Kernel Panic in kswapd0 / mem_cgroup_from_obj on JetPack 6.2.2 (R36.5.0)
Environment
Board: NVIDIA Jetson AGX Orin Developer Kit
JetPack: 6.2.2
Jetson Linux: R36.5.0 (GCID: 43688277, DATE: Fri Jan 16 03:50:45 UTC 2026)
Kernel: 5.15.185-tegra
Ubuntu: 22.04
Power mode: nvpmodel -m 3 (50W)
apt upgrade: fully up to date
Symptom
System crashes and reboots suddenly during LLM model loading (Docker container, llama.cpp server, Gemma4-26B Q4_K_M model). Also occurs during apt upgrade.
No output on serial console during crash
journalctl -b -1ends abruptly with no shutdown sequence -
pstore/ramoops captures the kernel panic after reboot
Crash is intermittent (does not occur every time)
Additional Findings
console-ramoops-0shows journal file corruption on every boot, confirming repeated unclean shutdowns -
Crash occurs consistently ~519 seconds after boot
SMP: failed to stop secondary CPUs 0-1,4at panic time -
dmesg-ramoops-0anddmesg-ramoops-1contain identical panic (same crash recorded in two ramoops slots)
Reboot History (last reboot / Jun 6)
reboot system boot 5.15.185-tegra Sat Jun 6 21:51 still running
reboot system boot 5.15.185-tegra Sat Jun 6 18:20
reboot system boot 5.15.185-tegra Sat Jun 6 16:15
reboot system boot 5.15.185-tegra Sat Jun 6 14:53
reboot system boot 5.15.185-tegra Sat Jun 6 10:19
reboot system boot 5.15.185-tegra Sat Jun 6 09:07
Kernel Panic Log (/sys/fs/pstore/dmesg-ramoops-0)
<1>[ 519.543956] Unable to handle kernel paging request at virtual address ffff004200007c68
<1>[ 519.543970] Mem abort info:
<1>[ 519.543972] ESR = 0x0000000096000005
<1>[ 519.543973] EC = 0x25: DABT (current EL), IL = 32 bits
<1>[ 519.543976] SET = 0, FnV = 0
<1>[ 519.543977] EA = 0, S1PTW = 0
<1>[ 519.543978] FSC = 0x05: level 1 translation fault
<1>[ 519.543979] Data abort info:
<1>[ 519.543980] ISV = 0, ISS = 0x00000005
<1>[ 519.543981] CM = 0, WnR = 0
<1>[ 519.543982] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000752645000
<1>[ 519.543985] [ffff004200007c68] pgd=180000082cd68003, p4d=180000082cd68003, pud=0000000000000000
<0>[ 519.543993] Internal error: Oops: 0000000096000005 [#1] PREEMPT SMP
<6>[ 519.544168] CPU: 4 PID: 163 Comm: kswapd0 Tainted: G O 5.15.185-tegra #1
<6>[ 519.544173] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.5.0-gcid-43688277 01/16/2026
<6>[ 519.544175] pstate: 804000c9 (Nzcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
<6>[ 519.544179] pc : mem_cgroup_from_obj+0xb0/0x110
<6>[ 519.544193] lr : mem_cgroup_from_obj+0x20/0x110
<6>[ 519.544229] Call trace:
<6>[ 519.544231] mem_cgroup_from_obj+0xb0/0x110
<6>[ 519.544234] list_lru_add+0xa0/0x130
<6>[ 519.544243] workingset_update_node+0x94/0xb0
<6>[ 519.544247] xas_store+0x2b4/0x560
<6>[ 519.544252] __delete_from_page_cache+0x11c/0x210
<6>[ 519.544256] __remove_mapping+0x140/0x270
<6>[ 519.544260] shrink_page_list+0x64c/0xf60
<6>[ 519.544263] shrink_lruvec+0x528/0xaa0
<6>[ 519.544265] shrink_node+0x3d0/0x770
<6>[ 519.544268] balance_pgdat+0x330/0x6f0
<6>[ 519.544271] kswapd+0x234/0x510
<6>[ 519.544273] kthread+0x184/0x1a0
<6>[ 519.544278] ret_from_fork+0x10/0x20
<0>[ 519.544284] Code: 0b010000 1ac32400 f8607840 b4000120 (f9400800)
<4>[ 519.544290] ---[ end trace f469f984dd0e6bbb ]---
<0>[ 520.554783] Kernel panic - not syncing: Oops: Fatal exception
<2>[ 521.559689] SMP: stopping secondary CPUs
<4>[ 522.618180] SMP: failed to stop secondary CPUs 0-1,4
<0>[ 522.618187] Kernel Offset: 0x32f110240000 from 0xffff800008000000
<0>[ 522.618189] PHYS_OFFSET: 0x80000000
<0>[ 522.618190] CPU features: 0x0,000005c1,a3332e5a
<0>[ 522.618193] Memory Limit: none
console-ramoops-0 (boot log at crash time, relevant excerpt)
[ 0.000000] Linux version 5.15.185-tegra ... #1 SMP PREEMPT Thu Jan 15 19:24:38 PST 2026
[ 8.371266] systemd-journald[278]: File /var/log/journal/.../system.journal
corrupted or uncleanly shut down, renaming and replacing.
journalctl -b -1 (last line before crash)
Jun 06 23:17:47 jetson-agx-orin NetworkManager[579]: dhcp4 (wlP1p1s0): state changed new lease
-> No shutdown/panic message. Log ends abruptly.
What was ruled out
NOT thermal shutdown (no thermal errors in dmesg)
NOT OOM killer (no OOM messages)
NOT power supply issue (serial output present until panic, no voltage warnings)
NOT storage full (/ partition: 25GB used / 57GB total)
apt fully up to date (JetPack 6.2.2 / R36.5.0 is latest)
Similar report
Question
Is this a known bug in kernel 5.15.185-tegra (R36.5.0)? Is there a fix or workaround available for the mem_cgroup_from_obj / kswapd0 kernel panic under memory pressure?
