362.768843) uvcvideo: Non-zero status (-71) in video completion handler.
362.776462] uvcvideo: Non-zero status (-71) in video completion handler.
362.789998] uvcvideo: Non-zero status (-71) in video completion handler.
362.791510] uvcvideo: Non-zero status (-71) in video completion handler.
362.799144] uvcvideo: Non-zero status (-71) in video completion handler.
362.806724] uvcvideo: Non-zero status (-71) in video completion handler.
I 363.086730] uvcvideo 1-2.2:1.0: Entity type for entity Extension 3 was not initialized! [ 363.095865] uvcvideo 1-2.2:1.0: Entity type for entity Processing 2 was not initialized!
[ 363.116083] uvcvideo 1-2.2:1.0: Entity type for entity Camera 1 was not initialized!
363.139298] usb 1-2.2: 3:1: cannot get freq at ep 0×84
368.980569) sysfs group ‘pouer’ not found for kobject ‘events’
363.987295] -_— - [ cut here 1-.
L 368.992299] HARNING: CPU: 0 PID: 6985 at /home/dyf/jetson_nano_file/6001b/32.4.3/jetson_nano/kernel/kernel-4.9/fs/sysfs/group.c:237 sysfs_remove_group+0x98/0
[ 364.007717] —[ end trace 7a95a67267a412f3 ]—
364.040929] sysfs group ‘pouer’ not found for kobject ‘inputs’
364.0476751
----------[ cut here 1-.
xa0
364.0528771 MARNING: CPU: 1 PID: 6935 at /home/dyf/jetson_nano_file/6001b/32.4.3/jetson_nano/kernel/kernel-4.9/fs/sysfs/group.c:237 sysfs_remove_group+0x98/0
[ 364.068719] —[ end trace 7a95a67267a41244 ]—
I! 364.080597] sysfs group 'Id" not found for kobject ‘inputs’
364.087016]
•–[ cut here 1-…
[ 364.092418) HARNING: CPU: 1 PID: 6935 at /home/dyf/jetson_nano_f11e/6001b/32.4.3/jetson_nano/kernel/kernel-4.9/fs/sysfs/group.c:237 sysfs_remove_group+0x98/0
[ 364.108675] —[ end trace 7a95a67267a412f5 ]—
364.128444] sysfs group ‘capabilities’ not found for kobject ‘Inputs’
364.1359101
– L cut here ]----
-=-1
xa0
364.141526] HARNING: CPU: 3 PID: 6985 at /home/dyf/jetson_nano_f11e/6001b/32.4.3/jetson_nano/kernel/kernel-4.9/fs/sysfs/group.c:237 sysfs_remove_group+0x98/0
364.158185] —[ end trace 7a95a67267a412f6 ]—
364.164807] susfs group ‘power’ not found for kobject ‘media?’
364.171873}
—[ cut here ]—.
xa0
364.177700] HARNING: CPU: 3 PID: 6935 at /home/dyf/jetson_nano_f11e/6001b/32.4.3/jetson_nano/kernel/kerne1-4.9/fs/sysfs/group.c:237 sysfs_remove_group+0x98/0
364.194758] —[ end trace 7a95a67267a412f7 ]—
Please provide more information of how it’s happened?
Is it on custom carrier board?
Which JetPack version?
the board is rts0-6001b realtimes
and jetpack is 4.4
Is there any application running?
Can it be reproduced on devkit?
Can you try with newer JetPack?
