Kernel 4.10.1-1 and 340.102 driver. ERROR: Unable to load the kernel module 'nvidia.ko'
Hello! I patched 340.102 with http://pastebin.com/u2STDSNd this patch. Now driver is compiled successfully, but after compiling there are some errors:
9949 ERROR: Unable to load the kernel module 'nvidia.ko'.  This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc t     hat differs from the one used to build the target kernel, or if a driver such as rivafb, nvidiafb, or nouveau is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA g     raphics device(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
9950
9951 Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information.
9952 -> Kernel module load error: No such device
9953 -> Kernel messages:
9954 [  472.211462]  warn_slowpath_fmt+0x4f/0x60
9955 [  472.211466]  proc_register+0xf3/0x120
9956 [  472.211471]  proc_mkdir_data+0x61/0x90
9957 [  472.211580]  nv_register_procfs+0x4c/0x1d0 [nvidia]
9958 [  472.211669]  nvidia_init_module+0x286/0x770 [nvidia]
9959 [  472.211753]  ? nv_drm_init+0xf/0xf [nvidia]
9960 [  472.211832]  nvidia_frontend_init_module+0x4c/0x881 [nvidia]
9961 [  472.211916]  ? nv_drm_init+0xf/0xf [nvidia]
9962 [  472.211918]  do_one_initcall+0x4e/0x1a0
9963 [  472.211922]  ? __vunmap+0x6d/0xc0
9964 [  472.211923]  ? __vunmap+0x6d/0xc0
9965 [  472.211925]  do_init_module+0x5b/0x207
9966 [  472.211928]  load_module+0x197f/0x1d80
9967 [  472.211932]  ? __symbol_put+0x50/0x50
9968 [  472.211934]  SYSC_finit_module+0xa4/0xe0
9969 [  472.211938]  entry_SYSCALL_64_fastpath+0x1e/0xad
9970 [  472.211940] ---[ end trace fbd0f784be317d92 ]---
9971 [  472.211941] NVRM: failed to register procfs!
9972 [  472.211970] NVRM: request_mem_region failed for 16M @ 0xfd000000. This can
9973                NVRM: occur when a driver such as rivatv is loaded and claims
9974                NVRM: ownership of the device's registers.
9975 [  472.211974] nvidia: probe of 0000:01:00.0 failed with error -1
9976 [  472.211991] Error: Driver 'nvidia' is already registered, aborting...
9977 [  472.211991] NVRM: DRM init failed
Why driver nvidia is already registered?
You also need to patch for 4.9 kernel
https://pkgs.rpmfusion.org/cgit/nonfree/nvidia-340xx-kmod.git/tree/4.9.0_kernel.patch
nope. the same error
Make sure nomodeset is in your /etc/default/grub at the end of the GRUB_CMDLINE_LINUX_DEFAULT options
grub2-mkconfig -o /boot/grub2/grub.cfg
to update your grub, and reboot.
Also need to add nv_unregister_procfs in kernel/nv.c
right after line 1041:
pci_unregister_driver(&nv_pci_driver);
nv_unregister_procfs();
failed5:
rm_shutdown_rm(sp);
Save it and build again, you need both patches 4.9 & 4.10 applied too.
This worked succesful for me using (last updated) OpenSuSE Tumbleweed 20170303 kernel 4.10.1-1-default x86_64
Thank you! It works! I also using OpenSUSE Tumbleweed and you saved my day!
Hello Tumbleweed Folks,
Would you be kind to give full “how to” with patch links (downloadable) and numbered steps
for making the 340.102 work for kernel 4.10 (64 bit)?
Thanks in advance!!!
What is the patch you used?
