Hello!
We have some more insights now, which I’d like to share.
The crashes also occur on some Orin 8GB modules with an “A23” in the silkscreen label.
Still, the crashes still seem to occur only on a subset of the modules. -
I have built a Kernel 6.6. with some memory-related debugging options, including the kernel address sanitizer (KAZAN).
Now, during each startup on a affected Orin module, a bug report is printed by KASAN, see attached kazan_bugreport.txt
kasan_bugreport.txt (4.8 KB)
This bugreport is not printed on an Orin module that is not prone to kernel crashes reported on the original post.
BUG: KASAN: slab-out-of-bounds in nvgpu_gr_config_init+0x1468/0x1df8 [nvgpu]
[ 17.210205] BUG: KASAN: slab-out-of-bounds in nvgpu_gr_config_init+0x1468/0x1df8 [nvgpu]
[ 17.211220] Write of size 8 at addr ffff000090c5bf40 by task nvpmodel/934
[ 17.211414]
[ 17.211462] CPU: 0 PID: 934 Comm: nvpmodel Tainted: G O 6.6.23-<our_kernel_branch> #1
[ 17.212944] Hardware name: <Our machine> with Orin NX 8 GB/Jetson, BIOS v36.4.0 10/01/2024
[ 17.217289] Call trace:
[ 17.241437] nvgpu_gr_config_init+0x1468/0x1df8 [nvgpu]
[ 17.246687] gr_init_support_impl+0x120/0x6a8 [nvgpu]
[ 17.251850] nvgpu_gr_init_support+0x148/0x348 [nvgpu]
[ 17.489325] The buggy address belongs to the object at ffff000090c5bf38
[ 17.489325] which belongs to the cache kmalloc-8 of size 8
[ 17.501050] The buggy address is located 0 bytes to the right of
[ 17.501050] allocated 8-byte region [ffff000090c5bf38, ffff000090c5bf40)
I have tried to track the origin of the reported issue, and it looks like it occurs in this line
https://nv-tegra.nvidia.com/r/gitweb?p=linux-nvgpu.git;a=blob;f=drivers/gpu/nvgpu/common/gr/gr_config.c;h=c86bba610c6b1aa57da81824a0128a104e3cd0ae;hb=8a0a5345705e069e398a79dbcba96c5db54a37f1#l699
(apparently same code in BSP 36.4.0 and 36.4.4)
There, an array index “1” is write-accessed, but with debug-logging I found out that the array only was allocated to hold one element about 10 lines above, so this is apparently an array-out-of-bounds access issue.
I can imagine that if the reported nvgpu driver writes data to where it’s not supposed to, then a heap corruption occurs, which could theoretically cause crashes reported above.
I wonder, why this only happens on some specific Orin modules, and not on others.
Edit 2025-04-15: Fixed the link to the OOT module source code.
