370029] rcu: INFO: rcu_sched self-detected stall on CPU
[  421.370033] rcu:     0-....: (21005 ticks this GP) idle=95c4/1/0x4000000000000000 softirq=8747/8747 fqs=10461
[  421.370042] rcu:     (t=21007 jiffies g=15989 q=37731 ncpus=14)
[  421.370046] CPU: 0 PID: 2200 Comm: Xorg Tainted: G        W  OE      6.8.12-rt-tegra #16
[  421.370051] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS r38.2-899cdbc9-dirty 09/28/2025
[  421.370054] pstate: 03400009 (nzcv daif +PAN -UAO +TCO +DIT -SSBS BTYPE=--)
[  421.370058] pc : prepare_to_wait_event+0x74/0x17c
[  421.370070] lr : dce_wait_cond_wait_interruptible+0x180/0x228 [tegra_dce]
[  421.370092] sp : ffff80008f2fb230
[  421.370094] x29: ffff80008f2fb230 x28: 0000000000000014 x27: ffffb7efecd7ed20
[  421.370099] x26: ffffb7efeb7321f0 x25: ffffb7efeb7321f0 x24: ffffb7efeb733638
[  421.370104] x23: ffff80008f2fb260 x22: 0000000000000000 x21: 0000000000000001
[  421.370109] x20: ffff80008f2fb260 x19: ffffb7efeb733638 x18: ffffffffffffffff
[  421.370113] x17: 0000000000000000 x16: ffffb7f0071b69b8 x15: ffff80008f2fb0e0
[  421.370118] x14: ffff80008f2fb278 x13: 2e676e6979727465 x12: 72203a6465747075
[  421.370122] x11: 0000000000000000 x10: 0000000000000000 x9 : 0000000000000000
[  421.370127] x8 : ffff80008f2fb278 x7 : 747075727265746e x6 : 692074696177205d
[  421.370131] x5 : 0000000000000000 x4 : ffff00008c721240 x3 : ffff80008f2fb278
[  421.370136] x2 : ffff80008f2fb278 x1 : ffff80008f2fb278 x0 : fffffffffffffe00
[  421.370140] Call trace:
[  421.370143]  prepare_to_wait_event+0x74/0x17c
[  421.370149]  dce_wait_cond_wait_interruptible+0x180/0x228 [tegra_dce]
[  421.370163]  dce_client_ipc_wait+0xd4/0x188 [tegra_dce]
[  421.370177]  dce_ipc_send_message_sync+0x90/0x288 [tegra_dce]
[  421.370191]  tegra_dce_client_ipc_send_recv+0x94/0x1d0 [tegra_dce]
[  421.370204]  nv_tegra_dce_client_ipc_send_recv+0x38/0x64 [nvidia]
[  421.371007]  dceclientSendRpc_IMPL+0x64/0xe0 [nvidia]
[  421.371772]  _dceRpcIssueAndWait.isra.0+0x80/0x100 [nvidia]
[  421.372508]  rpcRmApiControl_dce+0xc8/0x1b0 [nvidia]
[  421.373230]  rmresControl_Prologue_IMPL+0xb4/0x1c0 [nvidia]
[  421.373978]  resControl_IMPL+0xec/0x1d0 [nvidia]
[  421.374724]  serverControl+0x3b8/0x4a0 [nvidia]
[  421.375458]  _rmapiRmControl+0x474/0x6a0 [nvidia]
[  421.376178]  rmapiControlWithSecInfo+0xa8/0x150 [nvidia]
[  421.376898]  rmapiControlWithSecInfoTls+0x74/0xe0 [nvidia]
[  421.377609]  _nv04ControlWithSecInfo.constprop.0+0x80/0xa0 [nvidia]
[  421.378314]  Nv04ControlKernel+0x50/0x60 [nvidia]
[  421.379016]  nvkms_call_rm+0x58/0x94 [nvidia_modeset]
[  421.379161]  nvRmApiControl+0x50/0x70 [nvidia_modeset]
[  421.379300]  __arm64_sys_ioctl+0xac/0xf0
[  421.379312]  invoke_syscall+0x48/0x114
[  421.379322]  el0_svc_common.constprop.0+0x40/0xe0
[  421.379331]  do_el0_svc+0x1c/0x28
[  421.379339]  el0_svc+0x30/0xa8
[  421.379348]  el0t_64_sync_handler+0x120/0x12c
[  421.379351]  el0t_64_sync+0x194/0x198
Are you using devkit or custom carrier board?
hi:
we use the custom carrier board.