Link is dead
Hello, please tell details in us how install your property driver nvidia-340.102 on kali linux 2017.1.
i am having similar issue in RHEL7.6 Kernel version is 3.10.0-957.10.1.el7.x86_64
entry in /etc/default/grub
GRUB_CMDLINE_LINUX=“crashkernel=auto rd.lvm.lv=rootvg/lv_root rd.lvm.lv=rootvg/lv_swap rd.lvm.lv=rootvg/lv_usr rd.driver.blacklist=nouveau nouveau.modeset=0 rhgb quiet splash nomodeset”" audit=1"
i have Tesla v100 GPU cards assigned to vmware vm via passthrough, able to see the PCI in operating system
[root@server ~]# lspci | grep -i nvidia
13:00.0 3D controller: NVIDIA Corporation GV100GL [Tesla V100 PCIe 16GB] (rev a1)
[root@server ~]#
have disabled the nouveau and re-created initramfs as well.
[root@server modprobe.d]# cat nvidia-installer-disable-nouveau.conf
generated by nvidia-installer
blacklist nouveau
options nouveau modeset=0
[root@server modprobe.d]# pwd
/etc/modprobe.d
[root@server modprobe.d]# cat blacklist-nouveau.conf
blacklist nouveau
while installing latest nvidia cuda driver i am having below error.
[root@server satmp]# more /var/log/cuda-installer.log
INFO: Checking compiler version…
INFO: gcc location: /bin/gcc
INFO: gcc version: gcc version 4.8.5 20150623 (Red Hat 4.8.5-36) (GCC)
INFO: Window setup complete
INFO: Cleaning up window
INFO: Complete
INFO: Initializing menu
INFO: Setting install of manpages to 0
INFO: Path doesn’t end with ‘/’, adding it
INFO: Setup complete
INFO: Complete
INFO: Components to install:
INFO: Driver
INFO: /bin/lsb_release
INFO: Executing NVIDIA-Linux-x86_64-418.39.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --inst
all-libglvnd 2>&1
INFO: Verifying archive integrity… OK
INFO: Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 418.39…
INFO:
INFO: WARNING: One or more modprobe configuration files to disable Nouveau are
INFO: already present at:
INFO: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be
INFO: sure you have rebooted your system since these files were written.
INFO: If you have rebooted, then Nouveau may be enabled for other
INFO: reasons, such as being included in the system initial ramdisk or
INFO: in your X configuration file. Please consult the NVIDIA driver
INFO: README and your Linux distribution’s documentation for details on
INFO: how to correctly disable the Nouveau kernel driver.
INFO:
INFO:
INFO: Welcome to the NVIDIA Software Installer for Unix/Linux
INFO:
INFO: Detected 20 CPUs online; setting concurrency level to 20.
INFO: Installing NVIDIA driver version 418.39.
INFO: For some distributions, Nouveau can be disabled by adding a file in the
INFO: modprobe configuration directory. Would you like nvidia-installer to
INFO: attempt to create this modprobe file for you? (Answer: Yes)
INFO:
INFO: One or more modprobe configuration files to disable Nouveau have been
INFO: written. For some distributions, this may be sufficient to disable
INFO: Nouveau; other distributions may require modification of the initial
INFO: ramdisk. Please reboot your system and attempt NVIDIA driver installation
INFO: again. Note if you later wish to reenable Nouveau, you will need to delete
INFO: these files: /usr/lib/modprobe.d/nvidia-installer-disable-nouveau.conf,
INFO:
INFO: Performing CC sanity check with CC="/bin/cc".
INFO: Kernel source path: ‘/lib/modules/3.10.0-957.10.1.el7.x86_64/source’
INFO: Kernel output path: ‘/lib/modules/3.10.0-957.10.1.el7.x86_64/build’
INFO: Performing Compiler check.
INFO: Performing Dom0 check.
INFO: Performing Xen check.
INFO: Performing PREEMPT_RT check.
INFO: Performing vgpu_kvm check.
INFO: Cleaning kernel module build directory.
