I started work with deepstream and trying to convert weight file from keras to uff format. converted successfully but not working with deepstream docker 4.0
Is there any document that will indicate the correct version to use all the tools.
Tried the below path
keras . >> frozen graph >> uff
keras >> fronzen graph >> onnx
Tried this path for resnet18 classification network
uff conversion getting : DEBUG: convert reshape to flatten node
and deepstream giving error for the same file: log(): UffParser: Parser error: bn_conv1/Reshape_7: You cannot reshape with a different volume
Just wanted the correct way to deploy models to deepstream.
