I failed to install Jetpack 3.1 on my ubuntu16.04. The error says unalble to locate libvisionworks…
This happened when I deleted the folder and tried to reinstall… I don’t know how I could recover. Please provide some feedback… Thanks.
root 6855 0.0 0.0 190308 2744 ? Ssl 17:04 0:00 /home/el/Jetpack31//_installer/sudo_daemon -installer=6826 -d=/home/el/Jetpack31//_installer/tmp
0
/home/el/Jetpack31//_installer/run_command -c="apt-get remove --purge -y libvisionworks." -d=/home/el/Jetpack31//_installer/tmp
Reading package lists…
Building dependency tree…
Reading state information…
Package ‘libvisionworks-samples’ is not installed, so not removed
Package ‘libvisionworks-dev’ is not installed, so not removed
Package ‘libvisionworks’ is not installed, so not removed
The following packages were automatically installed and are no longer required:
gstreamer1.0-plugins-bad-videoparsers libass5 libavresample-ffmpeg2 libbs2b0
libflite1 libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-dev
libgstreamer1.0-dev libopenal-data libopenal1 libpostproc-ffmpeg53
libsdl1.2debian libsodium18 libzmq5 tcl-vtk
Use ‘apt autoremove’ to remove them.
The following packages will be REMOVED:
libvisionworks-repo
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 66.7 MB disk space will be freed.
(Reading database … 393856 files and directories currently installed.)
Removing libvisionworks-repo (1.6.0.193n) …
Purging configuration files for libvisionworks-repo (1.6.0.193n) …
root 6855 0.0 0.0 190308 2756 ? Ssl 17:04 0:00 /home/el/Jetpack31//_installer/sudo_daemon -installer=6826 -d=/home/el/Jetpack31//_installer/tmp
0
/home/el/Jetpack31//_installer/run_command -c=“dpkg -i /home/el/Jetpack31/jetpack_download/libvisionworks-repo_1.6.0.193n_amd64_ubuntu-14.04.deb; apt-get update; apt-get install -y --force-yes libvisionworks libvisionworks-dev libvisionworks-docs libvisionworks-samples” -d=/home/el/Jetpack31//_installer/tmp -l=/home/el/Jetpack31/_installer/logs/64_TX2//visionworks_host.log
Selecting previously unselected package libvisionworks-repo.
(Reading database … 393839 files and directories currently installed.)
Preparing to unpack …/libvisionworks-repo_1.6.0.193n_amd64_ubuntu-14.04.deb .
Unpacking libvisionworks-repo (1.6.0.193n) …
Setting up libvisionworks-repo (1.6.0.193n) …
OK
Get:1 file:/var/cuda-repo-8-0-local-ga2 InRelease
Ign:1 file:/var/cuda-repo-8-0-local-ga2 InRelease
Get:2 file:/var/cuda-repo-8-0-local InRelease
Ign:2 file:/var/cuda-repo-8-0-local InRelease
Get:3 file:/var/cuda-repo-9-0-local InRelease
Ign:3 file:/var/cuda-repo-9-0-local InRelease
Get:4 file:/var/libopencv4tegra-repo InRelease
Ign:4 file:/var/libopencv4tegra-repo InRelease
Get:5 file:/var/visionworks-repo InRelease
Ign:5 file:/var/visionworks-repo InRelease
Get:6 file:/var/cuda-repo-8-0-local-ga2 Release [574 B]
Get:7 file:/var/cuda-repo-8-0-local Release [574 B]
Get:8 file:/var/cuda-repo-9-0-local Release [574 B]
Get:9 file:/var/libopencv4tegra-repo Release [347 B]
Get:10 file:/var/visionworks-repo Release [1,999 B]
Get:11 file:/var/visionworks-repo Release.gpg [819 B]
Ign:13 http://dl.google.com/linux/chrome-remote-desktop/deb stable InRelease
Hit:14 Index of /ubuntu xenial InRelease
Ign:17 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:19 http://dl.google.com/linux/chrome-remote-desktop/deb stable Release
Get:15 Index of /ubuntu xenial-updates InRelease [102 kB]
Hit:20 Index of /notepadqq-team/notepadqq/ubuntu xenial InRelease
Hit:23 http://dl.google.com/linux/chrome/deb stable Release
Hit:24 http://packages.ros.org/ros/ubuntu xenial InRelease
Get:21 Index of /ubuntu xenial-security InRelease [102 kB]
Get:18 Index of /ubuntu xenial-backports InRelease [102 kB]
Ign:26 Index of /ubuntu xenial/main arm64 Packages
Ign:27 Index of /ubuntu xenial/universe arm64 Packages
Ign:28 Index of /ubuntu xenial/multiverse arm64 Packages
