Kernel error on boot, gpu info does not look complete
We are just getting started with the Jetson Thor. After flashing Thor with the latest Jetson ISO (r38.2-08-22) we see an error in dmesg (see below).
lspci also shows errors
sudo lspci -vvvv -s 0000:01:00.0
0000:01:00.0 3D controller: NVIDIA Corporation TA1090SA [THOR] (rev a1)
!!! Unknown header type 7f
Device tree node: /sys/firmware/devicetree/base/bus@0/pcie@d0b0000000/pci@0,0/gpu@0,0
Interrupt: pin ? routed to IRQ 416
IOMMU group: 58
Region 0: Memory at d0c0000000 (64-bit, prefetchable) [size=16M]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
Also the gpu information in /proc seems wrong.
cat /proc/driver/nvidia/gpus/0000:01:00.0/information
Model: Unknown
IRQ: 416
GPU UUID: GPU-a7c66ad2-6dbb-0ab8-c1a2-37ba6dba3600
Video BIOS: ??.??.??.??.??
Bus Type: PCIe
DMA Size: 40 bits
DMA Mask: 0xffffffffff
Bus Location: 0000:01:00.0
Device Minor: 0
GPU Firmware: 580.00
GPU Excluded: No
[ 13.219822] ------------[ cut here ]------------
[ 13.219824] WARNING: CPU: 13 PID: 981 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x16c
[ 13.219838] Modules linked in: qrtr bridge stp llc usb_f_ncm usb_f_mass_storage nvidia(O+) usb_f_acm u_serial governor_pod_scaling(O) usb_f_rndis u_ether libcomposite algif_hash algif_skcipher af_alg bnep snd_soc_tegra_controls(O) snd_soc_tegra_utils(O) snd_soc_tegra186_arad(O) snd_soc_tegra186_asrc snd_soc_tegra210_mixer snd_soc_tegra210_mvc snd_soc_tegra210_ope snd_soc_tegra210_admaif snd_soc_tegra_pcm snd_soc_tegra210_sfc snd_soc_tegra210_adx snd_soc_tegra210_amx snd_soc_tegra210_i2s tegra210_adma snd_soc_tegra210_ahub nvvrs_pseq_rtc(O) spidev rtk_btusb(O) btusb btrtl btintel btmtk btbcm bluetooth ecdh_generic tegra_capture_coe(O) ecc crct10dif_ce sm3_ce sm3 sha3_ce sha512_ce sha512_arm64 rtl8852ce(O) nvmap(O) coresight_trbe cfg80211 snd_soc_tegra_audio_graph_card coresight nvsciipc(O) snd_soc_audio_graph_card arm_spe_pmu ivc_cdev(O) snd_soc_simple_card_utils rfkill ina238 nvpmodel_clk_cap(O) r8126(O) ina3221 tegra234_oc_event(O) tegra_aconnect tegra_cactmon_mc_all(O) thermal_trip_event(O) tegra23x_psc(O)
[ 13.219891] nvethernet(O) snd_soc_rt5640 snd_hda_codec_hdmi at24 snd_soc_rl6231 nvidia_vrs_pseq(O) snd_hda_tegra host1x_fence(O) lm90 mttcan(O) snd_hda_codec nvpps(O) snd_hda_core can_dev pwm_tegra_tachometer(O) nvidia_cspmu spi_tegra114 ramoops tegra_dce(O) reed_solomon arm_cspmu_module tegra_se(O) nvhost_nvcsi(O) tegra_se_kds(O) nvhost_pva(O) nvhost_capture(O) nvhost_vi5(O) crypto_engine tpm_ftpm_tee camera_diagnostics(O) nvhost_isp5(O) tegra_capture_isp(O) tegra_camera(O) v4l2_dv_timings host1x_nvhost(O) tegra_drm(O) tegra_wmark(O) nvhwpm(O) drm_display_helper drm_dp_aux_bus cec drm_kms_helper host1x(O) tegra_camera_platform(O) mc_utils(O) capture_ivc(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videodev videobuf2_common mc camchar(O) rtcpu_debug(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) dm_multipath nvme_fabrics fuse drm nfnetlink ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc uas ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u
