JSON file wrongly formate ? (Mlx5Cmd.exe -stat -json )
I am using mlx5cmd version 2.30.21713.0, and it seems to me that the JSON format is not correct
Section Adapter, the “name” : line has no cote, neither , at the end
Here attached my exemple
Json text.txt (4.52 KB)
You are right.
I do see in the WinOF-2 driver v2.30 the missing of one inverted-commas + a comma at the end of the “name” in the “json” format
I presume you have used the command # mlx5cmd.exe -stat -json (to get the output in JSON format)
if so, then notice that it is already fixed in WinOF-2 driver v2.40
Have checked & confirmed it myself (see attached mlx5cm_json_file_v2.40)
PS C:> Mlx5Cmd.exe -stat | findstr driver_ver
driver_ver=2.40.22511.0
you can also pars it using the site: http://json.parser.online.fr/
Hope this helps
I have installed the version 2.40 … but I still believe that it’s not correct for me
see the code here below and the attached TXT.
Thank you for your reply / help
Mlx5Cmd.exe -stat -json | Convertfrom-Json
Invalid object passed in, ‘:’ or ‘}’ expected. (662):
“NIC 1”: {
“Info”: {
“physical_location”: “Bus 4, Device 0, Function 1”,
“state”: “ENABLED”,
“uplink”: {
“BUS”: “PCI-E Gen3”,
“SPEED”: “8.0 GT/s”,
“WIDTH”: “x8”,
“CAPS”: “8.0*x8”,
“MaxPayloadSize”: “256 Bytes”,
“MaxReadReqSize”: “4096 Bytes”
“vendor_id”: “0x15b3”,
“vendor_part_id”: “4117”,
“hw_ver”: “0x0”,
“fw_ver”: “14.26.1040”,
“driver_ver”: “2.40.22511.0”,
“PSID”: “HP_2690110034”,
“system_image_guid”: “98f2:b3ff:ffde:5cd0”
“Adapters”: {
“Adapter 1”: {
“name”: "Embedded
“interface_description”: “HPE Ethernet 10/25Gb 2-port 640FLR-SFP28 Adapter #2”,