Hi mingming,
From the log you shared, it seems the stall is caused from DCE.
Do you have custom design about display on your board?
Or do you connect the display currently?
If so, please remove it and check if you would still hit the similar issue.
For this error, please also use r38.2.1 to verify.
hi:
现在系统稳定行很差,以下是导致重启的log,请分析谢谢
Do you have custom design about display on your board? —–》yes
Or do you connect the display currently?——>yes
If so, please remove it and check if you would still hit the similar issue. 我们现在要接显示器测试camera出图的情况,所以说不能拿掉dp接口的显示器
[  387.460654] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[  413.959496] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[  803.558485] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[ 1088.586782] mcf_log_fault: 1011 callbacks suppressed
[ 1088.586794] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff880: EMEM address decode error (EMEM decode error)
[ 1088.586820] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff980: EMEM address decode error (EMEM decode error)
[ 1088.586829] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffa00: EMEM address decode error (EMEM decode error)
[ 1088.586841] hub_log_fault: 952 callbacks suppressed
[ 1088.586844] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586858] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffb00: EMEM address decode error (EMEM decode error)
[ 1088.586869] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586881] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffb00: EMEM address decode error (EMEM decode error)
[ 1088.586891] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586903] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffa80: EMEM address decode error (EMEM decode error)
[ 1088.586913] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586925] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffb80: EMEM address decode error (EMEM decode error)
[ 1088.586933] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffc00: EMEM address decode error (EMEM decode error)
[ 1088.586942] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586954] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffd00: EMEM address decode error (EMEM decode error)
[ 1088.586963] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586976] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffffc00: EMEM address decode error (EMEM decode error)
[ 1088.586984] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.586999] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.587015] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.587030] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[ 1088.596556] arm-smmu-v3 8806000000.iommu: EVTQ overflow detected -- events lost
[ 1088.596563] arm_smmu_evtq_thread: 32758 callbacks suppressed
[ 1088.596566] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596570] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596574] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596578] arm-smmu-v3 8806000000.iommu:    0x0000007ffe324880
[ 1088.596581] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596586] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596589] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596592] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596595] arm-smmu-v3 8806000000.iommu:    0x0000007ffe326880
[ 1088.596598] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596603] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596606] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596609] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596612] arm-smmu-v3 8806000000.iommu:    0x0000007ffe324980
[ 1088.596615] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596620] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596623] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596627] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596630] arm-smmu-v3 8806000000.iommu:    0x0000007ffe328880
