Kernel panic at 35.2.1, cannot boot to the OS
I successfully built 35.2.1 and also successfully flash to SOM with our reference board.
However, it cannot boot to the OS, and the usb log shows kernel panic.
[ 9.959239] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00[ 9.969975] CPU: 7 PID: 1 Comm: chroot Not tainted 5.10.104-tegra #1[ 9.979068] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 2.1-32413640 01/24/2023[ 9.990670] Call trace:[ 9.993192] dump_backtrace+0x0/0x1d0[ 9.996955] show_stack+0x30/0x40[ 10.000365] dump_stack+0xd8/0x138[ 10.003854] panic+0x17c/0x384[ 10.006993] do_exit+0xaa8/0xab0[ 10.010320] do_group_exit+0x4c/0xb0[ 10.013992] __arm64_sys_exit_group+0x28/0x30[ 10.018475] el0_svc_common.constprop.0+0x80/0x1d0[ 10.023388] do_el0_svc+0x38/0xb0[ 10.026792] el0_svc+0x1c/0x30[ 10.029926] el0_sync_handler+0xa8/0xb0[ 10.033857] el0_sync+0x16c/0x180[ 10.037260] SMP: stopping secondary CPUs[ 10.041441] Kernel Offset: 0x2fef0f380000 from 0xffff800010000000[ 10.047686] PHYS_OFFSET: 0xffffb92ac0000000[ 10.051970] CPU features: 0x0040006,4a80aa38[ 10.056353] Memory Limit: none[ 10.059493] —[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]—
Please refer to the attachment:
nvidia_01_20230130.log (409.9 KB)
Hi fengying_chu,
Could you boot up the board with previous release(Jetpack 5.1 EA) ?
It looks like that you flash the image into NVMe.
How did you flash the board?
Please provide the flash steps and flash log for further check.
Hi, I did the flash process again this morning, and I found it is ok to boot to the OS. I think this issue can be closed. Thanks a lot.
