Hi
I run a small java program to call cufft and libcuda from Java. The program, looking
for a GPU, setting the device, doing a transfer to device, fft transform, transfer back
is running fine.
The same program runs ok under Java when I also add some swing/awt windows. However
when I exit the program generates a kernel panic (need to reboot machine).
The trace of the panic is attached below.
I reduced the program to just looking for the GPU and calling CudaSetDevice.
The program runs, pops up the proper windows. When exit it panics.
I guess, since the driver/cuda on MacOSX is still in beta, this is what I need to live with.
Just to let you guys know.
Regards
Mark Donszelmann
Mon Apr 21 10:11:50 2008
panic(cpu 1 caller 0x001A8C8A): Kernel trap at 0x00b2c6b3, type 14=page fault, registers:
CR0: 0x8001003b, CR2: 0x0000000c, CR3: 0x013dd000, CR4: 0x00000660
EAX: 0x0725b880, EBX: 0x00000000, ECX: 0x00000001, EDX: 0x0762cce8
CR2: 0x0000000c, EBP: 0x5b09f978, ESI: 0xc1d00054, EDI: 0x00000000
EFL: 0x00010202, EIP: 0x00b2c6b3, CS: 0x00000008, DS: 0x5c000010
Error code: 0x00000000
Backtrace, Format - Frame : Return Address (4 potential args on stack)
0x5b09f778 : 0x12b0f7 (0x4581f4 0x5b09f7ac 0x133230 0x0)
0x5b09f7c8 : 0x1a8c8a (0x461720 0xb2c6b3 0xe 0x460ed0)
0x5b09f8a8 : 0x19ece5 (0x5b09f8c0 0x5b09fa74 0x5b09f978 0xb2c6b3)
0x5b09f8b8 : 0xb2c6b3 (0xe 0x48 0x10 0xb30010)
0x5b09f978 : 0xb3cbef (0x0 0x762cce8 0x0 0x5b09f99c)
0x5b09f9a8 : 0xb86434 (0x7612004 0x0 0x4c908000 0x4c908000)
0x5b09fa38 : 0xb37173 (0xc1d00054 0x5c000001 0x5c000018 0x4c908000)
0x5b09fa98 : 0xb421fa (0xc1d00054 0x5c000001 0x5c000018 0x5c000018)
0x5b09fb08 : 0xb462d9 (0xc1d00054 0x5c000001 0x40 0x5c000018)
0x5b09fb88 : 0xb464a2 (0xc1d00054 0x5c000001 0x0 0x120fcb)
0x5b09fbd8 : 0xb4a89b (0xc1d00054 0x5b09fc2c 0x5b09fc08 0x3ea7d9)
0x5b09fc48 : 0xb2e2b0 (0xc1d00054 0x0 0xc1d00054 0xb2c203)
0x5b09fc68 : 0xb2e326 (0x9a71300 0x9a71300 0x5b09fc98 0xb2bcd8)
0x5b09fc78 : 0xb2bcd8 (0x9a71300 0x10f0 0x5b09fcb8 0x1d)
0x5b09fc98 : 0x43d4ed (0x9a71300 0x5328b0 0x5b09fce8 0x0)
0x5b09fcb8 : 0x187332 (0x9a71300 0x9c1c9d8 0x1d 0x5b09fce8)
Backtrace continues…
Kernel loadable modules in backtrace (with dependencies):
com.apple.NVDAResman(5.2.4)@0xb28000->0xd67fff
dependency: com.apple.iokit.IONDRVSupport(1.5)@0xb1a000
dependency: com.apple.iokit.IOPCIFamily(2.4.1)@0x5c1000
dependency: com.apple.iokit.IOGraphicsFamily(1.5.1)@0xafe000
BSD process name corresponding to current thread: java
Mac OS version:
9C7010
Kernel version:
Darwin Kernel Version 9.2.2: Tue Mar 4 21:17:34 PST 2008; root:xnu-1228.4.31~1/RELEASE_I386
System model name: MacBookPro3,1 (Mac-F4238BC8)
