Kernel is not launching in my code. What is the problem
I am trying a code for matrix multiplication. But the answer came out to be wrong. So when I checked what is the issue, I found that the kernel is not launching for some reason. What is the reason. Here is my code.
MY GPU is Quadro P2000 and CUDA version 11.2
#include <stdio.h>
#include <memory>
#include <cstring>
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include <stdlib.h>
#include <time.h>
__global__ void matmul_gpu(int *a, int *b, int *output, int nx_a, int ny_a, int nx_b, int ny_b)
	int row = threadIdx.x + blockIdx.x*blockDim.x;
	int col = threadIdx.y + blockIdx.y*blockDim.y;
	printf("row :- %d, col :- %d\n",row,col);
	int sum = 0;
	if(row > nx_a || col > ny_a)
		return;
	for(int k = 0; k < ny_b; k++)
		sum += a[row*ny_b + k] * b[col + ny_a*k];
	output[row*ny_b + col] = sum;
void matmul_cpu(int *a, int *b, int *output, int nx_a, int ny_a, int nx_b, int ny_b)
	for(int i = 0; i <  nx_a; i++)
		for(int j =0; j < ny_b; j++)
			int sum = 0;
			for(int k =0; k < nx_b ; k++)
				sum += (a[k + nx_b*i] * b[k*ny_b + j]);
			output[i + nx_b*j] = sum;
int main()
	size_t nx_a = 256,ny_a = 256,nx_b = 256,ny_b = 256;
	int *h_a,*h_b,*h_c;
	int block_size = 128;
	int BYTES_A,BYTES_B,BYTES_C;
	BYTES_A = nx_a * ny_a * sizeof(int);
	BYTES_B = ny_b * nx_b * sizeof(int);
	BYTES_C = nx_a * ny_b * sizeof(int);
	h_a = (int*)(malloc(BYTES_A));
	h_b = (int*)(malloc(BYTES_B));
	h_c = (int*)(malloc(BYTES_C));
	memset(h_c,0,BYTES_C);
	time_t t;
	srand((unsigned)time(&t));
	for(int i = 0; i < BYTES_A/sizeof(int); i++)
		h_a[i] = (int)(rand() & 0x0F);
	for(int i = 0; i < BYTES_B/sizeof(int); i++)
		h_b[i] = (int)(rand() & 0x0F);
	int *d_a,*d_b, *d_c;
	cudaMalloc((int**)&d_a,BYTES_A);
	cudaMalloc((int**)&d_b,BYTES_B);
	cudaMalloc((int**)&d_c,BYTES_C);
	cudaMemcpy(d_a,h_a,BYTES_A,cudaMemcpyHostToDevice);
	cudaMemcpy(d_b,h_b,BYTES_B,cudaMemcpyHostToDevice);
	cudaMemcpy(d_c,h_c,BYTES_C,cudaMemcpyHostToDevice);
	dim3 block(block_size,block_size);
	dim3 grid(nx_a/block_size,ny_a/block_size);
	printf("Running kernel with block size %dx%d and grid size %dx%d\n",block.x,block.y,grid.x,grid.y);
	matmul_gpu<< <grid,block>> >(d_a,d_b,d_c,nx_a,ny_a,nx_b,ny_b);
	cudaDeviceSynchronize();
	int *gpu_result;
	gpu_result = (int*)(malloc(BYTES_C));
	cudaMemcpy(gpu_result,d_c,BYTES_C,cudaMemcpyDeviceToHost);
	matmul_cpu(h_a,h_b,h_c,nx_a,ny_a,nx_b,ny_b);
	bool wrong = false;
	for(int i = 0 ; i < BYTES_C/sizeof(int); i++)
		if(gpu_result[i] != h_c[i])
			printf("%d  %d\n",gpu_result[i],h_c[i]);
			wrong = true;
			break;
	if(wrong)
		printf("Answer is Wrong\n");
	else
		printf("Answer is correct\n");
	cudaFree(d_a);
	cudaFree(d_b);
	cudaFree(d_c);
	free(h_a);
	free(h_b);
	free(h_c);
	free(gpu_result);
	//cudaDeviceReset();
	return EXIT_SUCCESS;
Use proper CUDA error checking (google that, take the first hit, and apply it carefully to your code). If you do that you will discover that your code is not calling the kernel with a proper configuration.
In the future, I recommend:
  1. Use proper code formatting on this site, so your code is easier to read and work with. I have fixed this already in your posted code. In a nutshell, when you are editing your post, select your code then press the </> button at the top of the edit pane.
  2. Use proper CUDA error checking in your code, any time you are having trouble.
Okay thank you… I did that and found the problem.
