We use NvJPEGEncoder
to encode images (resolution: 1920x1080, color format: NVBUF_COLOR_FORMAT_YUV420
NVJPGGetSurfPinHandle 91: NVJPGGetSurfPinHandle : Surface not registered
NVJPGPushSurfFalconMethodRelocShift 369: Surface not registered
tvmrNvjpgJPEGEncFeedFrame_safe 583: NVJPGPushSurfFalconMethodRelocShift failed for SET_CUR_PIC_CHROMA_U with error 0x4
tvmrNvjpgJPEGEncFeedFrame_safe 590: NVJPGPushSurfFalconMethodRelocShift failed for SET_CUR_PIC_CHROMA_V with error 0x4
NvRmHost1xStreamEndClass: Requested number of operations in StreamBegin not yet pushed
NvRmHost1xStreamEnd: StreamEndClass failed, err = 8
pushNVJPGStreamEnd 153: Stream end failed
tvmrNvjpgJPEGEncFeedFrame_safe 597: Call to pushNVJPGStreamEnd failed with error 0x1
tvmrNvjpgJPEGEncFeedFrame_safe 605: Stream flush failed with error 0x8
Thread 103 "mediapipe/44073" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xfffedffec900 (LWP 440733)]
0x0000ffffe8ef01c4 in jpeg_write_raw_data () from /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so
(gdb) bt
#0 0x0000ffffe8ef01c4 in jpeg_write_raw_data () at /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so
#1 0x0000ffffe9d53148 in NvJPEGEncoder::encodeFromFd(int, J_COLOR_SPACE, unsigned char**, unsigned long&, int) (this=
0xffff4c0034e0, fd=277, color_space=JCS_YCbCr, out_buf=0xfffedffeb120, out_buf_size=@0xfffedffeb130: 1555200, quality=90)
at /home/work/workspace/jetson/jetson_multimedia_api_35.1.0/samples/common/classes/NvJpegEncoder.cpp:115
Any idea for this problem?
