Keep PCIe Reference Clock Active for pcie@141a0000 on Jetson AGX Orin (L4T 36.4.4)
hi,can you tell me how to slove Keep PCIe Reference Clock Active for pcie@141a0000 on Jetson AGX Orin (L4T 36.4.4); thank you
Please try the patch in tuning guide to make PCIe always on and see if you could see the clock active.
Can you just send the patch directly? I couldn’t find the download link. thank you very much!
I have find it; thank you,I will try it
The clk is always there before loading the kernel, but once UEFI is loaded, it disappears. During the kernel loading process, the clk only works for about 2 seconds and then quickly disappears.
Have you applied the patch..?
It does not matter how the behavior is like before UEFI. That stage is not something you could control or customize.
yes, i have applied the patch
Could you share the result of your lspci after you apply the patch?
I really want to figure out the problem. My switch hasn’t been reset during the MB1 initialization phase to make it work properly, and later on, after entering the system, it still can’t link up.
zdz@zdz-desktop:~$ lspci
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1)
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
zdz@zdz-desktop:~$
Forget about MB1. That stage does not matter.
You didn’t apply the patch correctly. lspci will show every pcie controller that is enabled if you apply the patch correctly.
Please share me how you really did on your side. It might have some steps wrong.
I connected a PI7C9X2G608GP expander to C5, and the reset of this expander is connected to the PEX_C5_RST_N pin.
But when I normally boot into the system, I found that REFCLK didn’t detect any clock signal, and modifying the above patch still didn’t work.
Not sure why you are replying a unrelated answer here… I was only asking how did you apply your patch.
Edit this file, then replace the ko in the system with the newly compiled ko file.
No, please replace the file in initrd and reflash the device.
The step 5 in above document will update the initrd. PCIe driver is loaded from initrd.
OK,I try it
Even following the steps to reflash it still doesn’t work.
Share me what is your lspci looks like now.
Please try to give some more information when you are telling info to others.
We won’t be possible to help you with just “not work” thing here.
I have keep clock, thanks