[ 13.219944] pcie_tegra194 ufs_tegra(O) pcie_tegra264(O)
[ 13.219947] CPU: 13 PID: 981 Comm: modprobe Tainted: G O 6.8.12-tegra #1
[ 13.219950] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS 38.2.0-gcid-41844464 08/22/2025
[ 13.219951] pstate: 21400009 (nzCv daif +PAN -UAO -TCO +DIT -SSBS BTYPE=–)
[ 13.219953] pc : __reset_control_get_internal+0x68/0x16c
[ 13.219957] lr : __of_reset_control_get+0x190/0x1d8
[ 13.219960] sp : ffff80008f4435c0
[ 13.219961] x29: ffff80008f4435c0 x28: 0000000000000004 x27: ffff0000a07c0110
[ 13.219964] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000001
[ 13.219966] x23: 0000000000000000 x22: ffff0000888f0b50 x21: 000000000000001f
[ 13.219968] x20: ffff0000888f0b70 x19: ffff000093a0ad80 x18: 00000000fffffffe
[ 13.219970] x17: ffff80008f442db8 x16: ffffde3224c3e800 x15: ffff80008f443300
[ 13.219972] x14: ffffffffffffffff x13: 0000000000000018 x12: 0101010101010101
[ 13.219974] x11: 7f7f7f7f7f7f7f7f x10: ffffe2322830e33d x9 : 0000000000000038
[ 13.219976] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 0000000000000080
[ 13.219978] x5 : ffff80008f443618 x4 : fffffbfffde272dc x3 : 0000000000000001
[ 13.219980] x2 : 000000000000001f x1 : 000000000000001f x0 : 0000000000000000
[ 13.219982] Call trace:
[ 13.219983] __reset_control_get_internal+0x68/0x16c
[ 13.219987] __of_reset_control_get+0x190/0x1d8
[ 13.219990] __reset_control_get+0x48/0x1cc
[ 13.219993] __devm_reset_control_get+0x78/0xd4
[ 13.219996] nvlink_core_init+0x3c0af0/0x3c0d58 [nvidia]
[ 13.220206] platform_probe+0x68/0xe0
[ 13.220212] really_probe+0x150/0x2c8
[ 13.220215] __driver_probe_device+0x78/0x134
[ 13.220217] driver_probe_device+0x3c/0x164
[ 13.220220] __driver_attach+0x98/0x1c4
[ 13.220222] bus_for_each_dev+0x7c/0xf4
[ 13.220225] driver_attach+0x24/0x38
[ 13.220227] bus_add_driver+0xec/0x218
[ 13.220229] driver_register+0x5c/0x13c
[ 13.220232] __platform_driver_register+0x28/0x3c
[ 13.220235] nv_platform_register_driver+0x34/0x40 [nvidia]
[ 13.220415] init_module+0x174/0x5a0 [nvidia]
[ 13.220588] do_one_initcall+0x58/0x318
[ 13.220593] do_init_module+0x58/0x1ec
[ 13.220597] load_module+0x1f04/0x2000
[ 13.220600] init_module_from_file+0x88/0xd4
[ 13.220603] __arm64_sys_finit_module+0x148/0x330
[ 13.220605] invoke_syscall+0x48/0x134
[ 13.220610] el0_svc_common.constprop.0+0x40/0xf0
[ 13.220613] do_el0_svc+0x1c/0x30
[ 13.220616] el0_svc+0x30/0xb8
[ 13.220620] el0t_64_sync_handler+0x130/0x13c
[ 13.220622] el0t_64_sync+0x194/0x198
[ 13.220624] —[ end trace 0000000000000000 ]—
Trying to run the container loopback test also has errors.
