After referring to the homepage, ( NVIDIA Xavier - Kernel )
I compiled it according to the procedure.
- l4t installation(R31.1)
- Kernel and ToolChain installation (kernel 4.9)
- wget -O kernel-gcc-6-4-tool-chain.tar.gz https://developer.nvidia.com/embedded/dlc/kernel-gcc-6-4-tool-chain
- ./source_sync.sh ( tegra-l4t-r31.1 )
- Compile
make ARCH=arm64 O=$KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=${JETPACK}/Xavier/Linux_for_Tegra/sources/kernel/${KERNEL_DIR}/build
CROSS_COMPILE=CROSS_COMPILE=${HOME}/toolchain_bin_${VERSION}/${TOOLCHAIN_DIR}/bin/$CC_PREFIX -j4
But the following problem occurred.
Please advise.
Thank you.
…/arch/arm64/boot/dts/Makefile:112: target 'arch/arm64/boot/dts/ddot’given more than once in the same rule."
…/arch/arm64/boot/dts/Makefile:126: warning: overriding recipe for target ‘arch/arm64/boot/dts/ddot’
…/arch/arm64/boot/dts/Makefile:113: warning: ignoring old commands for ‘arch/arm64/boot/dts/ddot’
…/arch/arm64/boot/dts/Makefile:125: target 'arch/arm64/boot/dts/ddot’given more than once in the same rule."
make[2]: *** ‘arch/arm64/boot/dts/ddot//hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000.dtb’ need by ‘arch/arm64/boot/dts/…//hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000.dts’ no rule to make targe. stop.
make[2]: *** Waiting for unfinished jobs…
DTC arch/arm64/boot/dts/ddot
cc1: fatal error: arch/arm64/boot/dts/…: There are no such files or directories…
compilation terminated.
make[2]: *** […/arch/arm64/boot/dts/Makefile:126: arch/arm64/boot/dts/ddot] error 1
make[1]: *** [arch/arm64/Makefile:124: dtbs] error 2
