I am using Ubuntu 18 and Tensorflow 2.5, ONNX 1.7, and Keras 2.4. I’m trying to convert Keras code to Onnx. I have the following Python code:
from __future__ import print_function
import warnings
import matplotlib.pyplot as plt
import numpy as np
import pandas as pd
from keras import backend as K
from keras.callbacks import CSVLogger
from keras.layers import *
from keras.models import Model
from keras.optimizers import Adam
from scipy.io import loadmat
from scipy.misc import imread
from skimage.io import imsave
from skimage.transform import resize
import cv2
Ny=512
target_size = (Ny, Ny)
warnings.filterwarnings('ignore')
%matplotlib inline
LR= 1e-5
E, BS = 200,4
def get_unet(img_rows, img_cols):
inputs = Input((img_rows, img_cols, 1))
conv1 = Conv2D(64, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(inputs)
conv1 = Conv2D(64, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv1)
pool1 = MaxPooling2D(pool_size=(2, 2))(conv1)
conv2 = Conv2D(128, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(pool1)
conv2 = Conv2D(128, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv2)
pool2 = MaxPooling2D(pool_size=(2, 2))(conv2)
conv3 = Conv2D(256, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(pool2)
conv3 = Conv2D(256, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv3)
pool3 = MaxPooling2D(pool_size=(2, 2))(conv3)
conv4 = Conv2D(512, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(pool3)
conv4 = Conv2D(512, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv4)
drop4 = Dropout(0.5)(conv4)
pool4 = MaxPooling2D(pool_size=(2, 2))(drop4)
conv5 = Conv2D(1024, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(pool4)
conv5 = Conv2D(1024, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv5)
drop5 = Dropout(0.5)(conv5)
up6 = Conv2D(512, 2, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(UpSampling2D(size = (2,2))(drop5))
merge6 = concatenate([drop4,up6], axis = 3)
conv6 = Conv2D(512, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(merge6)
conv6 = Conv2D(512, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv6)
up7 = Conv2D(256, 2, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(UpSampling2D(size = (2,2))(conv6))
merge7 = concatenate([conv3,up7], axis = 3)
conv7 = Conv2D(256, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(merge7)
conv7 = Conv2D(256, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv7)
up8 = Conv2D(128, 2, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(UpSampling2D(size = (2,2))(conv7))
merge8 = concatenate([conv2,up8], axis = 3)
conv8 = Conv2D(128, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(merge8)
conv8 = Conv2D(128, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv8)
up9 = Conv2D(64, 2, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(UpSampling2D(size = (2,2))(conv8))
merge9 = concatenate([conv1,up9], axis = 3)
conv9 = Conv2D(64, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(merge9)
conv9 = Conv2D(64, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv9)
conv9 = Conv2D(2, 3, activation = 'relu', padding = 'same', kernel_initializer = 'he_normal')(conv9)
conv10 = Conv2D(1, 1, activation = 'sigmoid')(conv9)
model = Model(inputs=[inputs], outputs=[conv10])
model.compile(optimizer=Adam(lr=LR),
loss='binary_crossentropy', metrics=['binary_crossentropy'])
return model
outName='Unet'
trainDir='train'
trainAnnotDir='trainannot'
#training images
import os
Image_directory = './' + trainDir + '/'
Label_directory = './' + trainAnnotDir + '/'
image_lists = {os.path.basename(x[0]): x[2] for x in os.walk('./'+trainDir)}
n = len(image_lists[trainDir])
ids = os.listdir(trainDir)
train_images=np.zeros([n, Ny,Ny,1], dtype=float)
annot_train=np.zeros([n, Ny,Ny,1], dtype=float)
for j in range(0, n):
l=ids[j][:-4]
img = cv2.imread(Image_directory+l+'.bmp', 0)/255.0
label = cv2.imread(Label_directory+l+'.bmp', 0)/255.0
train_images[j,:,:,0], annot_train[j,:,:,0] =img, label
#test images
testDir='test'
testAnnotDir='testannot'
Image_directory = './' + testDir + '/'
Label_directory = './' + testAnnotDir + '/'
image_lists = {os.path.basename(x[0]): x[2] for x in os.walk('./'+testDir)}
n = len(image_lists[testDir])#16
ids = os.listdir(testDir)
nTestTotal=21
test_images=np.zeros([nTestTotal, Ny,Ny,1], dtype=float)
annot_test=np.zeros([nTestTotal, Ny,Ny,1], dtype=float)
nTest=0
for j in range(0, n): #n):
l=ids[j][:-4]
img = cv2.imread(Image_directory+l+'.bmp',0)/255.0
label = cv2.imread(Label_directory+l+'.bmp',0)/255.0
if img.shape[0]==Ny:
test_images[nTest,:,:,0], annot_test[nTest,:,:,0] =img, label
nTest+=1
C = np.concatenate([annot_test, annot_train])
I = np.concatenate([test_images, train_images])
#mixed precision
import tensorflow as tf
from tensorflow.keras.mixed_precision import experimental as mixed_precision
policy = mixed_precision.Policy('mixed_float16')
mixed_precision.set_policy(policy)
config = tf.compat.v1.ConfigProto()
config.gpu_options.allow_growth = True
session = tf.compat.v1.Session(config=config)
csv_callback = CSVLogger('history.log', append=True)
unet = get_unet(Ny, Ny)
filepath="W-E_{epoch:02d}-L_{loss:.6f}"+outName+".h5"
callbacks = keras.callbacks.ModelCheckpoint('./'+filepath, monitor='loss', verbose=1,
save_best_only=True, mode='min', period=1)
history = unet.fit(I, C, verbose=2, epochs=E, batch_size=BS, validation_split=0.1, callbacks=[csv_callback])
from tensorflow.keras.models import save_model
save_model(unet, outName+'.keras')
I then tried to convert it to ONNX with this:
from keras.models import load_model
import onnx
import keras2onnx
outName='Unet'
E,BS,LR=200,4,1e-5
Estr, LRstr='200', '0.00001'
onnx_model_name = 'unetMaster.onnx'
model = load_model(outName+'.keras')
onnx_model = keras2onnx.convert_keras(model, model.name)
onnx.save_model(onnx_model, onnx_model_name)
but it gave the error
File "kerasToOnnx.py", line 15, in <module>
File "/home/me/.local/lib/python3.8/site-packages/keras2onnx/main.py", line 62, in convert_keras
tf_graph = build_layer_output_from_model(model, output_dict, input_names, output_names)
File "/home/me/.local/lib/python3.8/site-packages/keras2onnx/_parser_tf.py", line 304, in build_layer_output_from_model
graph = model.outputs[0].graph
AttributeError: 'KerasTensor' object has no attribute 'graph'
maybe I’m getting this error because ONNX Only works with Tensorflow 1 instead of 2? can anyone help with this?
