i tried two kinds of kernels for projection,one is nearest interpolation.one is cubic interpolation.both of these two kernel are tranformed using image2D.
the kernel is
__kernel
void median(__global CB* cb,
__read_only image2d_t SourceRgbaTex,sampler_t RowSampler,__global unsigned int* uiDest,
unsigned int uiWidth, unsigned int uiHeight)
int gx=get_global_id(0);
int gy=get_global_id(1);
// float4 f4Sum = (float4)0.0f;
if(gx < uiWidth && gy<uiHeight)
* transformation
float k = 1.0f / (cb->a * gcol + cb->b * grow + 1.0f);
float x = (cb->c * gcol + cb->d * grow + cb->e) * k; //col
float y = (cb->f * gcol + cb->g * grow + cb->h) * k; //row
int pix = (int)x;
int scn = (int)y;
* pixel sampling from src image
unsigned int r, g, b;
if ( pix < 0 || uiWidth <= pix || scn < 0 || uiHeight <= scn)
// out of source image, use padding instead
r = PADDING;
g = PADDING;
b = PADDING;
else
// nearest neighborhood
int x1=select(ceil(x),floor(x),fabs(ceil(x)-x)-fabs(floor(x)-x)>0);
int y1=select(ceil(y),floor(y),fabs(ceil(y)-y)-fabs(floor(y)-y)>0);
int2 pos =
{x1, y1};
uint4 p = read_imageui(SourceRgbaTex, RowSampler, pos);
r=p.x;
g=p.y;
b=p.z;
// a=p.w;
//bicubic interpolation
float abyRed[4][4], abyGreen[4][4], abyBlue[4][4];
int i,j;
for (i = 0; i < 4; i++)
for (j = 0; j < 4; j++)
int2 pos=
{scn + i - 2,pix + j - 2};
float4 p0 = convert_float4(read_imageui(SourceRgbaTex, RowSampler,pos));
abyBlue[i][j] = p0.z;
abyGreen[i][j] = p0.y;
abyRed[i][j] = p0.x;
uint4 p0 = read_imageui(SourceRgbaTex, RowSampler,(int2)(scn + i - 2,pix + j - 2));
abyBlue[i][j] = 0;
abyGreen[i][j] =0;
abyRed[i][j] = 0;*/
float afu[4], afv[4];
float fv = y - scn;//[0,1)
float fu = x - pix;
afu[0] = Sinxx(1.0f + fu);
afu[1] = Sinxx(fu);
afu[2] = Sinxx(1.0f - fu);
afu[3] = Sinxx(2.0f - fu);
afv[0] = Sinxx(1.0f + fv);
afv[1] = Sinxx(fv);
afv[2] = Sinxx(1.0f - fv);
afv[3] = Sinxx(2.0f - fv);
float afRed[4] =
0.0f, 0.0f, 0.0f, 0.0f
float afGreen[4] =
float afBlue[4] =
afRed[i] += afv[j] * abyRed[j][i];
afGreen[i] += afv[j] * abyGreen[j][i];
afBlue[i] += afv[j] * abyBlue[j][i];
r =
(T)(BOUND((afu[0] * afRed[0] + afu[1] * afRed[1] + afu[2]
* afRed[2] + afu[3] * afRed[3]), 0, 255));
g =
(T)(BOUND((afu[0] * afGreen[0] + afu[1] * afGreen[1]
+ afu[2] * afGreen[2] + afu[3] * afGreen[3]), 0, 255));
b =
(T)(BOUND((afu[0] * afBlue[0] + afu[1] * afBlue[1] + afu[2]
* afBlue[2] + afu[3] * afBlue[3]), 0, 255));
uint4 w =
r,
g,
b,
0
//uint4 p = read_imageui(SourceRgbaTex, RowSampler, (int2)(gx,gy));
uiDest[grow * get_global_size(0)+ get_global_id(0)] = rgbaInt4ToUint(w);
CB is a struct of parameters
there is no error during compile and run time. but oberviously,the kernel is not executed,even the parameter of CB is not transfored.
but the strange things is,if I tryed another kernel using nearest interpolation,which is commented out in the upper code,the kernel can run correctly.
can any one help me to fix this problem?
thanks.
