Hello.
NVidia newer hypervisor (~second half 2014) drivers lower ram assignments (probably Nvidia has some undocumented issues with full-ram assignments).
# grep framebufferlength /usr/share/nvidia/vgx/*
/usr/share/nvidia/vgx/grid_k100.conf:plugin0.framebufferlength 0x10000000
/usr/share/nvidia/vgx/grid_k120q.conf:plugin0.framebufferlength 0x1A000000
/usr/share/nvidia/vgx/grid_k140q.conf:plugin0.framebufferlength 0x38000000
/usr/share/nvidia/vgx/grid_k160q.conf:plugin0.framebufferlength 0x74000000
/usr/share/nvidia/vgx/grid_k180q.conf:plugin0.framebufferlength 0xEC000000
/usr/share/nvidia/vgx/grid_k200.conf:plugin0.framebufferlength 0x10000000
/usr/share/nvidia/vgx/grid_k220q.conf:plugin0.framebufferlength 0x1A000000
/usr/share/nvidia/vgx/grid_k240q.conf:plugin0.framebufferlength 0x38000000
/usr/share/nvidia/vgx/grid_k260q.conf:plugin0.framebufferlength 0x74000000
/usr/share/nvidia/vgx/grid_k280q.conf:plugin0.framebufferlength 0xEC000000
K220Q == 0x1A000000 == 436207616 == 416 MiB
Probably you can set "framebufferlength" (search driver "Release notes" for similar "frame_rate_limiter" parameter setting) but the result seems to be unsupported or driver can crash.
M.C>
