Hi everybody,
I have been struggling with an error in my jetson xavier agx. I installed some libraries and when i did a reboot, the hdmi does not output anything in the screen. It seems like the jetson is deadth. I tried to install using sdkmanager but my host pc is not able to find the device through the usb wire. Then i used the uart port using the micro usb and this message is shown when it boots:
rootfs path: /sdmmc_user/boot/initrd
lookup_linear_dir:436: Invalid file block num
ext2_walk:142: ‘initrd’ lookup failed
ext4_open_file:638 ‘/boot/initrd’ lookup failed
file /sdmmc_user/boot/initrd open failed!!
kernel boot failed
I think that the only solution is to try booting from sd card with a image. Am i right?
Any help would be appreciated.