===================================================================================================== short test summary info ======================================================================================================
FAILED tests/test_holoscan.py::test_holoscan[720-1280-bayer_format0-pixel_format0-0.1] - cupy.cuda.compiler.CompileException: nvrtc: error: invalid value for --gpu-architecture (-arch)
FAILED tests/test_holoscan.py::test_holoscan[720-1280-bayer_format1-pixel_format1-0.1] - cupy.cuda.compiler.CompileException: nvrtc: error: invalid value for --gpu-architecture (-arch)
FAILED tests/test_holoscan.py::test_holoscan[720-1280-bayer_format2-pixel_format2-0.1] - cupy.cuda.compiler.CompileException: nvrtc: error: invalid value for --gpu-architecture (-arch)
FAILED tests/test_holoscan.py::test_holoscan[720-1280-bayer_format3-pixel_format3-0.1] - cupy.cuda.compiler.CompileException: nvrtc: error: invalid value for --gpu-architecture (-arch)
FAILED tests/test_holoscan.py::test_holoscan[720-1280-bayer_format4-pixel_format4-0.1] - cupy.cuda.compiler.CompileException: nvrtc: error: invalid value for --gpu-architecture (-arch)
FAILED tests/test_holoscan.py::test_holoscan[720-1280-bayer_format5-pixel_format5-0.1] - cupy.cuda.compiler.CompileException: nvrtc: error: invalid value for --gpu-architecture (-arch)
====================================================================================== 6 failed, 16 passed, 141 skipped, 8 warnings in 4.05s =======================================================================================
Could someone please provide some guidance for debugging this ?
Thank you,
-John
Could you flash with rel-38.2.1 with sdkmanager?
Thanks @wushanbi19 , @john.miller reflashed with the latest from the sdkmanager; however, when he progressed to running the HSB demo container, things went south. Here is what John did…
OK, i flashed with rel-38.2.1 with the SDK, but still see the kernel panic. After a cold boot lspci reports OK for the gpu.
However after i run the following holoscan test commands the GPU control plane wedges.
$ git clone https://github.com/nvidia-holoscan/holoscan-sensor-bridge
cd holoscan-sensor-bridge
sh docker/build.sh --igpu
xhost +
sh docker/demo.sh
pytest
Here is the test output.
Inspecting dmesg shows a lot not happy. Our thinking is that HSB and Thor aren’t best-friends yet. Can you suggest what we try next?
Shep
please attach your full dmesg so that we can see what is wrong first.
Actually, the kernel log in first comment was not fatal. It does not matter to the error.
Wayne, John and I both tried to include the dmesg that shows the failure; however the forum software is picking up the many ampersands in the output and doesn’t let us post as it thinks they are users being referenced! Is there a way we can attach or email you?
shep
Just want to clarify. This forum could attach file up.
Generally we don’t want users to directly copy + paste a 100-lines text to forum directly.