[ 1088.596633] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596638] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596641] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596644] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596647] arm-smmu-v3 8806000000.iommu:    0x0000007ffe326980
[ 1088.596650] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596655] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596658] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596661] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596664] arm-smmu-v3 8806000000.iommu:    0x0000007ffe32a880
[ 1088.596667] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596672] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596675] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596678] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596681] arm-smmu-v3 8806000000.iommu:    0x0000007ffe32c880
[ 1088.596684] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596689] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596692] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596695] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596698] arm-smmu-v3 8806000000.iommu:    0x0000007ffe328980
[ 1088.596701] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596705] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596708] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596711] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596714] arm-smmu-v3 8806000000.iommu:    0x0000007ffe32e880
[ 1088.596717] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1088.596722] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[ 1088.596725] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[ 1088.596728] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[ 1088.596731] arm-smmu-v3 8806000000.iommu:    0x0000007ffe32a980
[ 1088.596734] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[ 1130.318015] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[ 1149.058005] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[ 1401.981799] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[ 1490.021755] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[ 1544.613406] rcu: INFO: rcu_sched self-detected stall on CPU
[ 1544.613413] rcu:     0-....: (5249 ticks this GP) idle=25f4/1/0x4000000000000000 softirq=72662/72662 fqs=2612
[ 1544.613425] rcu:     (t=5250 jiffies g=249561 q=14613 ncpus=14)
[ 1544.613431] CPU: 0 PID: 3572 Comm: Xorg Tainted: G        W  OE      6.8.12-rt-tegra #3
[ 1544.613437] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS r38.2-899cdbc9-dirty 09/28/2025
[ 1544.613439] pstate: 23400009 (nzCv daif +PAN -UAO +TCO +DIT -SSBS BTYPE=--)
[ 1544.613445] pc : vsnprintf+0x31c/0x6e0
[ 1544.613461] lr : vsnprintf+0x2d0/0x6e0
[ 1544.613468] sp : ffff800086102a80
[ 1544.613470] x29: ffff800086102a90 x28: ffffb5ad9df5765f x27: 00000000fffffff0
[ 1544.613477] x26: ffff800086102bf0 x25: 0000000000000064 x24: ffff800086102b34
[ 1544.613483] x23: ffff800086102bf0 x22: ffff800086102b98 x21: 000000000000001d
[ 1544.613488] x20: ffff800086102b5a x19: ffffb5ad9df5765f x18: ffffffffffffffff
[ 1544.613492] x17: 0000000000000000 x16: ffffb5adc70b6170 x15: ffff800086102a00
[ 1544.613497] x14: ffff800086102b98 x13: 2e676e6979727465 x12: 72203a6465747075
[ 1544.613502] x11: 0000000000000000 x10: 0000000200000600 x9 : 0000000000000000
[ 1544.613507] x8 : ffff800086102b98 x7 : 747075727265746e x6 : 692074696177205d
[ 1544.613513] x5 : ffff800086102b5a x4 : ffffb5ad9df5765f x3 : ffffb5ad9df5765f
[ 1544.613517] x2 : 000000000000001d x1 : 0000000000000000 x0 : 0000000000000026
[ 1544.613523] Call trace:
[ 1544.613525]  vsnprintf+0x31c/0x6e0
[ 1544.613533]  dce_os_log_msg+0x8c/0x124 [tegra_dce]
[ 1544.613559]  dce_client_ipc_wait+0xc0/0x188 [tegra_dce]
[ 1544.613574]  dce_ipc_send_message_sync+0x90/0x288 [tegra_dce]
[ 1544.613589]  tegra_dce_client_ipc_send_recv+0x94/0x1d0 [tegra_dce]
[ 1544.613602]  nv_tegra_dce_client_ipc_send_recv+0x38/0x64 [nvidia]
