Is there a Way to install Kali Linux on the Jetson Nano board?
Hi vedupadhye2195,
I can’t answer it due to not done any test yet, not sure if can work, may other developer share their experience or suggestions.
I suspect that if you get it to work, then the GPU driver would be via Nouveau (which means CUDA and GPU software won’t work). If you were to manage to use the same release of Xorg as on the officially supported L4T/Ubuntu, then the driver could be loaded…but this would be a lot of work and large learning curve.
