I have all the containers up and running and VST web app is working:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
5c09c24d9f29 nvcr.io/nvidia/jps/sdr:jps-v2.0.4 "sh -c '/wdm/dist/sd…" 40 minutes ago Up 40 minutes sdr-emdx
11441655cac7 nvcr.io/nvidia/jps/emdx-analytics:jps_v1.1.1 "python3 gunicorn --…" 40 minutes ago Up 40 minutes emdx-analytics-02
436e1be4d1ea nvcr.io/nvidia/jps/emdx-analytics:jps_v1.1.1 "python3 gunicorn --…" 40 minutes ago Up 40 minutes emdx-analytics-01
f6efccbb0b28 nvcr.io/nvidia/jps/sdr:jps-v2.0.4 "sh -c '/wdm/dist/sd…" 40 minutes ago Up 40 minutes sdr
7afd9386b70f nvcr.io/nvidia/jps/deepstream:7.0-jps-v1.1.1 "sh -c '/opt/nvidia/…" 40 minutes ago Up 40 minutes deepstream
45c40fb859c5 nvcr.io/nvidia/jps/sdr-reprovision-controller:jps-v1 "/bin/sh -c ./entryp…" 40 minutes ago Up 40 minutes sdr-reprovision-controller
a06c3379ab7f nvcr.io/nvidia/jps/emdx-analytics-web-api:jps_v1.1.1 "python3 gunicorn --…" 40 minutes ago Up 40 minutes emdx-webapi
64343839b12a nvcr.io/nvidia/jps/vst:v1.2.58_aarch64 "sh -c '/root/vst_re…" 3 hours ago Up 3 hours vst
7b2bff7dd583 redisfab/redistimeseries:master-arm64v8-jammy "docker-entrypoint.s…" 3 hours ago Up 3 hours redis
882a8e4ab2a9 nvcr.io/nvidia/jps/ialpha-ingress-arm64v8:0.10 "sh -c '/nginx.sh 2>…" 3 hours ago Up 3 hours ingress
29d14554bb3f prom/node-exporter "/bin/node_exporter …" 3 hours ago Up 3 hours nodeexporter
acd3d74c9cba nvcr.io/nvidia/jps/jps-metric-exporter:v1.4.0_arm64v8 "/usr/bin/shelless_u…" 3 hours ago Up 3 hours jps-metric-exporter
b720bc8eb72d nvcr.io/nvidia/jps/its-monitoring:v1.6.1_arm64 "/root/its_monitorin…" 3 hours ago Up 3 hours its-monitoring
8974547780de prom/pushgateway "/bin/pushgateway" 3 hours ago Up 3 hours push-gateway
be6f8940772a prom/prometheus "/bin/prometheus --c…" 3 hours ago Up 3 hours prometheus
09a9e885be06 grafana/grafana "/run.sh" 3 hours ago Up 3 hours grafana
6e922220c732 prom/alertmanager "/bin/alertmanager -…" 3 hours ago Up 3 hours alert-manager
However, the app doesn’t connect to eMDX.
It says Failed to connect to [jetson-ipaddress]:30080
emdx is listed on the containers running.
Any insights what is going on?