[ 1544.614460]  dceclientSendRpc_IMPL+0x64/0xe0 [nvidia]
[ 1544.615282]  _dceRpcIssueAndWait.isra.0+0x80/0x100 [nvidia]
[ 1544.616037]  rpcRmApiControl_dce+0xc8/0x1b0 [nvidia]
[ 1544.616767]  rmresControl_Prologue_IMPL+0xb4/0x1c0 [nvidia]
[ 1544.617541]  resControl_IMPL+0xec/0x1d0 [nvidia]
[ 1544.618304]  serverControl+0x3b8/0x4a0 [nvidia]
[ 1544.619051]  _rmapiRmControl+0x474/0x6a0 [nvidia]
[ 1544.619788]  rmapiControlWithSecInfo+0xa8/0x150 [nvidia]
[ 1544.620523]  rmapiControlWithSecInfoTls+0x74/0xe0 [nvidia]
[ 1544.621260]  _nv04ControlWithSecInfo.constprop.0+0x80/0xa0 [nvidia]
[ 1544.621994]  Nv04ControlKernel+0x50/0x60 [nvidia]
[ 1544.622729]  nvkms_call_rm+0x58/0x94 [nvidia_modeset]
[ 1544.622875]  nvRmApiControl+0x50/0x70 [nvidia_modeset]
[ 1544.623016]  __arm64_sys_ioctl+0xac/0xf0
[ 1544.623030]  invoke_syscall+0x48/0x114
[ 1544.623041]  el0_svc_common.constprop.0+0x40/0xe0
[ 1544.623050]  do_el0_svc+0x1c/0x28
[ 1544.623058]  el0_svc+0x30/0xa8
[ 1544.623070]  el0t_64_sync_handler+0x120/0x12c
[ 1544.623074]  el0t_64_sync+0x194/0x198
[ 1607.625351] rcu: INFO: rcu_sched self-detected stall on CPU
[ 1607.625356] rcu:     0-....: (21001 ticks this GP) idle=25f4/1/0x4000000000000000 softirq=72662/72662 fqs=10476
[ 1607.625365] rcu:     (t=21003 jiffies g=249561 q=49111 ncpus=14)
[ 1607.625370] CPU: 0 PID: 3572 Comm: Xorg Tainted: G        W  OE      6.8.12-rt-tegra #3
[ 1607.625375] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS r38.2-899cdbc9-dirty 09/28/2025
[ 1607.625377] pstate: a3400009 (NzCv daif +PAN -UAO +TCO +DIT -SSBS BTYPE=--)
[ 1607.625382] pc : number+0x18/0x3bc
[ 1607.625392] lr : vsnprintf+0x444/0x6e0
[ 1607.625399] sp : ffff800086102a00
[ 1607.625400] x29: ffff800086102a90 x28: ffffb5ad9df57642 x27: 00000000fffffff0
[ 1607.625407] x26: ffff800086102bf0 x25: 0000000000000064 x24: ffff800086102b34
[ 1607.625411] x23: ffff800086102bf0 x22: ffff800086102b98 x21: 0000000000000002
[ 1607.625416] x20: ffff800086102b3c x19: ffffb5ad9df57640 x18: ffffffffffffffff
[ 1607.625421] x17: 0000000000000000 x16: ffffb5adc70b6170 x15: ffff800086102a00
[ 1607.625425] x14: ffff800086102b98 x13: ffff800086102b3c x12: 72203a6465747075
[ 1607.625430] x11: 0000000000000000 x10: 0000000200000600 x9 : 0000000000000000
[ 1607.625435] x8 : ffff800086102b98 x7 : 5b20746e65696c43 x6 : 5b20746e65696c43
[ 1607.625440] x5 : ffff800086102b3c x4 : ffff000096e15b40 x3 : ffff0a00ffffff0f
[ 1607.625445] x2 : 0000000000000000 x1 : ffff800086102b98 x0 : ffff800086102b3c
[ 1607.625450] Call trace:
[ 1607.625452]  number+0x18/0x3bc
[ 1607.625458]  dce_os_log_msg+0x8c/0x124 [tegra_dce]
[ 1607.625481]  dce_client_ipc_wait+0xc0/0x188 [tegra_dce]
[ 1607.625497]  dce_ipc_send_message_sync+0x90/0x288 [tegra_dce]
[ 1607.625511]  tegra_dce_client_ipc_send_recv+0x94/0x1d0 [tegra_dce]
[ 1607.625525]  nv_tegra_dce_client_ipc_send_recv+0x38/0x64 [nvidia]
[ 1607.626323]  dceclientSendRpc_IMPL+0x64/0xe0 [nvidia]
[ 1607.627077]  _dceRpcIssueAndWait.isra.0+0x80/0x100 [nvidia]
[ 1607.627808]  rpcRmApiControl_dce+0xc8/0x1b0 [nvidia]
[ 1607.628525]  rmresControl_Prologue_IMPL+0xb4/0x1c0 [nvidia]
[ 1607.629271]  resControl_IMPL+0xec/0x1d0 [nvidia]
[ 1607.630014]  serverControl+0x3b8/0x4a0 [nvidia]
[ 1607.630744]  _rmapiRmControl+0x474/0x6a0 [nvidia]
[ 1607.631467]  rmapiControlWithSecInfo+0xa8/0x150 [nvidia]
[ 1607.632187]  rmapiControlWithSecInfoTls+0x74/0xe0 [nvidia]
[ 1607.632903]  _nv04ControlWithSecInfo.constprop.0+0x80/0xa0 [nvidia]
[ 1607.633625]  Nv04ControlKernel+0x50/0x60 [nvidia]
[ 1607.634335]  nvkms_call_rm+0x58/0x94 [nvidia_modeset]
[ 1607.634475]  nvRmApiControl+0x50/0x70 [nvidia_modeset]
[ 1607.634613]  __arm64_sys_ioctl+0xac/0xf0
[ 1607.634626]  invoke_syscall+0x48/0x114
[ 1607.634639]  el0_svc_common.constprop.0+0x40/0xe0
[ 1607.634647]  do_el0_svc+0x1c/0x28
[ 1607.634655]  el0_svc+0x30/0xa8
[ 1607.634666]  el0t_64_sync_handler+0x120/0x12c
[ 1607.634669]  el0t_64_sync+0x194/0x198
I just want to clarify the cause of the issue.
