Kbuild error when trying to compile Linux Kernel 5.1.0-rc6
Kbuild error when trying to compile Linux Kernel 5.1.0-rc6. I am able to get to the login screen but I am never able to log into the desktop. I tried recompiling the kernel and saw the following error in make.log file:
DKMS make.log for nvidia-384-384.130 for kernel 5.1.0-rc6+ (x86_64)
Mon Apr 29 23:57:48 PDT 2019
Makefile:19: /Kbuild: No such file or directory
make[3]: *** No rule to make target ‘/Kbuild’. Stop.
I found this error when trying to do sudo make modules_install install
ERROR (dkms apport): kernel package linux-headers-5.1.0-rc6+ is not supported
Error! Bad return status for module build on kernel: 5.1.0-rc6+ (x86_64)
Consult /var/lib/dkms/nvidia-384/384.130/build/make.log for more information.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.1.0-rc6+ /boot/vmlinuz-5.1.0-rc6+
Here is my lspci output:
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x8 Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM87 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation GM204M [GeForce GTX 970M] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GM204 High Definition Audio Controller (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GM204M [GeForce GTX 970M] (rev a1)
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411 PCI Express Card Reader (rev 01)
04:00.2 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0a)
05:00.0 Network controller: Intel Corporation Wireless 7260 (rev bb)
When I boot into my regular kernel 4.4.0-140-generic seems to work fine. I believe it is the nvidia driver that is causing the issue.
Driver v384.130 is much too old compile against kernel 5.0 and up. You’d need at least v418.56 or v430 for kernel 5.0 though I don’t know if it’ll work for 5.1rc. Nevertheless, your system looks like a SLI setup and those so far didn’t work with kernel 5.0 regardless of driver version.
