Hi Sir/Madam,
The size of rootfs/lib/modules that are extracted from kernel_supplement.tbz2 in JAX-TX2-Jetson_Linux_R32.1.0_aarch64.tbz2 is 47MB. But the size of the one that I built from kernel source is 914.4MB.
I found all drivers (*.ko) are the same but the sizes have huge different.
For example. the gpu “nvgup.ko”, the default release from kernel_supplement.tbz2 is 2.4 MB, The size I build from kernel source is 86.6MB. (Others also have huge different sizes)
Is there any reason to cause this different?
PS: I use “gcc-linaro-6.4.1” and R32.1
Thank you
JasonFan,
We will check this issue. Thanks for report.
Found the root cause
add “INSTALL_MOD_STRIP=1” when make module_install
but if I use “sudo” as below, the “INSTALL_MOD_STRIP=1” doesn’t work.
sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT INSTALL_MOD_STRIP=1 modules_install \
INSTALL_MOD_PATH=Linux_for_Tegra/rootfs/
If I don’t use sudo, and install to another folder, the size will be the same as kernel_supplement.tbz2 you released.
INSTALL_MOD_PATH=/temp
So now I install module to another folder and zip to update “Linux_for_Tegra/kernel/kernel_supplements.tbz2”, then use alpply_binaries.sh to update “rootfs/lib/modules”.
