mtk
January 21, 2010, 6:28pm
1
I know this may look tricky, but it would be really useful in some cases.
Is there any way I can abort a kerner execution from inside the kernel and return some value?
Sometimes, I have a lot of data to process, but if I find an error, I don’t want to continue kernel execution and I want to return as fast as possible to the host code.
Let’s suppose the following simple example. I want to check that every element in a vector with 10 million values is >= 5.
As soon as I find something below 5, I want to abort and return false. I don’t want execute all blocks/grid, etc… Just abort and return some value that indicate something like UserAbortCode=1.
Any ideas?
Any ideas?
You can define some int value in gmem, initialize it to zero. in case you find some value that is less than 5 in any
thread/block you set it to 1 (if i recall correctly even if many threads or blocks update the same value to 1, you should
still see one).
Everytime a block starts have threadIdx.x == 0 check this value, if its zero do the calculation as above, otherwise return.
There is no special function to quit the kernel.
eyal
mtk
January 22, 2010, 7:03pm
3
still see one).
eyal
Yes, we were using something like that… but then I access global memory a lot of times, and I still have to run all the blocks.
Are you 100% sure I can’t somehow abort a kernel? I would love to be able to do something like that…
Nope, no other way.
Make sure you only read this flag once per block thread and not per thread.
eyal
