right you are. I noticed that this morning after a reboot.
I have a similar problem. I’m on a MB Pro, with 8600M GT. I have to reinstall the
2.3.0 driver every time after reboot, but the kext is already running:
after reboot ‘kextstat | grep CUDA’ results in ’ 112 0 0x54c25000 0x2000 0x1000 com.nvidia.CUDA (1.1.0) <5 2>’
after reinstall, same commands: ’ 114 0 0x5b2ae000 0x2000 0x1000 com.nvidia.CUDA (1.1.0) <5 2>’
Not reading carefully everything I once installed the 2.3.1 driver (which is not intended to be used with my card), maybe
that is causing the problem. It seems as if the wrong kext is loaded at runtime.
Any ideas?
- Stephan
