Using kdeinit5 to start konsole, crashes on konsole exit
I can reproduce it every time.
It happens to me only with nvidia driver.
$ kdeinit5 konsole
kdeinit5: Shutting down running client.
kdeinit5: preparing to launch ‘/usr/lib/x86_64-linux-gnu/libexec/kf5/klauncher’
kdeinit5: Launched KLauncher, pid = 25358, result = 0
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
kdeinit5: opened connection to :0
kdeinit5: preparing to launch ‘libkdeinit5_konsole’
kdeinit5: Launched ‘konsole’, pid = 25361 result = 0
KCrash: crashing… crashRecursionCounter = 2
KCrash: Application Name = kdeinit5 path = /usr/bin pid = 25361
KCrash: Arguments: /usr/bin/kdeinit5
KCrash: Attempting to start /usr/lib/x86_64-linux-gnu/libexec/drkonqi from kdeinit
sock_file=/run/user/500/kdeinit5__0
kdeinit5: Got EXEC_NEW ‘/usr/lib/x86_64-linux-gnu/libexec/drkonqi’ from wrapper.
kdeinit5: preparing to launch ‘/usr/lib/x86_64-linux-gnu/libexec/drkonqi’
found lsb_release
Using /proc to determine executable path
Executable is: “/usr/bin/kdeinit5”
Executable exists: true
Enabling drkonqi crash catching
Application: kdeinit5 (kdeinit5), signal: Segmentation fault
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
[KCrash Handler]
#6 0x00007fa410470d95 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.340.106
#7 0x00007fa413d160a0 in ?? () from /usr/lib/x86_64-linux-gnu/libGL.so.1
#8 0x00007fa4178892d3 in _dl_fini () at dl-fini.c:143
#9 0x00007fa415a9a831 in __run_exit_handlers (status=0, listp=0x7fa415e17718 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true, run_dtors=run_dtors@entry=true) at exit.c:108
#10 0x00007fa415a9a92a in __GI_exit (status=) at exit.c:139
#11 0x00005649846756a4 in launch (argc=1, _name=0x564984d5dae0 “konsole”, args=, cwd=, envc=0, envs=, reset_env=false, tty=0x0, avoid_loops=false, startup_id_str=0x564984678527 “0”) at ./src/kdeinit/kinit.cpp:705
#12 0x0000564984671f53 in main (argc=2, argv=) at ./src/kdeinit/kinit.cpp:1756
https://bugs.kde.org/show_bug.cgi?id=391664
nvidia-bug-report.log.gz (67.1 KB)
