Hi tmurray,
After a reboot the “kextstat | grep CUDA” returns nothing. I’ve listed my output below.
CUDA WORKING:
boussinesq:release johnston$ ./deviceQuery
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce GTX 285”
CUDA Driver Version: 2.30
CUDA Runtime Version: 2.30
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 1073414144 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.80 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
Press ENTER to exit…
boussinesq:release johnston$ kextstat | grep CUDA
107 0 0x8d41d000 0x2000 0x1000 com.nvidia.CUDA (1.1.0) <5 2>
boussinesq:release johnston$ ls -Fal /System/Library/StartupItems/CUDA
total 16
drwxr-xr-x 4 root wheel 136 Aug 10 16:43 ./
drwxr-xr-x 3 root wheel 102 Sep 17 2008 …/
-rwxrwxr-x 1 root wheel 498 May 22 09:35 CUDA*
-rw-rw-r-- 1 root wheel 438 May 22 09:35 StartupParameters.plist
AFTER REBOOT; CUDA NOT WORKING:
There is no device supporting CUDA.
Device 0: “Device Emulation (CPU)”
CUDA Capability Major revision number: 9999
CUDA Capability Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total number of registers available per block: 8192
Warp size: 1
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Run time limit on kernels: No
Integrated: Yes
Test PASSED
total 16