There’re memory decode errors which causes IOMMU error and the system stall at the end.
Please help to clarify what customization on your board may lead to this issue.
Or could you reproduce the similar issue on the devkit?
Have you also verified this?
hi:
It was caused by plugging and unplugging the monitor
[  285.581841] nvethernet a808b10000.ethernet: [get_tx_ts][1904][type:0x2][loga-0xfd] Removing stale TS from queue pkt_id
[  301.798416] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[  305.594247] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  317.937889] nvethernet a808b10000.ethernet: [get_tx_ts][1904][type:0x2][loga-0x171] Removing stale TS from queue pkt_id
[  330.572457] NVRM: nvAssertFailed: Assertion failed: 0 @ g_kern_bus_nvoc.h:2706
[  332.903356] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.418696] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff080: EMEM address decode error (EMEM decode error)
[  333.418718] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418740] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff200: EMEM address decode error (EMEM decode error)
[  333.418759] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff200: EMEM address decode error (EMEM decode error)
[  333.418768] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418781] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff280: EMEM address decode error (EMEM decode error)
[  333.418790] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418801] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff280: EMEM address decode error (EMEM decode error)
[  333.418810] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418821] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff400: EMEM address decode error (EMEM decode error)
[  333.418829] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff380: EMEM address decode error (EMEM decode error)
[  333.418838] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418849] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff500: EMEM address decode error (EMEM decode error)
[  333.418859] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418870] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff400: EMEM address decode error (EMEM decode error)
[  333.418880] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418892] tegra-mc 8108020000.memory-controller: dispr: non-secure read @0x0000fffffffff580: EMEM address decode error (EMEM decode error)
[  333.418902] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418919] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.418936] tegra-mc 8108020000.memory-controller: ptcr: @0x0000000000000000: Read response with poison bit error status:0
[  333.426163] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426168] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426172] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426176] arm-smmu-v3 8806000000.iommu:    0x0000007ffe489080
[  333.426179] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426184] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426187] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426190] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426193] arm-smmu-v3 8806000000.iommu:    0x0000007ffe48b080
[  333.426196] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426201] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426204] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426208] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426211] arm-smmu-v3 8806000000.iommu:    0x0000007ffe489180
[  333.426214] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426219] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426222] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426225] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426227] arm-smmu-v3 8806000000.iommu:    0x0000007ffe48d080
[  333.426231] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426235] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426238] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426242] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426245] arm-smmu-v3 8806000000.iommu:    0x0000007ffe48b180
[  333.426248] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426253] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426256] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426258] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426261] arm-smmu-v3 8806000000.iommu:    0x0000007ffe48f080
[  333.426264] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426269] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426272] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426275] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426277] arm-smmu-v3 8806000000.iommu:    0x0000007ffe491080
[  333.426280] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426285] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426288] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426291] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426294] arm-smmu-v3 8806000000.iommu:    0x0000007ffe48d180
[  333.426297] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426301] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426304] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426307] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426310] arm-smmu-v3 8806000000.iommu:    0x0000007ffe493080
[  333.426313] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.426318] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[  333.426321] arm-smmu-v3 8806000000.iommu:    0x0000090000000010
[  333.426324] arm-smmu-v3 8806000000.iommu:    0x0000020800000000