Err:26 Index of /ubuntu xenial/main arm64 Packages
404 Not Found [IP: 91.189.91.23 80]
Get:31 Index of /ubuntu xenial-updates/main amd64 Packages [737 kB]
Get:32 Index of /ubuntu xenial-updates/main i386 Packages [684 kB]
Ign:33 Index of /ubuntu xenial-updates/main arm64 Packages
Get:34 Index of /ubuntu xenial-updates/main Translation-en [306 kB]
Get:35 Index of /ubuntu xenial-updates/main amd64 DEP-11 Metadata [317 kB]
Get:36 Index of /ubuntu xenial-updates/main DEP-11 64x64 Icons [224 kB]
Get:37 Index of /ubuntu xenial-updates/restricted amd64 Packages [7,560 B]
Get:38 Index of /ubuntu xenial-updates/restricted i386 Packages [7,524 B]
Get:39 Index of /ubuntu xenial-updates/restricted Translation-en [2,272 B]
Get:40 Index of /ubuntu xenial-updates/universe amd64 Packages [593 kB]
Get:41 Index of /ubuntu xenial-updates/universe i386 Packages [549 kB]
Ign:42 Index of /ubuntu xenial-updates/universe arm64 Packages
Get:43 Index of /ubuntu xenial-updates/universe Translation-en [240 kB]
Get:44 Index of /ubuntu xenial-updates/universe amd64 DEP-11 Metadata [191 kB]
Get:45 Index of /ubuntu xenial-updates/universe DEP-11 64x64 Icons [272 kB]
Get:46 Index of /ubuntu xenial-updates/multiverse amd64 Packages [16.2 kB]
Get:47 Index of /ubuntu xenial-updates/multiverse i386 Packages [15.3 kB]
Ign:48 Index of /ubuntu xenial-updates/multiverse arm64 Packages
Get:49 Index of /ubuntu xenial-updates/multiverse amd64 DEP-11 Metadata [5,888 B]
Get:50 Index of /ubuntu xenial-backports/main amd64 Packages [4,836 B]
Get:51 Index of /ubuntu xenial-backports/main i386 Packages [4,840 B]
Ign:52 Index of /ubuntu xenial-backports/main arm64 Packages
Get:53 Index of /ubuntu xenial-backports/main amd64 DEP-11 Metadata [3,328 B]
Get:54 Index of /ubuntu xenial-security/main amd64 Packages [460 kB]
Get:55 Index of /ubuntu xenial-backports/universe amd64 Packages [6,624 B]
Get:56 Index of /ubuntu xenial-backports/universe i386 Packages [6,616 B]
Ign:57 Index of /ubuntu xenial-backports/universe arm64 Packages
Get:58 Index of /ubuntu xenial-backports/universe amd64 DEP-11 Metadata [4,696 B]
Get:59 Index of /ubuntu xenial-backports/universe DEP-11 64x64 Icons [2,717 B]
Get:60 Index of /ubuntu xenial-security/main i386 Packages [414 kB]
Ign:61 Index of /ubuntu xenial-security/main arm64 Packages
Get:62 Index of /ubuntu xenial-security/main Translation-en [198 kB]
Get:63 Index of /ubuntu xenial-security/main amd64 DEP-11 Metadata [67.4 kB]
Get:64 Index of /ubuntu xenial-security/main DEP-11 64x64 Icons [77.2 kB]
Get:65 Index of /ubuntu xenial-security/restricted amd64 Packages [7,224 B]
Get:66 Index of /ubuntu xenial-security/restricted i386 Packages [7,224 B]
Get:67 Index of /ubuntu xenial-security/restricted Translation-en [2,152 B]
Get:68 Index of /ubuntu xenial-security/universe amd64 Packages [321 kB]
Get:69 Index of /ubuntu xenial-security/universe i386 Packages [280 kB]
Err:33 Index of /ubuntu xenial-updates/main arm64 Packages
Err:52 Index of /ubuntu xenial-backports/main arm64 Packages
Ign:70 Index of /ubuntu xenial-security/universe arm64 Packages
Get:71 Index of /ubuntu xenial-security/universe Translation-en [121 kB]
Get:72 Index of /ubuntu xenial-security/universe amd64 DEP-11 Metadata [51.4 kB]
Get:73 Index of /ubuntu xenial-security/universe DEP-11 64x64 Icons [80.2 kB]
Get:74 Index of /ubuntu xenial-security/multiverse amd64 Packages [3,208 B]
Get:75 Index of /ubuntu xenial-security/multiverse i386 Packages [3,376 B]
Ign:76 Index of /ubuntu xenial-security/multiverse arm64 Packages
Err:61 Index of /ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.88.149 80]
Fetched 306 kB in 2s (143 kB/s)
W: Invalid ‘Date’ entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.149 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
E: Unable to locate package libvisionworks-docs
