• Hardware Platform (Jetson / GPU) : Jetson
• DeepStream Version : 5.0
• JetPack Version (valid for Jetson only) : 4.4 DP
• TensorRT Version : 7
I was following /opt/nvidia/deepstream/deepstream/sources//libs/kafka_protocol_adaptor/README.
while running both test programs;
./test_sample_proto_sync
./test_sample_proto_async
It shows :
####:/opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor$ ./test_kafka_proto_sync
Refer to nvds log file for log output
/opt/nvidia/deepstream/deepstream-NVDS_VERSION/lib/libnvds_kafka_proto.so: cannot open shared object file: No such file or directory
unable to open shared library
But in the line no. 29 in README sudo cp /usr/local/lib/librdkafka* /opt/nvidia/deepstream/deepstream-<version>/lib/
while copying
There were no libnvds_kafka_proto.so file in /usr/local/lib/ but it is in /opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor/
