tf2trt_with_onnx this Github repo has Jupyter notebook documents how to convert a Tensorflow or Keras model to TenosrRT using ONNX. ONNX is the official way to convert TF/Keras model to TRT.
This is has been tested successfully on Facenet Keras model
If anyone has a question please ask!
Hi, plz could you help me, I have clone the git repository into my tensorflow nvidia container, TF2.2-nv. So, I have made some changes: instead of import keras, i used from tensorflow import keras. That is step 1.
Then, in step 2, I got, module ‘tensorflow.keras.backend’ has no attribute ‘get_session’.
So, I would really appreciate if you recommend to downgrade my TF. or to use another container in order to be able to execute this Jupyter notebook.
In TF 2 get_session is removed, there are some modifications needed, I have added keras_to_pb_tf2.py
I have test it successfully to generate pb file in TF2.0. In jupyter notebook just change the from keras_to_pb_tf2 import keras_to_pb' instead of from keras_to_pb import keras_to_pb’
Thanks a lot, it worked for me (well, I ran two first steps in other laptop, with those files y could continue with step 3 in my new container, cause I had some trouble and I reconstruct my docker container). Finally, I have my TRT engine. I hope it works on inference =). Ill let you know.
Step 2 convert pb to ONNX must be done on same machine that you will do inferencing because it will optimize the model specificaly to the GPU on the machine. Did you do it on same machine?