Apologies for the length, but here is the requested full dmesg output of the failure, with ampersands replaced so as not to upset the forum software…
$ git clone GitHub - nvidia-holoscan/holoscan-sensor-bridge: NVIDIA Holoscan Sensor Bridge - Bring Your Own Sensor (BYOS) over Ethernet
xhost +
sh docker/demo.sh
pytest
root[AT]ar-thor1:/home/john/work/hsb_examples/holoscan-sensor-bridge#
And here are the errors in dmesg
[ 101.119653] irq 265: nobody cared (try booting with the “irqpoll” option)
[ 101.119703] CPU: 0 PID: 312 Comm: kworker/0:2 Tainted: G W O 6.8.12-tegra #1
[ 101.119708] Hardware name: NVIDIA NVIDIA Jetson AGX Thor Developer Kit/Jetson, BIOS 38.2.1-gcid-42061081 09/10/2025
[ 101.119711] Workqueue: pm pm_runtime_work
[ 101.119735] Call trace:
[ 101.119739] dump_backtrace+0x90/0xf0
[ 101.119749] show_stack+0x18/0x2c
[ 101.119751] dump_stack_lvl+0x7c/0x9c
[ 101.119770] dump_stack+0x18/0x2c
[ 101.119773] __report_bad_irq+0x38/0xe8
[ 101.119779] note_interrupt+0x320/0x370
[ 101.119781] handle_irq_event+0xa4/0xb8
[ 101.119793] handle_fasteoi_irq+0xa4/0x1c4
[ 101.119796] handle_irq_desc+0x48/0x80
[ 101.119799] generic_handle_domain_irq+0x1c/0x30
[ 101.119801] gic_handle_irq+0x4c/0x12c
[ 101.119803] call_on_irq_stack+0x24/0x4c
[ 101.119810] do_interrupt_handler+0x88/0x9c
[ 101.119814] el1_interrupt+0x34/0x70
[ 101.119821] el1h_64_irq_handler+0x18/0x2c
[ 101.119824] el1h_64_irq+0x68/0x6c
[ 101.119826] finish_task_switch.isra.0+0x74/0x274
[ 101.119831] __schedule+0x36c/0xc14
[ 101.119838] preempt_schedule_irq+0x3c/0x9c
[ 101.119842] el1_interrupt+0x4c/0x70
[ 101.119844] el1h_64_irq_handler+0x18/0x2c
[ 101.119845] el1h_64_irq+0x68/0x6c
[ 101.119848] osDevReadReg032+0x54/0x90 [nvidia]
[ 101.120228] ioaprtReadReg32_IMPL+0x1bc/0x1d0 [nvidia]
[ 101.120441] kflcnWaitForHaltRiscv_GA102+0x5c/0xc0 [nvidia]
[ 101.120613] kgspUnloadRm_IMPL+0xdc/0x170 [nvidia]
[ 101.120787] gpuFindClientInfoWithPidIterator_IMPL+0x964/0xa10 [nvidia]
[ 101.120954] gpuEnterStandby_IMPL+0xc0/0x2d0 [nvidia]
[ 101.121114] nvswitch_spi_init+0x3f8/0xa50 [nvidia]
[ 101.121264] RmGcxPowerManagement+0x84/0x300 [nvidia]
[ 101.121409] rm_transition_dynamic_power+0xd8/0x150 [nvidia]
[ 101.121554] nvidia_isr_kthread_bh+0x7d0/0x808 [nvidia]
[ 101.121698] pci_pm_runtime_suspend+0x54/0x1c0
[ 101.121712] genpd_runtime_suspend+0xa8/0x25c
[ 101.121721] __rpm_callback+0x48/0x1d8
[ 101.121730] rpm_callback+0x74/0x80
[ 101.121732] rpm_suspend+0x114/0x66c
[ 101.121734] pm_runtime_work+0xdc/0xe0
[ 101.121737] process_one_work+0x170/0x424
[ 101.121743] worker_thread+0x328/0x440
[ 101.121746] kthread+0x110/0x124
[ 101.121752] ret_from_fork+0x10/0x20
[ 101.121759] handlers:
[ 101.121776] [<00000000f39b677f>] irq_default_primary_handler threaded [<000000009971c1c9>] regmap_irq_thread
[ 101.124661] Disabling IRQ #265
[13959.153947] tegra-mc 8108020000.memory-controller: dispr: non-se[HEX_ADDR] EMEM address decode error (EMEM decode error)
[13959.153992] tegra-mc 8108020000.memory-controller: pcr response with poison bit error status:0
[13959.163851] tegra-mc 8108020000.memory-controller: dispr: non-se[HEX_ADDR] EMEM address decode error (EMEM decode error)
[13959.176321] tegra-mc 8108020000.memory-controller: dispr: non-se[HEX_ADDR] EMEM address decode error (EMEM decode error)
[13959.188892] tegra-mc 8108020000.memory-controller: dispr: non-se[HEX_ADDR] EMEM address decode error (EMEM decode error)
[13959.201464] tegra-mc 8108020000.memory-controller: dispr: non-se[HEX_ADDR] EMEM address decode error (EMEM decode error)
[13959.214116] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214117] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214119] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214120] arm-smmu-v3 8806000000.iommu: 0x0000007ffd488c80
[13959.214120] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214123] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214123] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214124] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214126] arm-smmu-v3 8806000000.iommu: 0x0000007ffd48ac80
[13959.214127] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214129] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214130] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214131] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214132] arm-smmu-v3 8806000000.iommu: 0x0000007ffd488d80