INFO: Building kernel modules
: [############### ] 43% ] 0%
: [############################# ] 95%
: [##############################] 100%
: [##############################] 100%#] 100%
: [##############################] 100%%
: [##############################] 100% 100%
INFO:
INFO: ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most
INFO: frequently when this kernel module was built against the wrong or
INFO: improperly configured kernel sources, with a version of gcc that
INFO: differs from the one used to build the target kernel, or if another
INFO: driver, such as nouveau, is present and prevents the NVIDIA kernel
INFO: module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA
INFO: GPU installed in this system is supported by this NVIDIA Linux
INFO: graphics driver release.
INFO:
INFO: Please see the log entries ‘Kernel module load error’ and 'Kernel
INFO: messages’ at the end of the file ‘/var/log/nvidia-installer.log’ for
INFO: more information.
INFO:
INFO:
INFO: ERROR: Installation has failed. Please see the file
INFO: ‘/var/log/nvidia-installer.log’ for details. You may find
INFO: suggestions on fixing installation problems in the README available
INFO: on the Linux driver download page at www.nvidia.com.
INFO:
INFO: Kernel module compilation complete.
INFO: Unable to determine if Secure Boot is enabled: No such file or directory
INFO: Kernel module load error: No such device
INFO: Kernel messages:
INFO: [ 8.960145] type=1131 audit(1552995203.835:68): pid=1 uid=0
INFO: auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm=“systemd”
INFO: exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
INFO: [ 8.972153] type=1130 audit(1552995203.847:69): pid=1 uid=0
INFO: auid=4294967295 ses=4294967295 msg='unit=rhel-import-state comm=“systemd”
INFO: [ 8.986702] type=1130 audit(1552995203.862:70): pid=1 uid=0
INFO: auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup
INFO: comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?
INFO: [ 9.002907] type=1305 audit(1552995203.878:71): audit_enabled=1 old=1
INFO: auid=4294967295 ses=4294967295 res=1
INFO: [ 9.002940] type=1305 audit(1552995203.878:72): audit_pid=11273 old=0
INFO: [ 9.231390] NET: Registered protocol family 40
INFO: [ 9.337251] IPv6: ADDRCONF(NETDEV_UP): ens192: link is not ready
INFO: [ 9.340742] vmxnet3 0000:0b:00.0 ens192: intr type 3, mode 0, 9 vectors
INFO: [ 9.341455] vmxnet3 0000:0b:00.0 ens192: NIC Link is Up 10000 Mbps
INFO: [ 10.504129] random: crng init done
INFO: [ 110.286629] VFIO - User Level meta-driver version: 0.3
INFO: [ 110.317196] ipmi message handler version 39.2
INFO: [ 110.320216] ipmi device interface
INFO: [ 110.335144] nvidia: loading out-of-tree module taints kernel.
INFO: [ 110.335151] nvidia: module license ‘NVIDIA’ taints kernel.
INFO: [ 110.335153] Disabling lock debugging due to kernel taint
INFO: [ 110.399900] nvidia: module verification failed: signature and/or
INFO: required key missing - tainting kernel
INFO: [ 110.482205] nvidia-nvlink: Nvlink Core is being initialized, major
INFO: device number 240
INFO: [ 110.482925] NVRM: This PCI I/O region assigned to your NVIDIA device is
INFO: NVRM: BAR1 is 0M @ 0x0 (PCI:0000:13:00.0)
INFO: [ 110.482927] NVRM: The system BIOS may have misconfigured your GPU.
INFO: [ 110.482931] nvidia: probe of 0000:13:00.0 failed with error -1
INFO: [ 110.482951] NVRM: The NVIDIA probe routine failed for 1 device(s).
INFO: [ 110.482952] NVRM: None of the NVIDIA graphics adapters were initialized!
INFO: [ 110.483092] nvidia-nvlink: Unregistered the Nvlink Core, major device
INFO: number 240
INFO: Finished with code: 256
[ERROR]: Install of driver component failed.
INFO: CUDA Toolkit 10.1
rajeshpodapati, you’re running into this:
https://devtalk.nvidia.com/default/topic/1047349/linux/unable-to-load-the-nvidia-drm-kernel-module-on-centos-7/post/5315092/#5315092
