Facing issue after updating the drivers from DGX dashboard and restart the device it says Kernal in panic and it doesn’t boot.
Again i have to reinstall the OS and then update the drivers and issue remains the same.
Is this a hardware issue ?
Can you share the exact error message you are seeing and where and what phase you are seeing them at?
Boot corruption issues:
The boot sequence frequently gets corrupted.
Even after reinstalling the OS multiple times, the device sometimes fails to load properly and displays boot-related errors.
Power failure while device is ON:
On several occasions, the device suddenly loses power even while it is running.
The screen goes completely blank, and the unit becomes unresponsive.
It only turns back on after performing a manual restart.
Frequent freezing during workloads:
While running demanding tasks like image generation or AI workloads, the device often hangs.
It requires multiple forced restarts to function again.
Overall system instability:
Even after following all the recommended steps, creating new OS media, and performing a clean installation, the same problems continue.
These issues are severely affecting usability and reliability.
If you need any specific logs, snapshots, or error details, I will be happy to provide them.
/var/log/dmesg and /var/log/kern.log?Hi @subhadip1524, were you able to solve your issue?
