Hi, this is an oldy but for me pretty relevant. I STILL have a Lenovo W530 with Nvidia k1000m and I have it running Cuda and it seems like all is well.
My issue is that when attempting to run a script in Anaconda, I keep getting an error. I am not sure what it means so could really use some help. I reached out on GITHUB but nobody seems interested. Here is what I am running:
(ldm) C:\Users\MojoJojo\Documents\Stable Diffusion\stable-diffusion-main>set /P id=Enter Prompt And Options :
Enter Prompt And Options :(ldm) C:\Users\MojoJojo\Documents\Stable Diffusion\stable-diffusion-main>python “optimizedSD\optimized_txt2img.py”
Global seed set to 42
Loading model from model 1.3.ckpt
Global Step: 470000
UNet: Running in eps-prediction mode
Selected timesteps for ddim sampler: [ 1 21 41 61 81 101 121 141 161 181 201 221 241 261 281 301 321 341
361 381 401 421 441 461 481 501 521 541 561 581 601 621 641 661 681 701
721 741 761 781 801 821 841 861 881 901 921 941 961 981]
File “optimizedSD\optimized_txt2img.py”, line 193, in
model = instantiate_from_config(config.modelUNet)
File “c:\users\mojojojo\documents\stable diffusion\stable-diffusion-main\ldm\util.py”, line 85, in instantiate_from_config
return get_obj_from_str(config[“target”])(**config.get(“params”, dict()))
File “c:\users\mojojojo\documents\stable diffusion\stable-diffusion-main\optimizedSD\ddpm.py”, line 356, in init
self.make_schedule(ddim_num_steps=ddim_steps, ddim_eta=0.0, verbose=True)
File “c:\users\mojojojo\documents\stable diffusion\stable-diffusion-main\optimizedSD\ddpm.py”, line 450, in make_schedule
self.register_buffer1(‘betas’, to_torch(self.betas))
File “c:\users\mojojojo\documents\stable diffusion\stable-diffusion-main\optimizedSD\ddpm.py”, line 438, in register_buffer1
attr = attr.to(torch.device(“cuda”))
File “C:\Users\MojoJojo\anaconda3\envs\ldm\lib\site-packages\torch\cuda_init_.py”, line 216, in _lazy_init
torch._C._cuda_init()
RuntimeError: CUDA driver initialization failed, you might not have a CUDA gpu.(ldm) C:\Users\MojoJojo\Documents\Stable Diffusion\stable-diffusion-main>cmd /k
Can anyone point me in the right direction because I am pretty lost at this point. Thanks!
Here is some more info from running nvidia-smi command
Thu Aug 25 22:22:55 2022
| NVIDIA-SMI 426.78 Driver Version: 426.78 CUDA Version: 10.1 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 Quadro K1000M WDDM | 00000000:01:00.0 On | N/A |
| N/A 37C P8 N/A / N/A | 814MiB / 2048MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1468 C+G Insufficient Permissions N/A |
| 0 4656 C+G …mmersiveControlPanel\SystemSettings.exe N/A |
| 0 4796 C+G …ent.CBS_cw5n1h2txyewy\TextInputHost.exe N/A |
| 0 7524 C+G …t_cw5n1h2txyewy\ShellExperienceHost.exe N/A |
| 0 7860 C+G C:\Windows\explorer.exe N/A |
| 0 8660 C+G …10091.0_x64__8wekyb3d8bbwe\Video.UI.exe N/A |
| 0 8912 C+G …5n1h2txyewy\StartMenuExperienceHost.exe N/A |
| 0 9668 C+G …dows.Search_cw5n1h2txyewy\SearchApp.exe N/A |
| 0 10280 C+G …136.0_x64__8wekyb3d8bbwe\YourPhone.exe N/A |
| 0 10288 C+G …es\Google\Chrome\Application\chrome.exe N/A |
| 0 10844 C+G …osoft.LockApp_cw5n1h2txyewy\LockApp.exe N/A |
| 0 12620 C+G C:\Program Files\NordVPN\NordVPN.exe N/A |
| 0 14200 C+G …3.8.0_x64__8wekyb3d8bbwe\Calculator.exe N/A |
| 0 14620 C+G C:\Windows\System32\WWAHost.exe N/A |
| 0 15124 C+G …dows.Search_cw5n1h2txyewy\SearchApp.exe N/A |
| 0 15204 C+G …x64__8wekyb3d8bbwe\Microsoft.Photos.exe N/A |
| 0 15808 C+G …dows.Search_cw5n1h2txyewy\SearchApp.exe N/A |
±----------------------------------------------------------------------------+(base) C:\Users\MojoJojo>
