K8s install fail on orin nx
k8s install fail on orin nx
JP5.1.1
error log:
 kubelet.go:2422] "Error getting node" err="node \"linux\" not found"
Could you share your installation steps with us?
Below is a sharing to set Kubernetes for your reference:
Here are the installation steps::
#k8s安装
//关闭swap
swapoff -a # 临时禁用
sed -ri 's/.*swap.*/#&/' /etc/fstab # 永久禁用
//docker配置
在/etc/docker/daemon.json配置文件中加入 "exec-opts": [ "native.cgroupdriver=systemd" ]
sudo systemctl daemon-reload
sudo systemctl restart docker #重启docker
//安装cri-docker
https://github.com/Mirantis/cri-dockerd/tags #打开链接下载最新版 (cri-dockerd-0.3.4.arm64.tgz)
tar zxf cri-dockerd-0.3.4.arm64.tgz
cp cri-dockerd/cri-dockerd /usr/local/bin/
https://github.com/Mirantis/cri-dockerd/tree/master/packaging/systemd  #创建cri-docker启动文件,启动文件从此链接可以找到
vim cri-docker.service (修改.service文件第十行为:ExecStart=/usr/local/bin/cri-dockerd --container-runtime-endpoint fd:// --network-plugin=cni --pod-infra-container-image=registry.aliyuncs.com/google_containers/pause:3.8)
cp cri-docker.service cri-docker.socket /etc/systemd/system/
systemctl enable cri-docker.service
systemctl enable --now cri-docker.socket
systemctl start cri-docker #启动cri-docker并设置开机自动启动
systemctl status cri-docker #查看启动状态
//配置k8s镜像
curl https://mirrors.aliyun.com/kubernetes/apt/doc/apt-key.gpg | apt-key add -
cat <<EOF >/etc/apt/sources.list.d/kubernetes.list
deb https://mirrors.aliyun.com/kubernetes/apt/ kubernetes-xenial main
EOF
apt-get update
apt-get install -y kubelet=1.23.1-00 kubeadm=1.24.1-00 kubectl=1.24.1-00
//初始化k8s
kubeadm init --kubernetes-version=1.23.1 --apiserver-advertise-address=192.168.162.213 --image-repository registry.aliyuncs.com/google_containers --pod-network-cidr=10.244.0.0/16 --cri-socket /var/run/cri-dockerd.sock
1.24.1和1.23.1、1.23.6都试了。一样的错
k8s部署.txt (1.7 KB)
It’s been solved
Thanks for the update.
Would you mind sharing how you fix the issue so other users can benefit from it?
