Hi ,
There is something going wrong and I need the team’s help here…
My Desktop config is as follows
- Core i9 9900 K (9th Gen)
- GTX 2070 Super
I have successfully installed Tensorflow-gpu and all necessary CUDA and CUDNN libraries. It is getting detected successfully…
When I import Keras which uses tensorflow backend in my jupyter notebook the following logs are observed in anaconda prompt
name: GeForce RTX 2070 SUPER major: 7 minor: 5 memoryClockRate(GHz): 1.83
pciBusID: 0000:01:00.0
2019-10-29 20:47:00.840937: I tensorflow/stream_executor/platform/default/dlopen_checker_stub.cc:25] GPU libraries are statically linked, skip dlopen check.
2019-10-29 20:47:00.843754: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2019-10-29 20:47:01.380298: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-10-29 20:47:01.383117: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2019-10-29 20:47:01.385096: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2019-10-29 20:47:01.387454: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 6283 MB memory) → physical GPU (device: 0, name: GeForce RTX 2070 SUPER, pci bus id: 0000:01:00.0, compute capability: 7.5)
2019-10-29 20:47:02.041798: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library cublas64_100.dll
Now neural nets training functions like
cross_val_score , GridSearchCV are taking aweful amounts of time to complete… In fact what gets completed by i9 in 7.5 mins , 2070 takes 65 mins…
I have no idea, whats going wrong…
Any indications… I can start putting in the code, if needed…
Regards,
Suvo
