Hi everyone,
I’m trying to communicate with MCP2515.This is my .dtbo file, i followed these steps to configure the SPI. After rebooting, everything is OK, i can see my spi_dev on /dev, and it also generated a tegra210-p3448-0000-p3449-0000-b00-mcp251x-can-controller.dtb. I wrote my own driver file like this
http://www.macs.hw.ac.uk/~hwloidl/hackspace/linux/drivers/net/can/spi/mcp251x.c
$ sudo insmod mcp251x.ko --> successful
$ ifconfig -a --> I can see the can0
$ sudo ip link set can0 up type can bitrate 500000
$ candump can0
RTNETLINK answers: Invalid argument
$ dmesg | grep mcp
[ 0.562011] GPIO line 200 (mcp2515_int) hogged as input
[ 8.786868] mcp251x: loading out-of-tree module taints kernel.
[ 70.862175] mcp251x spi0.0: failed to acquire irq 0
I have some questions
I try to add some debug statements (printk or
dev_dbg) to the MCP251x driver’s “mcp251x_can_probe” function. But I never see any of the debug prints from the MCP251x’s probe function on dmesg . Why? I can’t figure out why this probe function isn’t being called, but something is managing to return mcp251x spi0.0: failed to acquire irq 0 -
Why do i always get message “mcp251x: loading out-of-tree module taints kernel” ?
Thank you very much
This is a part of my tegra210-p3448-0000-p3449-0000-b00-mcp251x-can-controller.dts file
clocks {
can_clock {
phandle = <0x12c>;
linux,phandle = <0x12c>;
clock-accuracy = <0x64>;
clock-frequency = <0xf42400>;
#clock-cells = <0x0>;
compatible = "fixed-clock";
spi@7000d400 {
compatible = "nvidia,tegra210-spi";
reg = <0x0 0x7000d400 0x0 0x200>;
interrupts = <0x0 0x3b 0x4>;
iommus = <0x2b 0xe>;
#address-cells = <0x1>;
#size-cells = <0x0>;
dmas = <0x4c 0xf 0x4c 0xf>;
dma-names = "rx", "tx";
nvidia,clk-parents = "pll_p", "clk_m";
clocks = <0x21 0x29 0x21 0xf3 0x21 0xe9>;
clock-names = "spi", "pll_p", "clk_m";
resets = <0x21 0x29>;
reset-names = "spi";
status = "okay";
linux,phandle = <0x10c>;
phandle = <0x10c>;
prod-settings {
#prod-cells = <0x3>;
prod {
prod = <0x4 0xfff 0x0>;
prod_c_flash {
status = "disabled";
prod = <0x4 0x3f 0x7>;
prod_c_loop {
prod = <0x4 0xfff 0x44b>;
spi@0 {
//interrupt-parent = <0x56>;
//interrupts = <0xc8 0x1>;
interrupts = <0x56 0xc8 0x2>;
clocks = <0x12c>;
nvidia,rx-clk-tap-delay = <0x6>;
nvidia,enable-hw-based-cs;
compatible = "microchip,mcp2515";
reg = <0x0>;
spi-max-frequency = <0x989680>;
controller-data {
nvidia,tx-clk-tap-delay = <0x0>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
spi@1 {
compatible = "spidev";
reg = <0x1>;
spi-max-frequency = <0x1f78a40>;
controller-data {
nvidia,rx-clk-tap-delay = <0x7>;