[  333.426327] arm-smmu-v3 8806000000.iommu:    0x0000007ffe495080
[  333.426330] arm-smmu-v3 8806000000.iommu:    0x0000000000000000
[  333.515455] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.515746] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.515939] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.516135] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.516315] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.516496] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.516675] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.516851] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.517030] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.517212] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.517399] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.517564] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.517742] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.517921] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.518097] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.518281] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.518457] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.518635] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.518816] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.518991] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.519170] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.519348] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.519527] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.519706] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.519888] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.520071] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.520252] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.520440] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.520626] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.520813] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.520999] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.521187] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.521374] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.521563] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.521747] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.521930] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.522109] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.522288] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.522473] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  333.522655] NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
[  334.166148] nvethernet a808b10000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
[  359.693905] rcu: INFO: rcu_sched self-detected stall on CPU
[  359.693912] rcu:     0-....: (5246 ticks this GP) idle=c8bc/1/0x4000000000000000 softirq=13200/13200 fqs=2616
[  359.693923] rcu:     (t=5250 jiffies g=24393 q=33212 ncpus=14)
[  359.693928] CPU: 0 PID: 2193 Comm: Xorg Tainted: G        W  OE      6.8.12-rt-tegra #16
[  359.693934] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS r38.2-899cdbc9-dirty 09/28/2025
[  359.693937] pstate: 63400009 (nZCv daif +PAN -UAO +TCO +DIT -SSBS BTYPE=--)
[  359.693942] pc : dce_client_ipc_wait+0xc0/0x188 [tegra_dce]
[  359.693968] lr : dce_client_ipc_wait+0xc0/0x188 [tegra_dce]
[  359.693983] sp : ffff8000864cb2d0
[  359.693985] x29: ffff8000864cb2d0 x28: 0000000000000014 x27: ffffce6c4f416d20
[  359.693993] x26: ffffce6c4dde41f0 x25: ffffce6c4dde41f0 x24: 0000000000000000
[  359.693998] x23: ffffce6c4ddf3638 x22: ffffce6c4ddefd68 x21: ffffce6c4dde5628
[  359.694003] x20: ffff000090e17880 x19: 00000000fffffe00 x18: ffffffffffffffff
[  359.694007] x17: 0000000000000000 x16: ffffce6c85c66170 x15: ffff8000864cb0e0
[  359.694012] x14: ffff8000864cb278 x13: 2e676e6979727465 x12: 72203a6465747075
[  359.694017] x11: 0000000000000000 x10: 0000000000000000 x9 : 0000000000000000
[  359.694022] x8 : ffff8000864cb278 x7 : 747075727265746e x6 : 692074696177205d
[  359.694027] x5 : ffff8000864cb23a x4 : ffffce6c4ddf365f x3 : 0000000000000000
[  359.694032] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00009d0fed80
[  359.694037] Call trace:
[  359.694040]  dce_client_ipc_wait+0xc0/0x188 [tegra_dce]
[  359.694054]  dce_ipc_send_message_sync+0x90/0x288 [tegra_dce]
[  359.694068]  tegra_dce_client_ipc_send_recv+0x94/0x1d0 [tegra_dce]
[  359.694081]  nv_tegra_dce_client_ipc_send_recv+0x38/0x64 [nvidia]
[  359.694941]  dceclientSendRpc_IMPL+0x64/0xe0 [nvidia]
[  359.695776]  _dceRpcIssueAndWait.isra.0+0x80/0x100 [nvidia]
[  359.696549]  rpcRmApiControl_dce+0xc8/0x1b0 [nvidia]
[  359.697300]  rmresControl_Prologue_IMPL+0xb4/0x1c0 [nvidia]
[  359.698093]  resControl_IMPL+0xec/0x1d0 [nvidia]
[  359.698879]  serverControl+0x3b8/0x4a0 [nvidia]
[  359.699652]  _rmapiRmControl+0x474/0x6a0 [nvidia]
[  359.700411]  rmapiControlWithSecInfo+0xa8/0x150 [nvidia]
[  359.701159]  rmapiControlWithSecInfoTls+0x74/0xe0 [nvidia]
[  359.701913]  _nv04ControlWithSecInfo.constprop.0+0x80/0xa0 [nvidia]
[  359.702656]  Nv04ControlKernel+0x50/0x60 [nvidia]
[  359.703387]  nvkms_call_rm+0x58/0x94 [nvidia_modeset]
[  359.703534]  nvRmApiControl+0x50/0x70 [nvidia_modeset]
[  359.703677]  __arm64_sys_ioctl+0xac/0xf0
[  359.703691]  invoke_syscall+0x48/0x114
[  359.703702]  el0_svc_common.constprop.0+0x40/0xe0
[  359.703711]  do_el0_svc+0x1c/0x28
[  359.703719]  el0_svc+0x30/0xa8
[  359.703733]  el0t_64_sync_handler+0x120/0x12c
[  359.703737]  el0t_64_sync+0x194/0x198
These errors should be fixed in the next JP7.1 release.
Hi @mingming,
Do you still hit rcu stall issue with rt-kernel?
