While installing Keras in my Jetson AGX Xavier, I got the following error :
jetson-xavier@jetsonxavier-desktop:~$ sudo pip install keras
[sudo] password for jetson-xavier:
WARNING: The directory '/home/jetson-xavier/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting keras
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f76bab7b8>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /packages/ad/fd/6bfe87920d7f4fd475acd28500a42482b6b84479832bdc0fe9e589a60ceb/Keras-2.3.1-py2.py3-none-any.whl
Downloading Keras-2.3.1-py2.py3-none-any.whl (377 kB)
|████████████████████████████████| 377 kB 396 kB/s
Requirement already satisfied: keras-preprocessing>=1.0.5 in /usr/local/lib/python3.6/dist-packages (from keras) (1.0.5)
Requirement already satisfied: h5py in /usr/local/lib/python3.6/dist-packages (from keras) (2.9.0)
Requirement already satisfied: keras-applications>=1.0.6 in /usr/local/lib/python3.6/dist-packages (from keras) (1.0.8)
Requirement already satisfied: numpy>=1.9.1 in /usr/local/lib/python3.6/dist-packages (from keras) (1.16.1)
Collecting scipy>=0.14
Downloading scipy-1.4.1.tar.gz (24.6 MB)
|████████████████████████████████| 24.6 MB 655 kB/s
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-02poyqj7/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel setuptools 'Cython>=0.29.13' 'numpy==1.13.3; python_version=='"'"'3.5'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.13.3; python_version=='"'"'3.6'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.14.5; python_version=='"'"'3.7'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.17.3; python_version>='"'"'3.8'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.16.0; python_version=='"'"'3.5'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.16.0; python_version=='"'"'3.6'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.16.0; python_version=='"'"'3.7'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.17.3; python_version>='"'"'3.8'"'"' and platform_system=='"'"'AIX'"'"'' 'pybind11>=2.4.0'
cwd: None
Complete output (39 lines):
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.6/dist-packages/pip/__main__.py", line 16, in <module>
from pip._internal.cli.main import main as _main # isort:skip # noqa
File "/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/main.py", line 5, in <module>
import locale
File "/usr/lib/python3.6/locale.py", line 16, in <module>
import re
File "/usr/lib/python3.6/re.py", line 142, in <module>
class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 53, in apport_excepthook
if not enabled():
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 24, in enabled
import re
Original exception was:
import locale
import re
ERROR: Command errored out with exit status 1: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-02poyqj7/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- wheel setuptools 'Cython>=0.29.13' 'numpy==1.13.3; python_version=='"'"'3.5'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.13.3; python_version=='"'"'3.6'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.14.5; python_version=='"'"'3.7'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.17.3; python_version>='"'"'3.8'"'"' and platform_system!='"'"'AIX'"'"'' 'numpy==1.16.0; python_version=='"'"'3.5'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.16.0; python_version=='"'"'3.6'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.16.0; python_version=='"'"'3.7'"'"' and platform_system=='"'"'AIX'"'"'' 'numpy==1.17.3; python_version>='"'"'3.8'"'"' and platform_system=='"'"'AIX'"'"'' 'pybind11>=2.4.0' Check the logs for full command output.
Anyone have the same problem ?
Many thanks.
