Kernel log levels overridden in kernel parameters - what is the correct file to change?
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Kernel log level appears to be locked at 3. This Passing Additional Kernel Parameters | NVIDIA Docs says to change this file:
drive-foundation/virtualization/pct/<platform>/linux/linux_storage_qspi.cfg
Where my platform is p3710-10-s05 - which is not mentioned on this page - but this file does not exist.
The files that do exist in this directory have no mention of loglevel and the only mention of os_args is in
linux-linux/linux1_storage_emmc.cfg
linux-linux/linux2_storage_emmc.cfg
In kernel config I have set:
so I would expect this:
to be 15 7 1 15 or similar.
What is the correct file to modiy to change the log levels so that the loglevels obey what I specify in the kernel config?
We will review the documentation and get back to you.
Does the command work for you as a temporary solution?
$ sudo sysctl -w kernel.printk="15 7 1 15"
That sets things, but not for boot. Regardless, the real solution is to add -DDEBUG to the Makefile of the module(s) of interest.
