Hi Forum,
I’m very new to GPU programming, and I’m trying to write a simple CUDA program to speed up calculations of the digamma function for large 2D matrices. I’ve adapted a C implementation of the digamma function (from the “lightspeed” Matlab toolbox) to run on the GPU. I then compile the .cu code to a .ptx file and instantiate the kernel in Matlab by calling
k = parallel.gpu.CUDAKernel('digamma_test.ptx','digamma_test.cu');
and then use
o = feval(k,matrix);
The function works great, providing huge speed-ups on large matrices. The problem is that after a bunch of feval calls I get an error when I try to instantiate the kernel or call feval: “CUDA_ERROR_LAUNCH_FAILED”, with no more information than that. If I restart Matlab, I can get it to work again for about the same period of time.
My thoughts are that somehow I’m not managing my memory very well. I’ve never worked in a language where memory has to be explicitly managed like CUDA or C, so I’m sure I’m leaving something out. The problem is, I just don’t know what.
Here’s my kernel:
#include <math.h>
#include <stdlib.h>
#include <float.h>
/* this is directly from Minka's lightspeed toolbox*/
__global__ void digamma(double *y)
int idx_x = blockIdx.x;
int idx_y = blockIdx.y;
int offset = idx_x + idx_y * gridDim.x;
double x = y[offset];
double neginf = -INFINITY;
const double c = 12,
digamma1 = -0.57721566490153286,
trigamma1 = 1.6449340668482264365, /* pi^2/6 */
s = 1e-6,
s3 = 1./12,
s4 = 1./120,
s5 = 1./252,
s6 = 1./240,
s7 = 1./132,
s8 = 691./32760,
s9 = 1./12,
s10 = 3617./8160;
double result;
/* Illegal arguments */
if((x == neginf) || isnan(x)) {
y[offset] = NAN;
return;
/* Singularities */
if((x <= 0) && (floor(x) == x)) {
y[offset] = neginf;
return;
/* Negative values */
/* Use the reflection formula (Jeffrey 11.1.6):
* digamma(-x) = digamma(x+1) + pi*cot(pi*x)
* This is related to the identity
* digamma(-x) = digamma(x+1) - digamma(z) + digamma(1-z)
* where z is the fractional part of x
* For example:
* digamma(-3.1) = 1/3.1 + 1/2.1 + 1/1.1 + 1/0.1 + digamma(1-0.1)
* = digamma(4.1) - digamma(0.1) + digamma(1-0.1)
* Then we use
* digamma(1-z) - digamma(z) = pi*cot(pi*z)
if(x < 0) {
*p = digamma(p,1-x) + M_PI/tan(-M_PI*x);
return;
/* Use Taylor series if argument <= S */
if(x <= s) {
y[offset] = digamma1 - 1/x + trigamma1*x;
return;
/* Reduce to digamma(X + N) where (X + N) >= C */
result = 0;
while(x < c) {
result -= 1/x;
x++;
/* Use de Moivre's expansion if argument >= C */
/* This expansion can be computed in Maple via asympt(Psi(x),x) */
if(x >= c) {
double r = 1/x, t;
result += log(x) - 0.5*r;
r *= r;
#if 0
result -= r * (s3 - r * (s4 - r * (s5 - r * (s6 - r * s7))));
#else
/* this version for lame compilers */
t = (s5 - r * (s6 - r * s7));
result -= r * (s3 - r * (s4 - r * t));
#endif
/* assign the result to the pointer*/
y[offset] = result;
return;
