Nvidia driver traps:
This usually happens after restart. With after I mean specifically open day FF with some tabs and Thunderbird and Dolpin being open.
I also see this happen for the first time since upgrading to openSUSE Leap 15.1 from 15.0
The NVIDIA driver was not changed during this upgrade.
(I know/think there are some newer NVIDIA driver in development or experimental. Although older ones also seem quite experimental).
pl@lgaz:~> sudo lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GT218M [NVS 3100M] (rev a2)
pl@lgaz:~> sudo lscpu | grep Arch
Architecture: x86_64
pl@lgaz:~> sudo hwinfo --gfxcard
34: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.xVMssAe1k49
Parent ID: vSkL.HBIEsup+SaA
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: “nVidia GT218M [NVS 3100M]”
Vendor: pci 0x10de “nVidia Corporation”
Device: pci 0x0a6c “GT218M [NVS 3100M]”
SubVendor: pci 0x17aa “Lenovo”
SubDevice: pci 0x215c
Revision: 0xa2
Driver: “nvidia”
Driver Modules: “nvidia”
Memory Range: 0xcc000000-0xccffffff (rw,non-prefetchable)
Memory Range: 0xd0000000-0xdfffffff (ro,non-prefetchable)
Memory Range: 0xce000000-0xcfffffff (ro,non-prefetchable)
I/O Ports: 0x2000-0x2fff (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 29 (416731 events)
I/O Ports: 0x3c0-0x3df (rw)
Module Alias: “pci:v000010DEd00000A6Csv000017AAsd0000215Cbc03sc00i00”
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: “modprobe nouveau”
Driver Info #1:
Driver Status: nvidia is active
Driver Activation Cmd: “modprobe nvidia”
Config Status: cfg=no, avail=yes, need=no, active=unknown
Attached to: #31 (PCI bridge)
Primary display adapter: #34
Application: kdeinit5 (kdeinit5), signal: Aborted
Using host libthread_db library “/lib64/libthread_db.so.1”.
[KCrash Handler]
#6 0x00007fe616f7d160 in raise () from /lib64/libc.so.6
#7 0x00007fe616f7e741 in abort () from /lib64/libc.so.6
#8 0x00007fe616fc04a7 in __libc_message () from /lib64/libc.so.6
#9 0x00007fe616fc6cc3 in malloc_printerr () from /lib64/libc.so.6
#10 0x00007fe616fc85c9 in _int_free () from /lib64/libc.so.6
#11 0x00007fe615400fb9 in ?? () from /usr/X11R6/lib64/libGL.so.1
#12 0x00007fe611c0fb80 in ?? () from /usr/lib64/libnvidia-glcore.so.340.107
#13 0x00007fe6153df0af in ?? () from /usr/X11R6/lib64/libGL.so.1
#14 0x00007fe618df32d2 in _dl_fini () from /lib64/ld-linux-x86-64.so.2
#15 0x00007fe616f7fd78 in __run_exit_handlers () from /lib64/libc.so.6
#16 0x00007fe616f7fdca in exit () from /lib64/libc.so.6
#17 0x00005651b039e926 in ?? ()
#18 0x00005651b039fc5c in ?? ()
#19 0x00005651b03a05cf in ?? ()
#20 0x00005651b039b43c in ?? ()