[13959.214133] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214135] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214136] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214138] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214139] arm-smmu-v3 8806000000.iommu: 0x0000007ffd48cc80
[13959.214140] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214142] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214143] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214144] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214145] arm-smmu-v3 8806000000.iommu: 0x0000007ffd48ad80
[13959.214146] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214149] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214150] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214151] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214152] arm-smmu-v3 8806000000.iommu: 0x0000007ffd48ec80
[13959.214153] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214155] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214156] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214157] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214158] arm-smmu-v3 8806000000.iommu: 0x0000007ffd490c80
[13959.214159] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214162] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214162] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214163] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214164] arm-smmu-v3 8806000000.iommu: 0x0000007ffd48cd80
[13959.214165] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214168] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214169] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214171] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214172] arm-smmu-v3 8806000000.iommu: 0x0000007ffd492c80
[13959.214174] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[13959.214177] arm-smmu-v3 8806000000.iommu: event 0x10 received:
[13959.214178] arm-smmu-v3 8806000000.iommu: 0x0000090000000010
[13959.214180] arm-smmu-v3 8806000000.iommu: 0x0000020800000000
[13959.214181] arm-smmu-v3 8806000000.iommu: 0x0000007ffd494c80
[13959.214183] arm-smmu-v3 8806000000.iommu: 0x0000000000000000
[Network events and other entries continue normally…]
Once the test completes the gpu is wedged.
0000:01:00.0 3D controller: NVIDIA Corporation Device 2b00 (rev a1)
Device tree node: /sys/firmware/devicetree/base/bus[AT]0/pcie[AT]d0b0000000/pci[AT]0,0/gpu[AT]0,0
IOMMU group: 58
I am not sure if you get my point or not.
I mean you could add text file into your gedit, save it as a file and then upload that file.
Not pasting any log here.
Also, I need your error log right after the error happened.
So to make sure we are on the same page. Please define what error you want to discuss here first.
Do not mix up 2~3 error altogether in just one topic. It won’t be efficient to discuss issue in such way.
There is exactly one error here: The HSB demo container example is failing with AGX Thor. The application error is posted earlier in the thread; as is the dmesg spew that is farther from the scene of the crime.
Sorry, I didn’t see the upload icon on the edit bar. Will use that going forward.
Ok, then please file new topic for those lspci error. We will only discuss the HSB issue in this topic.
The lspci is a side-effect, a consequence, of the HSB issue. Like the disturbing dmesg output, the faulty is lspci was caused-by running the HSB program as in the docs. Yes, lets only discuss the HSB issue please. … Apologies for any confusion.
I’ve not tried it but have you followed thor-jp7-setup.md?
hello shepard.siegel,
let me double check how you setup an environment to test with HSB.
did you set up the docker tool since it need to run under docker, please share the steps for reference.
BTW,
I doubt it’s due to Jetson Thor supports the OpenRM driver architecture. (Thor did not used nvgpu drivers)
did you have Leopard Eagle VB1940 cameras for testing HSB with AGX Thor on JP-7.0?
Jerry,
We’re starting in on HSB without any sensor like the VB1940.
If that sensor is needed to work through some Nvidia examples, we can surely get one.
Our thinking is we could do the same (for development) with a CX6 NIC at the far/sensor end.
We understand that some of the HSB examples require specific sensors.
Sorry again for the topic alias.
Shep
let’s using Topic 345720 for tracking demo container failure.
