Hi NVIDIA,
Please, fix this warning message on boot:
------------[ cut here ]------------
WARNING: CPU: 1 PID: 1550 at drivers/gpu/drm/drm_ioctl.c:143 drm_setversion+0x185/0x190 [drm]()
No drm_driver.set_busid() implementation provided by nvidia_frontend_exit_module [nvidia]. Use drm_dev_set_unique() to set the unique name explicitly.
Modules linked in: w83627ehf adt7475 hwmon_vid coretemp vboxpci(O) vboxnetadp(O) vboxnetflt(O) vboxdrv(O) binfmt_misc fuse hid_generic usbhid hid snd_usb_audio snd_usbmidi_lib snd_rawmidi uvcvideo videobuf2_core v4l2_common videodev videobuf2_vmalloc videobuf2_memops snd_hda_codec_realtek snd_hda_codec_generic microcode pcspkr i2c_i801 sr_mod cdrom fan snd_hda_codec_hdmi 8250 serial_core sg xhci_pci xhci_hcd nvidia(PO) drm agpgart snd_hda_intel snd_hda_controller snd_hda_codec snd_hwdep snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd ehci_pci ehci_hcd e1000e ptp pps_core evdev
CPU: 1 PID: 1550 Comm: X Tainted: P O 3.18.0-ic #1
Hardware name: System manufacturer System Product Name/P8P67 PRO, BIOS 3602 11/01/2012
00000000 00000000 edd49dcc ca3743ac edd49e0c edd49dfc ca03dc0a f89590c4
edd49e28 0000060e f8957927 0000008f f89366d5 f89366d5 edd49e80 edcb2000
ffffffea edd49e14 ca03dcae 00000009 edd49e0c f89590c4 edd49e28 edd49e3c
Call Trace:
[<ca3743ac>] dump_stack+0x48/0x69
[<ca03dc0a>] warn_slowpath_common+0x7a/0xa0
[<f89366d5>] ? drm_setversion+0x185/0x190 [drm]
[<ca03dcae>] warn_slowpath_fmt+0x2e/0x30
[<f89366d5>] drm_setversion+0x185/0x190 [drm]
[<f8936550>] ? drm_noop+0x30/0x30 [drm]
[<f89360ec>] drm_ioctl+0x2bc/0x530 [drm]
[<ca0e8761>] ? inode_permission+0x11/0x50
[<ca0e90d5>] ? link_path_walk+0x1d5/0x720
[<ca0ebcb2>] ? path_openat+0xa2/0x560
[<ca0ec950>] ? do_filp_open+0x30/0x80
[<f8935e30>] ? drm_copy_field+0x80/0x80 [drm]
[<ca0ee9da>] do_vfs_ioctl+0x6a/0x540
[<ca0ec188>] ? final_putname+0x18/0x40
[<ca0deac4>] ? do_sys_open+0x194/0x210
[<ca0eeeee>] SyS_ioctl+0x3e/0x80
[<ca378630>] sysenter_do_call+0x12/0x12
---[ end trace 990d74af2caa5ce8 ]---
CPU: 1 PID: 1550 Comm: X Tainted: P W O 3.18.0-ic #1
Call Trace:
[<ca05d355>] ? __update_cpu_load+0xa5/0xe0
[<ca07af0c>] ? hrtimer_forward+0x9c/0x190
[<ca08027b>] ? ktime_get+0x4b/0x100
[<ca087b75>] ? clockevents_program_event+0xa5/0x160
[<ca0895e4>] ? tick_program_event+0x24/0x30
[<ca07b9cf>] ? hrtimer_interrupt+0x14f/0x2a0
---[ end trace 990d74af2caa5ce9 ]---
