Thanks for reporting this.
Could you help to check if the below changes can fix the issue?
We are going to merge this change to our internal branch so the future release should contain the fix by default.
diff --git a/drivers/gpu/nvgpu/common/gr/gr_config.c b/drivers/gpu/nvgpu/common/gr/gr_config.c
index c86bba6..42cf687 100644
--- a/drivers/gpu/nvgpu/common/gr/gr_config.c
+++ b/drivers/gpu/nvgpu/common/gr/gr_config.c
@@ -686,8 +667,9 @@
* logical id.
config->gpc_tpc_physical_id_map = nvgpu_kzalloc(g,
- nvgpu_safe_mult_u32((size_t)config->gpc_count,
- sizeof(u32 *)));
+ nvgpu_safe_mult_u32(
+ nvgpu_safe_cast_u64_to_u32((size_t)config->max_gpc_count),
+ (u32)sizeof(u32 *)));
if (config->gpc_tpc_physical_id_map == NULL) {
nvgpu_err(g, "alloc gpc_tpc_physical_id_map failed");
goto clean_up_gpc_rop_config;
@@ -696,6 +678,11 @@
for (gpc_index = 0; gpc_index < config->gpc_count; gpc_index++) {
gpc_phys_id = nvgpu_grmgr_get_gr_gpc_phys_id(g,
cur_gr_instance, (u32)gpc_index);
+ if (gpc_phys_id >= config->max_gpc_count) {
+ nvgpu_err(g, "gpc_phys_id: %u is >= max_gpc_count: %u",
+ gpc_phys_id, config->max_gpc_count);
+ goto clean_up_gpc_tpc_physical_id_map_alloc_fail;
config->gpc_tpc_physical_id_map[gpc_phys_id] =
nvgpu_kzalloc(g, nvgpu_safe_mult_u32(
config->max_tpc_per_gpc_count, sizeof(u32)));
